The CVB installation includes several standalone Python example programs that can be executed directly. These programs are installed under %CVB%Tutorial (Windows) or $CVB/tutorial (Linux) and can also be accessed from the list below:
| Link to Example Program | Description | Location under %CVB%Tutorial |
| MetricCalibration | Example for intrinsic and extrinsic calibration of a laser triangulation system using the AQS12 target. | Foundation/CVBpy |
| MetricCalibrationInclinationLaserPlane | Example for extrinsic calibration, including the correction of an inclined laser plane, in a laser triangulation system using the AQS12 target. | Foundation/CVBpy |
| MetricCalibrationRigidBodyTransformation | Example for a rigid-body transformation (extrinsic calibration) using the AQS12 target. | Foundation/CVBpy |
| QmlBlobSearch | This example shows the blob search of CVB Foundation package. | Foundation/CVBpy |
| QmlGevServer | The QmlGevServer example starts a QML GevServer which can load a device and stream the device image. | GEVServer/CVBpy |
| BufferHandling | Example for buffer handling. | Image Manager/CVBpy |
| CompositeStreamHandler | CVBpy Example Script for 3rd generation acquisition stack to demonstrate a basic usage of CompositeStreamHandler. | Image Manager/CVBpy |
| CreateAndAccessCalibratedPointCloud | Example for creating a calibrated point cloud from a range map and accessing point cloud values. | Image Manager/CVBpy |
| DeviceConfiguration | Example for device configuration. | Image Manager/CVBpy |
| DiscoverDevices | Example for discovering devices. | Image Manager/CVBpy |
| ImageLoadSave | Example for loading and saving images. | Image Manager/CVBpy |
| ImagePixelAccess | Example for accessing image pixel values. | Image Manager/CVBpy |
| MultiPart | Example for acquiring multi part images. | Image Manager/CVBpy |
| MultiStream | Example for acquiring multiple streams. | Image Manager/CVBpy |
| PixelFormatConversion | Example for converting PFNC compliant pixel formats. | Image Manager/CVBpy |
| QmlGenDCDisplay | Example for displaying GenDC data. | Image Manager/CVBpy |
| QmlStreamDisplay | Example for QML based streaming display. | Image Manager/CVBpy |
| Rdma | Example for RDMA for GEV acquisition. | Image Manager/CVBpy |
| StreamingAsync | Example for asynchronous streaming. | Image Manager/CVBpy |
| StreamingParallel | Example for parallel streaming. | Image Manager/CVBpy |
| StreamingSimple | Example for simple Image, PointCloud and Composite streaming. | Image Manager/CVBpy |
| QmlMinos | Example for OCR reading with Minos in QML environment. | Minos/CVBpy |
| QmlCookieClassification | Example for pattern classification using Polimago search in QML environment. | Polimago/CVBpy |
| ShapeFinder | Example for pattern recognition in 2D images using ShapeFinder. | ShapeFinder/CVBpy |
| ColorConvert | Example for normalizing and calculating Lab and sRGB images on hyperspectral cubes. | Spectral/CVBpy |
| CodeReading | Example, that demonstrates how to decode Data Matrix codes in an image. | cvb_code_reader/CVBpy |
| Recording | cvb_movie2/CVBpy |
