Image Manager/CVBpy/DiscoverDevices
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/CVBpy/DiscoverDevices.
discover_devices.py:
# CVBpy Example Script
# 1. Discover all devices.
# 2. Load the first device found.
# 3. Acquire images.
mock_info = next((info for info in discover if "CVMock.vin" in info.access_token), None)
if mock_info is None:
raise RuntimeError("unable to find CVMock.vin")
mock_info.access_token, cvb.AcquisitionStack.Vin) as device:
stream = device.stream()
for i in range(10):
image, status = stream.wait()
print("Acquired image: " + str(i))
stream.abort()
discover_devices_3gen.py:
# @brief Example for discovering devices.
# CVBpy Example Script for 3rd generation acquisition stack
# to show device discovery.
# 2. Open the first device found.
# 3. Get the generic composite stream.
# 4. Acquire images.
# Requires: A connected and configured GenICam device
stream = device.stream(cvb.CompositeStream)
for i in range(10):
with composite:
print("Acquired image: {}".format(i))
stream.abort()
