List of all CVB DLLs and their corresponding licenses
There are two basic CVB packages available: the Image Manager and the Foundation Package. If you are a using a GEV or U3V compliant camera, you already can use the CameraSuite license for the Image Manager. Advanced functionalities for image processing will be provided with an additional license for the Foundation Package. If you a looking for a special application, you can get a license for a specific CVB tool.
Image Manager
The Image Manager Libraries are part of the Image Manager License, the CameraSuite License and the Embedded License enforcement.
SDK
Image Manager Libraries  C++   .Net API (C#, VB, F#)   Python   C-Style
Image Entry point when programming with CVB. Cvb::Image Stemmer.Cvb.Image cvb.Image CVCImg.dll
Driver Driver or device related operations. Cvb::DeviceFactory
Cvb::Driver
Cvb::Async
Stemmer.Cvb.DeviceFactory
Stemmer.Cvb.Driver
Stemmer.Cvb.Async
cvb.DeviceFactory CVCDriver.dll
GenApi GenICam Api based device configuration. Cvb::GenApi Stemmer.Cvb.GenApi CVGenApi.dll
Display User interface components. Cvb::UI Stemmer.Cvb.Forms
Stemmer.Cvb.Wpf
cvb.ui
Utility Helpers and utilities, which are not directly related to image processing Cvb::Utilities Stemmer.Cvb.Utilities CVCUtilities.dll
Pixel Format Conversion PFNC format conversion. Cvb Stemmer.Cvb cvb CVPixFmtCnv.dll
RTP Streaming Streaming for real-time transmission. Cvb::RTPStreaming CVRTPStreaming.dll
Webstreaming Image conversion, compression and transport. Cvb::WebStreaming Stemmer.Cvb.WebStreaming cvb.webstreaming CVWebstreaming.dll
3D 3D functionality. Cvb::PointCloud
Cvb::PointCloudFactory
Cvb::Calibrator3D
Stemmer.Cvb.PointCloud
Stemmer.Cvb.PointCloudExtensions
Stemmer.Cvb.Calibrator3D
cvb.PointCloud
cvb.PointCloudFactory
cvb.Calibrator3D
CVCore.dll
CVCore3D.dll
Applications
 GenICamBrowser Easy to use application to detect devices in the network and to get a live view without programming.
 CVB Viewer Showing images and getting access to *.vin driver hardware.
 LogGUI Tool to collect and show diagnostic data from all CVB topics.
 License Manager Tool to manage your CVB license.
 Edit Bindings Console application to detect and edit bindings between GenApi xml file and device.
Foundation
In order to use the Foundation Libraries an Image Manager and Foundation License must be acquired. If you are using the STEMMER IMAGING Modular Embedded Board the use of the Foundation Libraries is already enabled.
Foundation Libraries  C++   .Net API (C#, VB, F#)   Python   C-Style
Foundation Package
(windows only)
Comprehensive collection of optimized algorithms. Cvb::Foundation Stemmer.Cvb.Foundation cvb.foundation CVCFoundation.dll
 Foundation Tools
Arithmetic Cvb::Foundation::Arithmetic cvb.foundation Arithmetic.dll
BayerConversion Cvb::Foundation::BayerConversion Stemmer.Cvb.Foundation.BayerConversion cvb.foundation etBayerToRGB.dll
Edge Cvb::Foundation::Edge Stemmer.Cvb.Foundation.Edge cvb.foundation CVCEdge.dll
Metric Cvb::Foundation::Metric Stemmer.Cvb.Foundation.Metric cvb.foundation CVMetric.dll
Polarization Cvb::Foundation::Polarization Stemmer.Cvb.Foundation.Polarization cvb.foundation CVPolarization.dll
CVB Tools
Each CVB tool is licensed individually. Note that all the tool libraries need access to the functionality of the Image Manager, so they will need to be combined either with an Image Manager license or a Foundation Package license.
SDK
 Software Tools
Code Reader Decode common code symbologies. Cvb::CodeReader Stemmer.Cvb.CodeReader cvb.code_reader CVCodeReader.dll
Blob Search for blobs (contiguous pixel). CVCBlob.dll
GEV Server Flexible image server for data transfer to multiple PCs via multicast, GigE Vision and GenICam compliant hardware simulation. Cvb::GevServer Stemmer.Cvb.GevServer cvb.gevserver CVGevServer.dll
Match3 Alignment of 3D objects. Cvb::Match3D Stemmer.Cvb.Match3D cvb.match_3d Match3D.dll
CAD-based 3D-object recognition. Cvb::Dnc Stemmer.Cvb.Dnc cvb.dnc CVDNCFind.dll
Minos High-speed decision tree object recognition and OCR/OCV. Cvb::Minos Stemmer.Cvb.Minos cvb.minos MinosCVC.dll
Polimago Search and classification. Cvb::Polimago
Cvb::SampleDatabase
Stemmer.Cvb.Polimago
Stemmer.Cvb.SampleDatabase
cvb.polimago
cvb.sample_database
Polimago.dll
Sil.dll
Shape Finder Object recognition using geometric information. Cvb::ShapeFinder2 Stemmer.Cvb.ShapeFinder2 cvb.shapefinder2 SF.dll
Spectral Work with hyperspectral imaging data. Cvb::Spectral Stemmer.Cvb.Spectral cvb.spectral CVSpectral.dll
Applications
TeachBench Training utility for various pattern recognition algorithms (Minos, Polimago, Match3D-DNC).
