Acquisition and Streaming
This document describes the newest 3rd Generation CVB acquisition stack using GenTL. If using an older acquisition stack using the VIN drivers, refer to the CVB 14.1 Documentation and Migrating from the 2nd Gen acquisition stack.
Once a device has been discovered per Device Discovery, acquisition is the process creating the data stream, and then retrieving the data from it.
Whilst the CVB interface is designed primarily for image streaming from a camera, there are no restrictions on the type of data sent and it is perfectly capable of receiving any binary data (e.g. text or metadata). For the purpose of this documentation, the term Device will be used for the sender side (camera, sensor, etc.), and the term Image used for the data payload (image, point cloud, binary data, etc.).
Acquisition in CVB
In CVB, acquisition begins by creating a Stream object of either Image Stream, Point Cloud Stream or Composite Stream. Once the stream has been created, it can be configured to use custom memory, before being started.
Acquisition can be started on each data stream individually using the Cvb::StreamBase::Start method. This will allocate the Cvb::FlowSetPool (see Flow Set Pool) if it has not been done already, and informs the device to begin streaming data on the chosen stream.
using namespace Cvb;
auto stream = device.Stream<ImageStream>(0);
stream.Start();
void Start() override
stream = device.stream(cvb.ImageStream, 0)
Stream Type
Inside CVB, all GenICam devices use a Cvb::CompositeStream for publishing data. In addition, CVB provides an Cvb::ImageStream and Cvb::PointCloudStream to simplify operations for common use cases. Which stream type to use depends on the device in question as well as what data needs to be processed.
Image Stream
The Cvb::ImageStream is a specialization of the Cvb::CompositeStream for usage with 1D or 2D images, allowing indexed access to pixel and subpixel data. It returns a Cvb::MultiPartImage that contains only image components of the stream.
When receiving only a single image, the Cvb::MultiPartImage will act as a Cvb::Image, allowing direct access to all image related data without requiring conversion.
WaitStatus status;
std::tie(image, status, nodeMaps) = stream->Wait();
// Access the image
auto pixelValue = image.GetPixel({x, y});
std::shared_ptr< MultiPartImage > MultiPartImagePtr
WaitStatus
WaitStatus status;
// Access the image
var pixelValue = image.GetPixel(x, y);
with image:
# Access the image
pixel_value = image.get_pixel(cvb.Point2D(x, y))
When receiving multiple images, the Cvb::MultiPartImage will also act as a container of images, allowing for indexed access to each image received. Accessing the Cvb::MultiPartImage as a Cvb::Image directly will access the information from the first image.
MultiPartImagePtr multiPartImage;
WaitStatus status;
std::tie(multiPartImage, status, nodeMaps) = stream->Wait();
// Access the first image
auto pixelValue1 = get<ImagePtr>(multiPartImage.GetPartAt(0))->GetPixel({x, y});
// Access the second image
auto pixelValue2 = get<ImagePtr>(multiPartImage.GetPartAt(1))->GetPixel({x, y});
WaitStatus status;
using (var multiPartImage = stream.Wait(out status))
var pixelValue1 = Image.FromHandle(multiPartImage.Parts[0].Handle).GetPixel(x, y);
var pixelValue2 = Image.FromHandle(multiPartImage.Parts[1].Handle).GetPixel(x, y);
__int3264 Image
multiPartImage, status, node_maps = stream.wait()
with image:
# Access the first image
pixel_value_1 = multiPartImage[0].get_pixel(cvb.Point2D(x, y))
# Access the second image
pixel_value_2 = multiPartImage[1].get_pixel(cvb.Point2D(x, y))
Converting Non-Displayable Images
If the camera streams a non-displayable image format, convert the acquired image after acquisition and before displaying it.
The following snippets show only the relevant steps for converting an acquired image. Device discovery, stream creation and display setup are omitted and are indicated by placeholders. The snippets assume that an image stream has already been opened and started. They show how to read the source PFNC format from the acquired image and convert it to a displayable format.
