CVBpy Example Script for AQS12 Calibration - Use Case 2.
This example shows how to calibrate range maps acquired by a compact 3D
sensor where the intrinsic calibration parameters are given, but the
laser plane is not exactly vertical to the direction of movement.
See also use case 2 described in the CVB Metric documentation:
https://help.commonvisionblox.com/NextGen/14.1/md_theory_of_operation_tools__metric.html#calibration_setup
This example program estimates an affine transformation.
The affine transformation:
- corrects errors induced by an incline laser plane
- corrects scaling in x, y, z
- moves the point cloud to the coordinate system given by the reference
points of the AQS12
def print_trafo(trafo: cvb.AffineMatrix3D) -> None:
print("Estimated transformation:")
print("Translation:")
print(f"[{trafo.translation.x}, {trafo.translation.y}, "
f"{trafo.translation.z}]")
print("Transformation matrix:")
print(f"[[{trafo.matrix.at(0, 0)}, "
f"{trafo.matrix.at(0, 1)}, "
f"{trafo.matrix.at(0, 2)}],")
print(f"[{trafo.matrix.at(1, 0)}, "
f"{trafo.matrix.at(1, 1)}, "
f"{trafo.matrix.at(1, 2)}],")
print(f"[{trafo.matrix.at(2, 0)}, "
f"{trafo.matrix.at(2, 1)}, "
f"{trafo.matrix.at(2, 2)}]]")
def print_trafo_parameters(atp: cvb.AffineTransformationParameters) -> None:
print("Rotation angles about X, Y, Z axis in degrees:")
print(f"{atp.rotation_angles.x}, {atp.rotation_angles.y}, "
f"{atp.rotation_angles.z}")
print("Shear Syx, Syz:")
print(f"{atp.s_yx}, {atp.s_yz}")
print("Inclination of laser plane about X, Z axis in degrees:")
print(f"{atp.inclination_x}, {atp.inclination_z}")
print("Scale in X, Y, Z:")
print(f"{atp.scale.x}, {atp.scale.y}, {atp.scale.z}")
def print_point_3d_list(points: list[
cvb.Point3D]) ->
None:
data_list = list()
for p in points:
data_list.append(f"[{p.x}, {p.y}, {p.z}]")
delimiter = ",\n"
print(f"[{delimiter.join(data_list)}]")
def print_residuals(points: list[
cvb.Point3D]) ->
None:
print("Residuals:")
print_point_3d_list(points)
def print_aqs12_points(points: list[
cvb.Point3D]) ->
None:
print("AQS12 points:")
def create_aqs12():
points = [
def check_accuracy(residuals, desired_accuracy):
for point in residuals:
if (abs(point.x) > desired_accuracy or
abs(point.y) > desired_accuracy or
abs(point.z) > desired_accuracy):
return False
return True
save = False
print("Estimation of an affine transformation (correcting an inclined laser "
"plane)")
print("Loading range map and calibration file.")
"tutorial", "Metric", "Images",
"RangeMapCalibrationPattern.tif")
print(f"Range map loaded with size of {range_map.width} x {range_map.height} "
f"from {range_map_file}.")
aqs12 = create_aqs12()
config.is_homography_calculated = False
"SICalibration.json")
calibrator.range_map_ignore_value = 0
range_map.planes[0], calibrator,
cvb.PointCloudFlags.Float)
print("Dense point cloud created from range map and calibration file "
f"with {cloud_intrinsic.num_points} points.")
cvb.foundation.SegmentationMethod.KmeansClustering)
print("Estimating affine transformation.")
transformation_, residuals_, transformation_parameters_ = \
cloud_intrinsic, segmentor, config)
calibrator.correction_of_laser_plane_inclination = \
transformation_, transformation_parameters_
if transformation_:
print_trafo(transformation_)
if transformation_parameters_:
print_trafo_parameters(transformation_parameters_)
desired_accuracy_ = 0.05
if residuals_:
print_residuals(residuals_)
if check_accuracy(residuals_, desired_accuracy_):
print("The calibration was successful and accuracy is < "
f"{desired_accuracy_} mm.")
cvb.PointCloudFlags.Float | cvb.PointCloudFlags.XYZConfidence)
if save:
calibrator_cloud.save("cloud.ply")
else:
print(
"Results do not have desired accuracy. Check face segmentation and "
"extracted AQS12 points...")
print("Extracting AQ12 faces on intrinsically calibrated point cloud.")
faces_aqs12 = segmentor.face_segmentation_from_piece(cloud_intrinsic)
if save:
faces_aqs12.save("AQS12faces.bmp")
print("Extracting AQ12 corner points on intrinsically calibrated "
"point cloud.")
points_aqs12 = segmentor.extract_projected_points_from_piece(
cloud_intrinsic)
print_aqs12_points(points_aqs12)
cvb.DensePointCloud create_dense(cvb.ImagePlane range_map, cvb.Calibrator3D calibrator, int flags)
cvb.foundation.AQS12DensePointCloudSegmentor create(int method)
cvb.foundation.CalibrationConfiguration create(cvb.foundation.AQS12Piece aqs12)
Tuple[cvb.AffineMatrix3D, Optional[List[cvb.Point3D]], Optional[cvb.AffineTransformationParameters]] calculate_correction_of_laser_plane_inclination_from_aqs12_piece(cvb.DensePointCloud cloud, cvb.foundation.AQS12DensePointCloudSegmentor segmentor, cvb.foundation.CalibrationConfiguration config, Optional[cvb.Rect] aoi=None)
