Image Manager/CVBpy/StreamingAsync
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/CVBpy/StreamingAsync.
streaming_async.py:
# @brief Example for asynchronous streaming.
# CVBpy Example Script
# 1. Open the CVMock.vin driver.
# 2. Asynchronously acquire images.
# 3. Measure the frame rate and print results.
# Note: can be extended to multible cameras.
import asyncio
rate_counter = None
async def async_acquire(port):
global rate_counter
with cvb.DeviceFactory.open(os.path.join(cvb.install_path(), "drivers", "CVMock.vin"), port=port) as device:
stream = device.stream()
rate_counter = cvb.RateCounter()
for i in range(0, 100):
result = await stream.wait_async()
image, status = result.value
rate_counter.step()
print("Buffer index: " + str(image.buffer_index) + " from stream: " + str(port))
stream.abort()
watch = cvb.StopWatch()
loop = asyncio.get_event_loop()
loop.run_until_complete(asyncio.gather(
async_acquire(port=0)))
loop.close()
duration = watch.time_span
print("Acquired on port 0 with " + str(rate_counter.rate) + " fps")
print("Overall measurement time: " +str(duration / 1000) + " seconds")