Potential source formats include monochrome formats such as Mono10, Mono10p, Mono12, Mono12p, Mono14 and Mono16, as well as Bayer formats such as BayerGB12.
Common displayable destination formats include Mono8, Mono16 and RGB8. Monochrome source images can be converted to Mono8 or Mono16, while Bayer source images can be converted to RGB8.
The source format is determined dynamically from the acquired image, including its bit depth, Bayer pattern and packing layout.
// Before, discover device and start stream
WaitStatus status;
if (status == WaitStatus::Ok)
auto pfncBuffer =
Cvb::HandleGuard<Cvb::BufferBase>(image.Handle()));
const auto sourceFormat =
static_cast<Cvb::PfncFormat>(
pfncBuffer->PFNCValue());
const auto destinationFormat =
Cvb::PfncFormat::Mono8;
const auto converter =
std::make_shared<PixelFormatConverter>(
sourceFormat,
destinationFormat);
auto displayImage =
image->Size(),
converter->DestinationFormat());
converter->Execute(
*image,
*displayImage);
// Display displayImage.
static std::unique_ptr< Image > FromPixelFormat(const Cvb::Size2D< int > &size, Cvb::PfncFormat format)
static PFNCBufferPtr FromHandle(HandleGuard< BufferBase > &&guard)
WaitStatus status;
if (status == WaitStatus.Ok)
using (var pfncBuffer =
image.Handle,
var sourceFormat =
pfncBuffer.PfncFormat;
var destinationFormat =
PfncFormat.Mono8;
using (var converter =
sourceFormat,
destinationFormat))
using (var displayImage =
Image.FromPixelFormat(
image.Size,
converter.DestinationFormat))
converter.Execute(
image,
displayImage);
static new PfncBuffer FromHandle(IntPtr handle, ShareObject doShare)
cvbbool_t ShareObject(OBJ Object)
# Before, discover device and start stream
pfnc_buffer = cvb.PFNCBuffer.from_object(image)
source_format = pfnc_buffer.pfnc_value
destination_format = cvb.PfncFormat.Mono8
source_format,
destination_format)
display_image = cvb.Image.from_pixel_format(
image.size,
converter.destination_format)
converter.execute(
image,
display_image)
# Display display_image.
cvb.Image from_pixel_format(cvb.Size2D size, int format)
cvb.PFNCBuffer from_object(Union[cvb.Image] obj)
When to Use an Image Stream
It is recommended to use the Cvb::ImageStream whenever possible to simplify access to 1D or 2D images, provided the following is true:
The data stream returns supported 1D or 2D Image PFNC Type (see Supported Image Formats) or only these need to be processed.
For most simple devices, this will always be true. In the case of a device sending complex payloads (e.g. mixed image and point cloud data) the Composite Stream is a better option.
Point Cloud Stream
The Cvb::PointCloudStream is a specialization of the Cvb::CompositeStream that delivers the data received from a 3D acquisition device in the form of a Cvb::PointCloud. This stream type allows an indexed access to the different parts of the point cloud data (typically coordinates in x, y and z; potentially also additional data like confidence, color, or normal vectors). When using Point Cloud Streams to acquire from devices that supply multi-part data, the stream will just provide the first point cloud encountered in the returned composite.
PointCloudPtr pointCloud;
WaitStatus status;
std::tie(pointCloud, status, nodeMaps) = stream->Wait();
// Access the point cloud
auto numPoints = pointCloud->NumPoints();
std::shared_ptr< PointCloud > PointCloudPtr
WaitStatus status;
using (var pointCloud = stream.Wait(out status))
auto numPoints = pointCloud.NumPoints;
point_cloud, status, node_maps = stream.wait()
with point_cloud:
# Access the point cloud
num_points = point_cloud.num_points
When to Use a Point Cloud Stream
It is recommended to use the Cvb::PointCloudStream whenever possible to simplify access to single and multipart images provided the following is true:
The data stream returns exactly one supported 3D Point Cloud PFNC Type (see Supported Image Formats).
