Image Manager/CVBpy/DeviceConfiguration
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/CVBpy/DeviceConfiguration.
device_configuration.py:
# @brief Example for device configuration.
# CVBpy Example Script
# 1. Loads a GenICam device.
# 2. Get the device node map.
# 3. Modify the exposure time node
# Requires: A connected and configured GenICam device
os.path.join(cvb.install_path(), "drivers", "GenICam.vin"),
cvb.AcquisitionStack.Vin)
dev_node_map = device.node_maps["Device"]
exposure_node = dev_node_map["ExposureTime"]
exposure_node.value = exposure_node.max / 2
print("Exposure time set to: " + str(exposure_node.value) + " " + exposure_node.unit)
with_bufferchange.py:
# CVBpy Example Script for 2nd generation acquisition stack
# 3. Modify the pixel format
# 4. Update the buffers
with cvb.DeviceFactory.open(devices[0].access_token, cvb.AcquisitionStack.Vin) as device:
stream = device.stream()
# do some acquisition
stream.abort()
nodes = device.node_maps["Device"]
pixel_format = nodes["Std::PixelFormat"]
pixel_format.value = "Mono10"
# update the CVB buffer according to the current device settings
stream.image_rect.update(cvb.DeviceUpdateMode.UpdateDeviceImage)
print("Pixel format set to: {}".format(pixel_format.value))
with_flowsetpool.py:
# CVBpy Example Script for 3rd generation acquisition stack
# to show the update of buffer due to changing a parameter
# which affects the buffer size.
# 1. Load a GenICam device.
stream.abort()
# update the flow_set_pool (buffers)
stream.deregister_flow_set_pool()
for i in range(10):
print("Acquired image: {0} | Timestamp: {1}".format(i, image.raw_timestamp))
stream.abort()
