CVB Python Example Programs
The CVB installation includes several standalone Python example programs that can be executed directly. These programs are installed under %CVB%Tutorial (Windows) or $CVB/tutorial (Linux) and can also be accessed from the list below:
Link to Example Program Description Location under %CVB%Tutorial
MetricCalibration Example for intrinsic and extrinsic calibration of a laser triangulation system using the AQS12 target. Foundation/CVBpy
MetricCalibrationInclinationLaserPlane Example for extrinsic calibration, including the correction of an inclined laser plane, in a laser triangulation system using the AQS12 target. Foundation/CVBpy
MetricCalibrationRigidBodyTransformation Example for a rigid-body transformation (extrinsic calibration) using the AQS12 target. Foundation/CVBpy
QmlBlobSearch This example shows the blob search of CVB Foundation package. Foundation/CVBpy
QmlGevServer The QmlGevServer example starts a QML GevServer which can load a device and stream the device image. GEVServer/CVBpy
BufferHandling Example for buffer handling. Image Manager/CVBpy
CompositeStreamHandler CVBpy Example Script for 3rd generation acquisition stack to demonstrate a basic usage of CompositeStreamHandler. Image Manager/CVBpy
CreateAndAccessCalibratedPointCloud Example for creating a calibrated point cloud from a range map and accessing point cloud values. Image Manager/CVBpy
DeviceConfiguration Example for device configuration. Image Manager/CVBpy
DiscoverDevices Example for discovering devices. Image Manager/CVBpy
ImageLoadSave Example for loading and saving images. Image Manager/CVBpy
ImagePixelAccess Example for accessing image pixel values. Image Manager/CVBpy
MultiPart Example for acquiring multi part images. Image Manager/CVBpy
MultiStream Example for acquiring multiple streams. Image Manager/CVBpy
PixelFormatConversion Example for converting PFNC compliant pixel formats. Image Manager/CVBpy
QmlGenDCDisplay Example for displaying GenDC data. Image Manager/CVBpy
QmlStreamDisplay Example for QML based streaming display. Image Manager/CVBpy
Rdma Example for RDMA for GEV acquisition. Image Manager/CVBpy
StreamingAsync Example for asynchronous streaming. Image Manager/CVBpy
StreamingParallel Example for parallel streaming. Image Manager/CVBpy
StreamingSimple Example for simple Image, PointCloud and Composite streaming. Image Manager/CVBpy
QmlMinos Example for OCR reading with Minos in QML environment. Minos/CVBpy
QmlCookieClassification Example for pattern classification using Polimago search in QML environment. Polimago/CVBpy
ShapeFinder Example for pattern recognition in 2D images using ShapeFinder. ShapeFinder/CVBpy
ColorConvert Example for normalizing and calculating Lab and sRGB images on hyperspectral cubes. Spectral/CVBpy
CodeReading Example, that demonstrates how to decode Data Matrix codes in an image. cvb_code_reader/CVBpy
Recording cvb_movie2/CVBpy