The data stream does not contain any non-3D Point Cloud information.
Composite Stream
If device provides mixed data types that cannot be handled by the Cvb::ImageStream or the Cvb::PointCloudStream, the Cvb::CompositeStream stream type should be used. It allows for any combination of data types and buffers at the cost of increased coding complexity.
CompositePtr composite;
WaitStatus status;
std::tie(composite, status, nodeMaps) = stream->Wait();
for (int i = 0; i < composite->ItemCount(); i++)
auto component = composite->ItemAt(i);
if (auto image = get_if<ImagePtr>(&component))
// Process image
else if (auto pointCloud = get_if<PointCloudPtr>(&component))
// Process point cloud
WaitStatus status;
foreach (var part in composite)
if (part.GetType() == typeof(Image)) {
var image = Image.FromHandle(part.Handle, ShareObject.No);
// Process image
else if (part.GetType() == typeof(PointCloud)) {
var pointCloud = PointCloud.FromHandle(part.Handle, ShareObject.No);
static PointCloud FromHandle(IntPtr handle, ShareObject doShare)
with composite:
for part in composite:
if isinstance(part, cvb.Image):
# Process image
elif isinstance(part, cvb.PointCloud):
# Process point cloud
When to Use Composite Stream
A Cvb::CompositeStream is more complex than a Cvb::ImageStream or Cvb::PointCloudStream and should only be used if the latter are not sufficient.
The data stream sends mixed data types.
The data stream sends unsupported PFNC Types (see Supported Image Formats).
Anatomy of a CVB Stream
Each device is capable of publishing one or more GenICam stream(s) that can each contain one or more GenTL flow(s), each of which contains a single data payload. The CVB acquisition stack supports both multi-flow streams and multi-stream devices or a combination thereof.
Internally, the CVB acquisition engine maps each GenTL flow onto a buffer, termed the CVB Flow. When a frame is received, this collection of CVB Flows is returned as a CVB Flow Set in the form of a Cvb::Composite where each CVB Flow maps to one of the components (e.g. Cvb::MultiPartImage). How many CVB Flow Sets can be in use at the same time and the memory location of the CVB Flow objects is determined by the Cvb::FlowSetPool object.
Note: The details of the CVB Flow and CVB Flow Set are hidden from the user; CVB provides interfaces to allow access to the CVB Flow data in a convenient manner (see Stream Type).
Flow Set Pool
The Cvb::FlowSetPool is a CVB construct that contains the CVB Flow buffers required by the acquisition engine to receive data. It is up to the acquisition engine to determine when and what buffer to use for a given GenTL component. If all buffers are in use, the acquisition engine will drop the incoming data. The count of flow sets in a pool should be well balanced between the minimum required for not dropping frames (camera frame rate) and the maximum possible for host side parallel processing capacity or storage limits. Increasing the amount of buffers will allow for more buffering for fast producer - slow consumer setups at the cost of higher memory usage. Reducing the amount of buffers will reduce the memory usage at the risk of dropped data if the consumer is unable to keep up.
Buffer Metadata {#acq_buffer_metadata}
Buffers returned by an acquisition contain associated metadata that can be accessed through the VinBuffer node map.
The VinBuffer node map is returned through the node map enumerator associated with the acquired buffer and provides access to metadata that can be used to inspect acquisition results.
The information stored in the VinBuffer node map can be grouped into the following use cases:
  • Error Checking
  • Frame Identification
  • Payload Information
  • Advanced Buffer Handling
The following sections describe how the available nodes can be used to answer common questions about an acquired buffer.
Error Checking
When receiving an acquired buffer, a user application may need to verify whether the buffer was received completely and whether any packet loss occurred during acquisition.
The VinBuffer node map provides information that can be used to answer questions such as:
  • Is the buffer complete?
  • Was packet loss detected?
To determine whether the received buffer is complete, check the IsIncomplete node.
If the node returns true, the buffer is considered incomplete because an error occurred while it was being filled.
Otherwise, the buffer is not marked as incomplete.
