Image Manager/CVBpy/ImagePixelAccess
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/CVBpy/ImagePixelAccess.
image_pixel_access.py:
# @brief Example for accessing image pixel values.
# CVBpy Example Script
# 1. Loads an image from file.
# 2. Converts it to a numpy array without copying
# 3. Modify pixel values through numpy
# 4. Save the image.
# Requires: numpy
image = cvb.Image(os.path.join(cvb.install_path(), "tutorial", "Clara.bmp"))
# copy=Fasle is default, but just a request
np_array = cvb.as_array(image, copy=False)
if np_array.flags["OWNDATA"]:
# pixel access
print("Modifying pixel data via numpy array.")
np_array[83 : 108, 48 : 157] = 0
print("Saving: ./ClaraUnknown.bmp")
image.save("ClaraUnknown.bmp")
