Image Manager/CVBpy/QmlGenDCDisplay
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/CVBpy/QmlGenDCDisplay.
gendc_display.py:
# @brief Example for displaying GenDC data.
import sys
import time
import numpy as np
from PIL import Image, ImageDraw, ImageFont
from PySide6.QtCore import Qt, QThread, Signal, Slot
from PySide6.QtGui import QAction, QImage, QPixmap, QIcon, QStandardItemModel, QStandardItem
from PySide6.QtWidgets import (QApplication, QMainWindow, QPushButton, QSizePolicy,
QVBoxLayout, QWidget, QLabel, QTableView, QHeaderView, QHBoxLayout)
else:
from PySide2.QtCore import Qt, QThread, Signal, Slot
from PySide2.QtGui import QAction, QImage, QPixmap, QIcon, QStandardItemModel, QStandardItem
from PySide2.QtWidgets import (QApplication, QMainWindow, QPushButton, QSizePolicy,
# Set MOCK = True for testing with mock cameras
# Set MOCK = False when using real GenDC cameras
MOCK = True
OUTPUT_SIZE = (600, 600)
# Mapping of CompositePurpose values to human-readable names
purpose_list = {
cvb.CompositePurpose.Custom: "Custom",
cvb.CompositePurpose.Image: "Image",
cvb.CompositePurpose.PointCloud: "PointCloud",
cvb.CompositePurpose.ImageList: "ImageList"
# Function to get purpose from an index
def purpose_from_index(index):
if 0 <= index < len(purpose_list):
return purpose_list[index]
else:
return "Incompatible purpose"
# Function to resize an image
def resize_image(image, target_size):
pil_image = Image.fromarray(image)
pil_image = pil_image.resize(target_size, Image.LANCZOS)
return np.array(pil_image)
# Function to format an image
def format_image(image, mode="RGB"):
if pil_image.mode != mode:
pil_image = pil_image.convert(mode)
# Function to prepare the device
def prepare_device(device):
nm = device.node_maps["Device"]
node_tlpl = nm.nodes["Std::TLParamsLocked"]
node_tlpl.value = 0
if MOCK:
node_count = nm.nodes["Cust::TestGenDCImageCount"]
node_count.value = 2
node_mode = nm.nodes["Cust::GenDCFlowMappingConfiguration"]
node_mode.value = "MultipleFlow"
node_streamingmode = nm.nodes["Std::GenDCStreamingMode"]
node_streamingmode.value = "On"
node_tlpl.value = 1
# Function to create an image with text
def create_image_with_text(
text, image_size=(
400, 200), bg_color=(
255, 255, 255), text_color=(0, 0, 0)):
image = Image.new("RGB", image_size, bg_color)
try:
font = ImageFont.load_default()
except OSError:
font = None
if font:
draw = ImageDraw.Draw(image)
text_width, text_height = draw.textbbox.textsize(text, font)
x = (image_size[0] - text_width) // 2
y = (image_size[1] - text_height) // 2
draw.text((x, y), text, fill=text_color, font=font)
image_array = np.array(image)
else:
image_array = None
return image_array
# Function to evaluate a composite and extract images and information
def evaluate_composite(composite, id):
images = []
table = []
table.append(f"Image ID: {id}")
table.append(f"Composite purpose: {purpose_from_index(composite.purpose)}")
table.append(f"Composite element count: {composite.item_count}")
for n in range(composite.item_count):
item = composite[n]
item_type = "unknown"
img = None
if isinstance(item, cvb.Image):
item_type = "image"
img = cvb.to_array(item)
elif isinstance(item, cvb.Plane):
item_type = "plane"
img = create_image_with_text("part is a plane")
elif isinstance(item, cvb.PlaneEnumerator):
item_type = "plane enumerator"
img = create_image_with_text("part is a plane enumerator")
elif isinstance(item, cvb.PFNCBuffer):
item_type = "pfnc buffer"
img = create_image_with_text("part is a PFNC buffer")
else:
img = create_image_with_text("unknown part type")
table.append(f"Composite item #{n}: {item_type}")
img = format_image(img)
images.append(img)
return images, table
# Function to subdivide and arrange images in a grid
def subdivide_images(images):
num_images = len(images)
side_length = int(num_images ** 0.5)
num_rows = num_cols = side_length
if num_rows * num_cols < num_images:
num_cols += 1
num_rows += 1
sub_image_width = OUTPUT_SIZE[1] // num_cols
sub_image_height = OUTPUT_SIZE[0] // num_rows
output_image = np.zeros(
(OUTPUT_SIZE[0], OUTPUT_SIZE[1], 3), dtype=np.uint8)
for idx, image in enumerate(images):
sub_image = resize_image(image, (sub_image_width, sub_image_height))
row = idx // num_cols
col = idx % num_cols
output_image[row * sub_image_height:(row + 1) * sub_image_height,
col * sub_image_width:(col + 1) * sub_image_width] = sub_image
return output_image
# Class for the acquisition thread
# It continuously captures images from the device and updates the UI with new frames.
class AcquisitionThread(QThread):
updateFrame = Signal(np.ndarray)
updateTable = Signal(list)
def __init__(self, parent=None):
QThread.__init__(self, parent)
self.status = True
def run(self):
if MOCK:
cvb.DiscoverFlags.IgnoreVins | cvb.DiscoverFlags.IncludeMockTL, time_span=300)
else:
cvb.DiscoverFlags.IgnoreVins, time_span=300)
if devices:
device_token = next(iter([dev.access_token for dev in devices if
(MOCK and "MockTL" in dev.access_token) or
(not MOCK and "SD" in dev.access_token)]), None)
if not device_token:
raise RuntimeError("No suitable device found.")