To determine whether packet loss occurred during GigE Vision acquisition, check the NumPacketsMissing node.
A value greater than zero indicates that packets were lost during acquisition. A value of zero indicates that no packet loss was detected.
When receiving an acquired buffer, an application may need to determine when a frame was acquired and distinguish it from other frames.
  • When was this frame acquired?
  • Which frame is this?
Timestamp
To determine when the frame was acquired, check the Timestamp node.
The node represents a device-specific timestamp associated with the acquired buffer.
The timestamp is relative to a device-specific time base and should not be interpreted as an absolute date or time.
The interpretation of the timestamp value depends on the producer and payload format.
When working with GenDC payloads, the value returned by Timestamp may depend on the component selected through GenDCComponentSelector.
FrameID
To identify the frame associated with the buffer, check the FrameID node.
The node provides a sequential identifier assigned to each acquired frame.
Depending on the transport technology, this value may correspond to the GigE Vision Block ID, the USB3 Vision Block ID, or the GenDC Container Identifier.
The frame ID can be used to distinguish one frame from another or correlate buffers with acquisition events.
Payload Information
When processing an acquired buffer, a user application may need to determine the payload type and understand how the payload data is organized.
  • What type of payload does this buffer contain?
  • What is the image size?
  • Does the payload contain chunk data?
To identify the payload type contained in the buffer, check the BufferPayloadType node.
The node indicates the type of payload contained in the buffer.
To determine the image size, check the Width node and/or the Height node.
The Width node represents the number of pixels in each image line, while the Height node represents the number of image lines in the image.
To identify whether the buffer contains GenICam chunk data, check the ContainsChunk node.
If the node returns true, the buffer contains GenICam chunk data. Otherwise, no chunk data is present.
In some advanced use cases, an application may also need to answer questions such as:
  • How much padding is present in the buffer?
To determine how much padding is present in the buffer, check the XPadding and YPadding nodes.
In some cases, image data may contain padding bytes that are not part of the image content.
The XPadding node represents the horizontal padding expressed in bytes, while the YPadding node represents the vertical padding expressed in bytes.
In some advanced applications, acquired buffers may be represented as composite buffers, which consist of multiple non-contiguous memory segments.
Composite buffers may be used with structured payload formats such as GenDC.
Handling Composite Buffers
  • Is this a composite buffer?
To determine whether the buffer was announced as a composite buffer, check the IsComposite node.
If the node returns true, the buffer was announced as a composite buffer. Otherwise, the buffer was announced as a regular contiguous buffer.
Handling GenDC Components
  • Which GenDC component is selected?
  • Is the selected component valid?
A GenDC container may contain one or more components.
To select the component used by subsequent component-related nodes, use the GenDCComponentSelector node.
Write the index of the component to the node. The available component indices can be queried from the node.
Depending on the acquisition result, a component may be marked as invalid. To determine whether the selected component is invalid, check the IsComponentInvalid node.
If the node returns true, the selected component is invalid. Otherwise, the selected component is valid.
Image lifetime {#acq_buffer_lifetime}
The CVB acquisition stack manages the lifetime of all image buffers automatically using a reference counting mechanism. This allows the acquisition engine to clear an image buffer when it is no longer being used and requeue it for a future acquisition cycles.
sequenceDiagram participant UserCode as User Code participant AcquisitionEngine as CVB Acquisition Engine participant FlowSetPool as CVB Flow Set Pool UserCode ->> AcquisitionEngine: Call Cvb::Stream::Wait AcquisitionEngine ->> FlowSetPool: Get Free FlowSet FlowSetPool -->> AcquisitionEngine: Return FlowSet Activate FlowSetPool AcquisitionEngine ->> AcquisitionEngine: Fill FlowSet Buffers from Driver Note right of FlowSetPool: FlowSet not available for reuse AcquisitionEngine ->> UserCode: Return FlowSet data as CVB Composite UserCode ->> UserCode: Process CVB Composite UserCode -->> AcquisitionEngine: Release CVB Composite AcquisitionEngine ->> FlowSetPool: Mark FlowSet As Free Deactivate FlowSetPool
For the purposes of the reference counting mechanism, the returned Cvb::MultiPartImage/Cvb::PointCloud/Cvb::Composite and Cvb::NodeMapEnumerator are considered part of the same buffer. As long as they or any derived items remain in scope, the while buffer will be marked as in use and cannot be used for a future acquisition cycle.
