Image Manager/CVBpy/MultiPart
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/CVBpy/MultiPart.
multi_part.py:
# @brief Example for acquiring multi part images.
# CVBpy Example Script for multi part image
# 1. Open the device with 3rd generation acq stack.
# 2. Get the composite stream
# 3. Acquire composites
# 4. Get the parts of a composite
# 5. Check the type of the part
# Requires: A connected and configured GenICam device which has multipart composites
stream = device.stream(cvb.CompositeStream)
for _ in range(10):
with composite:
for part in composite:
if isinstance(part, cvb.Image):
img: cvb.Image = part
print(f"Part of image is of type IMAGE: {img.width}x{img.height}")
# using this you can check for all the different types that could be in the composite
stream.abort()