with cvb.DeviceFactory.open(device_token, cvb.AcquisitionStack.GenTL) as device:
device: cvb.GenICamDevice = device
stream = device.stream(cvb.CompositeStream)
image_count = 0
while self.status:
wait_result = stream.wait()
composite: cvb.Composite = wait_result[0]
images, table = evaluate_composite(composite, image_count)
if len(images) > 1:
output_image = subdivide_images(images)
else:
output_image = images[0]
output_image_copy = output_image.copy()
# Emitting the updateFrame signal to update the UI with the new image and table data
self.updateFrame.emit(output_image_copy)
self.updateTable.emit(table)
image_count += 1
stream.stop()
sys.exit(-1)
# GUI Window Interface
# Window: This class represents the main window of the application. It sets up the user interface,
# including image display, control buttons, and data tables. It also manages the interaction
# between the UI and the acquisition thread.
class Window(QMainWindow):
def __init__(self):
super().__init__()
self.setWindowTitle("CVB GenDC Demo")
self.setGeometry(0, 0, 800, 700)
script_dir = os.path.dirname(os.path.realpath(__file__))
icon_path = os.path.join(script_dir, 'Tutorial-Python_32x32.png')
self.setWindowIcon(QIcon(icon_path))
menu = self.menuBar()
menu_file = menu.addMenu("File")
exit = QAction("Exit", self, triggered=qApp.quit)
menu_file.addAction(exit)
# Initialize and configure the UI components like labels, buttons, and table view.
self.label = QLabel(self)
self.label.setAlignment(Qt.AlignCenter)
self.label.setSizePolicy(QSizePolicy.Minimum, QSizePolicy.Minimum)
buttons_layout = QHBoxLayout()
self.button1 = QPushButton("Start")
self.button2 = QPushButton("Stop/Close")
self.button1.setMaximumWidth(100)
self.button2.setMaximumWidth(100)
self.button1.clicked.connect(self.start)
self.button2.clicked.connect(self.kill_thread)
self.button2.setEnabled(False)
buttons_layout.addWidget(self.button1)
buttons_layout.addWidget(self.button2)
self.table_model = QStandardItemModel(0, 1, self)
self.table_view = QTableView(self)
self.table_view.setModel(self.table_model)
self.table_view.verticalHeader().setVisible(False)
self.table_view.verticalHeader().setSectionResizeMode(QHeaderView.ResizeToContents)
# Organizing the layout
table_widget = QWidget()
table_layout = QVBoxLayout()
table_layout.addWidget(self.table_view)
table_widget.setLayout(table_layout)
table_widget.setSizePolicy(
QSizePolicy.Expanding, QSizePolicy.Preferred)
image_widget = QWidget()
image_layout = QVBoxLayout()
image_layout.addWidget(self.label)
image_widget.setLayout(image_layout)
central_widget = QWidget(self)
central_layout = QVBoxLayout()
central_layout.addWidget(image_widget)
central_layout.addLayout(buttons_layout)
central_layout.addWidget(table_widget)
central_widget.setLayout(central_layout)
self.setCentralWidget(central_widget)
# Set up the acquisition thread for handling image capture and processing.
self.th = AcquisitionThread(self)
self.th.finished.connect(self.close)
self.th.updateFrame.connect(self.set_image)
self.th.updateTable.connect(self.update_table)
# Create a dummy numpy array for the initial image
dummy_array = np.zeros(
self.set_image(dummy_array)
dummy_table_data = ["Press start to begin GenDC streaming"]
self.update_table(dummy_table_data)
@Slot(np.ndarray)
def set_image(self, np_image):
h, w, ch = np_image.shape
q_img = QImage(np_image.data, w, h, ch * w, QImage.Format_RGB888)
scaled_image = QPixmap.fromImage(q_img)
self.label.setPixmap(scaled_image)
@Slot()
def kill_thread(self):
print("Finishing...")
self.button1.setEnabled(True)
self.status = False
self.th.terminate()
time.sleep(1)
@Slot()
def start(self):
print("Starting...")
text = []
text.append("Starting...")
self.update_table(text)
self.button2.setEnabled(True)
self.button1.setEnabled(False)
self.th.start()
@Slot(list)
def update_table(self, data):
self.table_model.removeRows(0, self.table_model.rowCount())
self.table_model.setHorizontalHeaderLabels(["Infos"])
for item in data:
self.table_model.appendRow(QStandardItem(item))
self.table_view.horizontalHeader().setSectionResizeMode(
if __name__ == "__main__":
app = QApplication(sys.argv)
if sys.platform == 'win32':
import ctypes
myappid = u'stemmerimaging.commonvisionblox.pystreamdisplay.0'
w = Window()
w.show()
sys.exit(app.exec())
numpy.array to_array(Any buffer)