There are a few things to consider when working with CVB to avoid unexpected problems:
  • Keep the Cvb::MultiPartImagePtr, Cvb::CompositePtr or Cvb::PointCloudPtr in scope until it is no longer required. Otherwise, the acquisition engine will clear the buffer and the image will be unrecoverable.
    • In .NET, the image and node map enumerator implement the IDisposable interface and should be used in combination with a using statement to ensure correct object cleanup.
    • In Python, the image and node map enumerator implement a Context Manager and should be used in combination with a with statement to ensure correct object cleanup.
  • If the image needs to be saved for processing that cannot be done in a single acquisition cycle, the image should be copied to another memory location. This will allow the acquisition engine to requeue the buffer and avoid frame drops when all buffers are unable to be freed.
Cancellation
The Cvb::CancellationToken gives the possibility to cancel individual wait calls instead of the whole acquisition. Restarting the whole acquisition takes much longer, than to simply call wait functions again. A use case for example would be if an external stop signal is received by the application, the fastest reaction to stop the acquisition and to restart it, would be to abort the wait function with a cancellation token. The token itself can be checked if it has been canceled. In addition, on cancellation, the returned Cvb::WaitStatus will have a value of Cvb::WaitStatus::Abort.
When using a cancellation token, the following rules should be observed:
  • The cancellation of the acquisition may not occur immediately and if an image is received before the cancellation is processed, a race condition may occur, and the cancellation may not be seen. It is recommended to check the cancellation token even if an image has been received to properly act on it.
  • If multiple waits are cancelled at the same time through a single token, they may finish in a random order.
Event Interface
The INotify interface enables notification of application for asynchronous driver events. It allows for the registration of user defined callbacks for asynchronous driver events. All currently supported events can be found at Cvb::DeviceState.
When using it the following rules apply:
  • The thread context from which the callback is issued might vary between events and is not necessarily the main application process. It is driver (implementation) dependent whether callbacks are fired in parallel from multiple threads or sequentially from within the same thread context. Even though it is likely that a single callback registered on a single EventID on a single device is not called from multiple threads in parallel, it still valid. Therefore it is the caller's responsibility to ensure that the execution context of the registered notification is correct.
  • Multiple callbacks can be registered to a single event. They will be executed in a random order.
  • The callbacks are called from the thread context issuing the event. The execution time spent in the callback will possibly (depending on the event) affect image acquisition timing or driver behavior in general. It is recommended to return from a notification as quickly as possible.
  • In order to avoid deadlocks it is not recommended to call driver functions from within a callback.
Examples
Example Description
Single Stream Simple acquisition of a single stream.
Multiple Streams Acquisition of a device sending multiple data streams.
Multiple Components Acquisition of a device sending a single data stream containing multiple components.
Resizing the Flow Set Pool Customizing the Cvb::FlowSetPool before acquisition.
Using External Memory Using a custom Cvb::FlowSetPool for acquisition.
Cancelling Acquisition Using a Cvb::CancellationToken to stop an ongoing acquisition.
Using Event Callbacks Using a the Cvb::NotifyObservable interface to handle event callbacks.
Point Cloud Acquisition (C++) Acquiring point clouds coming along with additional data like RGB images.
Further Reading
Getting started with C++
Getting started with .NET
Getting started with Python
CVB Image Data Handling
Pixel Format Conversion - PFNC Formats and Bayer Conversion
Analyze your Composite in C++, .NET and Python
Details about GenDC. Access to Composites
Access to Simple Point Clouds
VinDevice and VinBuffer Nodemaps
