Polimago/CVBpy/QmlCookieClassification
This example program is located in your CVB installation under %CVB%Tutorial/Polimago/CVBpy/QmlCookieClassification.
classification.py:
import os, sys
from PySide6 import QtCore
from PySide6.QtCore import QObject, Qt, QUrl, Property, Signal, Slot
else:
from PySide2 import QtCore
from PySide2.QtCore import QObject, Qt, QUrl, Property, Signal, Slot
from result_model import ResultModel, PolimagoResult
# Global params
GRID_STEP = 0.6
THRESHOLD = 0.0
LOCALITY = 1.0
class Classification(QtCore.QObject):
def __init__(self, device, result_model):
super().__init__()
self._device = device
self._stream = device.stream()
self._model = result_model
self._search = cvb.polimago.SearchPredictor(os.path.join(cvb.install_path(), "tutorial", "Polimago", "Images", "Cookies", "Cookies.psc"))
self._classification = cvb.polimago.ClassificationPredictor(os.path.join(cvb.install_path(), "tutorial", "Polimago", "Images", "Cookies", "CookieType.pcc"))
self._source = ""
self._search_predictor = ""
self._classification_predictor = ""
self.notify_source.connect(self.source_changed)
self.notify_search_predictor.connect(self.search_predictor_changed)
self.notify_classification_predictor.connect(self.classification_predictor_changed)
@Slot()
def snap(self):
# clear the result
self._model.update([None] * 0)
self._image, wait_status = self._stream.get_timed_snapshot(1000)
if (wait_status != cvb.WaitStatus.Ok):
return None
# refresh image view
self._model.refresh(self._image)
@Slot()
def classify(self):
if self._search == 0 or self._classification == 0:
sys.stderr.write('No search predictor or classification predictor was loaded.\n')
return None
# 1. find items
search_res, calls = self._search.grid_search(self._image, self._image.bounds, GRID_STEP, THRESHOLD, LOCALITY)
polimago_results = [None] * 0
for res in search_res:
# only use results with quality >= 0.3
if res.quality >= 0.3:
# 2. classify the items
pos = cvb.Point2D(res.x, res.y)
clf_res, confidence_distribution = self._classification.classify(self._image, pos)
polimago_results.append(PolimagoResult(pos, res.quality, clf_res))
# 3. show result
self._model.update(polimago_results)
def source(self):
return self._source
def set_source(self, imageSource):
self._source = imageSource
self.notify_source.emit()
def search_predictor(self):
return self._search_predictor
def set_search_predictor(self, searchPredictor):
self._search_predictor = searchPredictor
self.notify_search_predictor.emit()
def classification_predictor(self):
return self._classification_predictor
def set_classification_predictor(self, classificationPredictor):
self._classification_predictor = classificationPredictor
self.notify_classification_predictor.emit()
@Signal
def notify_source(self):
pass
@Signal
def notify_search_predictor(self):
pass
@Signal
def notify_classification_predictor(self):
pass
@Slot()
def source_changed(self):
# clear the result
self._model.update([])
# clear predictors
self._search = 0
self._classification = 0
# close current device
self._device.close()
# open new device / image
path = self._source.toLocalFile()
if path.endswith(".vin"):
self._device = cvb.DeviceFactory.open(
path, cvb.AcquisitionStack.Vin)
self._stream = self._device.stream()
self.snap()
elif path.endswith(".bmp"):
self._image = cvb.Image(path)
@Slot()
def search_predictor_changed(self):
if not self.search_predictor().isEmpty():
self._search = cvb.polimago.SearchPredictor(self.search_predictor().toLocalFile())
@Slot()
def classification_predictor_changed(self):
if not self.classification_predictor().isEmpty():
self._classification = cvb.polimago.ClassificationPredictor(self.classification_predictor().toLocalFile())
imageSource = Property(QUrl, source, set_source)
searchPredictor = Property(QUrl, search_predictor, set_search_predictor)
classificationPredictor = Property(QUrl, classification_predictor, set_classification_predictor)
main.py:
# @brief Example for pattern classification using Polimago search in QML environment.
import os, sys
import cvb.ui
from classification import Classification
from PySide6.QtCore import QObject, QUrl, QAbstractListModel, Qt, QModelIndex
from PySide6.QtQml import QQmlApplicationEngine, qmlRegisterType
from PySide6.QtGui import QGuiApplication, QIcon
else:
from PySide2.QtCore import QObject, QUrl, QAbstractListModel, Qt, QModelIndex
from PySide2.QtQml import QQmlApplicationEngine, qmlRegisterType
from PySide2.QtGui import QGuiApplication, QIcon
if __name__ == "__main__":
app = QGuiApplication([])
app.setApplicationName('Polimago Python tutorial')
if sys.platform == 'win32':
import ctypes
myappid = u'stemmerimaging.commonvisionblox.pycookieclassification.0'
# load the device
# setup QML interface objects
result_model = ResultModel(image_controller)
# main classification object
classification = Classification(device, result_model)
# register QML components for an image display
engine = QQmlApplicationEngine()
context = engine.rootContext()
# create a controller object to communicate with QML
# create a Minos result model to communicate with QML for overlays
context.setContextProperty("resultModel", result_model)
# create a Minos search object to communicate with QML (grab, snap)
context.setContextProperty("classification", classification)
# load main QML file
engine.load(os.path.join(os.path.dirname(os.path.abspath(__file__)), "main.qml"))
# do a first snap at startup
classification.snap()
app.exec_()
None register(cls, str uri="CvbQuick", int version_major=1, int version_minor=0, str qml_name="ImageLabel")
result_model.py:
import cvb.ui
from PySide6.QtCore import QObject, QAbstractListModel, Qt, QModelIndex, Property, Signal, Slot
else:
from PySide2.QtCore import QObject, QAbstractListModel, Qt, QModelIndex, Property, Signal, Slot
class PolimagoResult(object):
def __init__(self, pos, pos_quality, clf_res):
self._pos = pos
self._pos_quality = pos_quality
self._name = clf_res.name
self._color_quality = clf_res.quality
def position(self):
return self._pos
def name(self):
return self._name
def position_quality(self):
return self._pos_quality
def color_quality(self):
return self._color_quality
class ResultModel(QAbstractListModel):
LineText = Qt.UserRole
StartPosition = Qt.UserRole + 1
Quality = Qt.UserRole + 2
def __init__(self, image_controller, parent=None):
super(ResultModel, self).__init__(parent)
self._image_controller = image_controller
self._results = [None] * 0
def update(self, polimago_results):
self._results = polimago_results
self.layoutChanged.emit()
def roleNames(self):
roles = dict()
roles[ResultModel.LineText] = b"lineText"
roles[ResultModel.StartPosition] = b"startPosition"
roles[ResultModel.Quality] = b"quality"
return roles
def rowCount(self, parent = QModelIndex()):
return len(self._results)
def data(self, index, role = Qt.DisplayRole):
if not index.isValid():
return None
result = self._results[index.row()]
if role == ResultModel.LineText:
return result.name()
elif role == ResultModel.StartPosition:
return cvb.ui.cvb_to_qt_point(result.position())
elif role == ResultModel.Quality:
return result.position_quality()
else:
return None
@Slot()
def refresh(self, image):
self._image_controller.refresh(image)
Union[PySide2.QtCore.QPointF, PySide6.QtCore.QPointF] cvb_to_qt_point(cvb.Point2D point)
