CVBpy Example Script for AQS12 Calibration - Use Case 1.
This example shows how to calibrate range maps acquired by a modular laser
triangulation setup (camera and laser separated), where the intrinsic calibration
parameters are not given.
See also use case 1 described in the CVB Metric documentation:
https://help.commonvisionblox.com/NextGen/14.1/md_theory_of_operation_tools__metric.html#calibration_setup
This example program estimates homography and an affine transformation.
The affine transformation:
- corrects errors induced by an incline laser plane
- corrects scaling in x, y, z
- moves the point cloud to the coordinate system given by the reference
points of the AQS12
def print_trafo(trafo: cvb.AffineMatrix3D) -> None:
print("Estimated transformation:")
print("Translation:")
print(f"[{trafo.translation.x}, {trafo.translation.y}, "
f"{trafo.translation.z}]")
print("Transformation matrix:")
print(f"[[{trafo.matrix.at(0, 0)}, "
f"{trafo.matrix.at(0, 1)}, "
f"{trafo.matrix.at(0, 2)}],")
print(f"[{trafo.matrix.at(1, 0)}, "
f"{trafo.matrix.at(1, 1)}, "
f"{trafo.matrix.at(1, 2)}],")
print(f"[{trafo.matrix.at(2, 0)}, "
f"{trafo.matrix.at(2, 1)}, "
f"{trafo.matrix.at(2, 2)}]]")
def print_trafo_parameters(atp: cvb.AffineTransformationParameters) -> None:
print("Rotation angles about X, Y, Z axis in degrees:")
print(f"{atp.rotation_angles.x}, {atp.rotation_angles.y}, "
f"{atp.rotation_angles.z}")
print("Shear Syx, Syz:")
print(f"{atp.s_yx}, {atp.s_yz}")
print("Inclination of laser plane about X, Z axis in degrees:")
print(f"{atp.inclination_x}, {atp.inclination_z}")
print("Scale in X, Y, Z:")
print(f"{atp.scale.x}, {atp.scale.y}, {atp.scale.z}")
def print_point_3d_list(points: list[
cvb.Point3D]) ->
None:
data_list = list()
for p in points:
data_list.append(f"[{p.x}, {p.y}, {p.z}]")
delimiter = ",\n"
print(f"[{delimiter.join(data_list)}]")
def print_residuals(points: list[
cvb.Point3D]) ->
None:
print("Residuals:")
print_point_3d_list(points)
def print_aqs12_points(points: list[
cvb.Point3D]) ->
None:
print("AQS12 points:")
def create_aqs12():
points = [
def check_accuracy(residuals: list[
cvb.Point3D], desired_accuracy: float):
for point in residuals:
if (abs(point.x) > desired_accuracy or
abs(point.y) > desired_accuracy or
abs(point.z) > desired_accuracy):
return False
return True
save = False
print("Estimation of homography and affine transformation (correcting an "
"inclined laser plane)")
print("Loading range map.")
"tutorial", "Metric", "Images",
"RangeMapCalibrationPattern.tif")
print(f"Range map loaded with size of {range_map.width} x {range_map.height} "
f"from {range_map_file}.")
aqs12 = create_aqs12()
print("Estimating homography and affine matrix.")
cvb.foundation.SegmentationMethod.KmeansClustering)
range_map.planes[0], segmentor, config)
transformation_, transformation_parameters_ = \
calibrator_.correction_of_laser_plane_inclination
if transformation_:
print_trafo(transformation_)
print_residuals(residuals_)
if transformation_parameters_:
print_trafo_parameters(transformation_parameters_)
desired_accuracy_ = 0.05
if check_accuracy(residuals_, desired_accuracy_):
print("The calibration was successful and accuracy is < "
f"{desired_accuracy_} mm.")
range_map.planes[0], calibrator_,
cvb.PointCloudFlags.Float | cvb.PointCloudFlags.XYZConfidence)
if save:
cloud.save("cloud.ply")
else:
print("Results do not have desired accuracy. Check face segmentation and "
"extracted AQS12 points...")
print("Segmenting AQ12 faces on range map.")
faces_aqs12 = segmentor.face_segmentation_from_piece(range_map.planes[0])
if save:
faces_aqs12.save("AQS12faces.bmp")
print("Extracting AQ12 corner points on range map.")
points_aqs12 = segmentor.extract_projected_points_from_piece(
print_aqs12_points(points_aqs12)
cvb.foundation.AQS12RangeMapSegmentor create(int method)
cvb.foundation.CalibrationConfiguration create(cvb.foundation.AQS12Piece aqs12)
Tuple[cvb.LaserPlaneHomographyCalibrator3D, List[cvb.Point3D]] create_calibrator_from_aqs12_piece(cvb.ImagePlane image_plane, cvb.foundation.AQS12RangeMapSegmentor segmentor, cvb.foundation.CalibrationConfiguration config, Optional[cvb.Rect] aoi=None)
