Camera Simulation
CVMockTL
CVMockTL is a simulated GenTL producer that provides an interface, devices and streams without relying on any physical hardware.
Usage
In the GenICam Browser, the CVMockTL can be enabled via View-> Show / hide TLs....
In order to detect the CVMockTL in code, the IncludeMockTL flag has to be set, programmatically. For more information see the Device Discovery Documentation.
#include <cvb/device_factory>
auto discoveredDevices = Cvb::DeviceFactory::Discover(Cvb::DiscoverFlags.IncludeMockTL);
DiscoverFlags
var discoveredDevices = DeviceFactory.Discover(DiscoverFlags.IncludeMockTL);
discoveredDevices = cvb.DeviceFactory.discover_from_root(cvb.DiscoverFlags.IncludeMockTL)
Configuration
The CVMockTL can be configured either through the GenICam Browser or via a user-created configuration file, CVMockTL.json. This file can be placed locally (residing in the working directory of the application that should use the CVMockTL) or globally (residing in %cvbdata%\Drivers). The CVMockTL.json placed locally will take priority over the global one.
By default no CVMockTL.json file is deployed when installing CVB. You need to create it yourself, using the example below (or a similar configuration):
"ID" : "CVMockTL.cti",
"Interfaces" : [
"ID" : "MyInterface0",
"Devices" : [
"ID" : "MyDevice0",
"SerialNumber" : "12345",
"UserName" : "MockDevice",
"Model" : "Mock Camera (Default)",
"Version" : "1.0",
"Streams" : [
"ID" : "MyStream0",
"Width" : 640,
"Height" : 480,
"PixelFormat" : "Mono8"
"ID" : "MyStream1",
"PixelFormat" : "Mono16"
"ID" : "MyStream2",
"PixelFormat" : "RGB8"
"ID" : "MyStream3",
"PixelFormat" : "RGB10"
It defines a single interface, with a single device having four different streams. If Width and Height are not set, the stream will assume a default value of 1920x1080. If PixelFormat is not set, Mono8 will be assumed.
Furthermore the following other pixel formats are supported:
  • Mono12p
  • BayerBG12p
  • BayerRG12p
  • BayerGB12p
  • BayerGR12p
Key Type Description Mandatory
Devices Array A list of available devices. Each entry describes one device. ✅
Inside each device object:
ID String Unique identifier for the device ✅
SerialNumber String Serial number of the device ❌
UserName String User-defined name for the device ❌
Model String Model name of the device ❌
Version String Firmware or hardware version of the device ❌
Streams Array List of available data streams for the device ✅
Inside each stream object:
ID String Unique identifier for the stream. ✅
Width Integer Width of the image stream in pixels ❌
Height Integer Height of the image stream in pixels ❌
PixelFormat String Format of pixel data (e.g., Mono8, Mono16, RGB8, RGB10) ❌
ImageDirectoryPath String Filesystem path to a directory containing images to stream ❌
ImageOrder Array[String] Ordered list of image file paths to load from disk ❌
Streaming image files from disk
To stream image files from disk when using the CVMockTL you can use the ImageDirectoryPath property. A relative path is interpreted based on the current working directory.
"Streams" : [
"ID" : "MyStream0",
"ImageDirectoryPath" : "C:\\path\\to\\a\\directory"
When using the ImageDirectoryPath property, the Width, Height and PixelFormat properties are ignored.
To specify a list of image file paths, the ImageOrder key is used. The value describes a list of image files to load in the specified order. If a client wants to load:
  • image_2.tif
  • image_0.tif
  • image_1.tif
in that order, he should write the configuration file as follows:
"Streams" : [
"ID" : "MyStream0",
"ImageOrder" : [
"/path/to/image_2.tif",
"/path/to/image_0.tif",
"/path/to/image_1.tif"
The following things need to be considered when streaming images from disk:
  • Once the last image has been streamed, it will loop back to streaming the first image.
  • When the grab is stopped and started again streaming will continue with the next image.
