The CVB Python wrapper allows you to seamlessly integrate Common Vision Blox functionality into your Python applications. It provides easy access to image acquisition, processing, and device management features, making it ideal for rapid prototyping and automation in machine vision projects.
To ensure long-term reliability and compatibility, CVB is built on a stable and well-defined core interface:
The CVB C-API maintains a stable application binary interface (ABI), ensuring that applications built against a specific version continue to work with newer CVB versions without requiring recompilation, as long as the interface contract remains unchanged.
Before you begin, the following requirements are met:
python -m pip install numpypython -m pip install pyside6 (optional, only needed if you want to use Qt/QML for image display)The CVB Python wrappers can be installed using pip. Running the install script also sets up code completion for your IDE (e.g., Visual Studio Code). The Python wheel is included with your CVB installation at %CVB%%/Lib/Python (Windows) or /opt/cvb/python (Linux).
Install command on Windows:
and on Linux:
python -m pip uninstall cvb.For users of Anaconda, additional information is available in the following CVB User Forum post: Getting Started with CVBPy.
The CVB Python wrapper is located in your CVB installation directory under %CVB%\Lib\Python\cvb. All classes and functions are part of the cvb module. Additional modules and classes are used for specific functionality.
To use the wrapper, simply import the corresponding cvb module and call its functions as shown below:
Proper management of object lifetimes is essential when working with resource-intensive entities. We recommend using Python’s with statement for objects that manage critical resources — such as devices and images — to guarantee timely and safe release of those resources.
Python does not treat enums as a distinct type like C/C++. However, since the CVB low-level API makes extensive use of enums, CVBpy provides equivalent representations using global classes. These classes contain static, read-only integer properties that correspond to the original enum values.
CVBpy automatically performs implicit conversions between int and float where appropriate. When a floating-point value is converted to an integer, the value is rounded mathematically. If the conversion would result in overflow or is otherwise undefined, the result is unspecified and may or may not raise an error.
To display images with CVB, you can use the Qt framework. For more details, refer to Python - Image Display Using Qt/QML.
Python Example Programs in CVB Installation
Code Examples
Python API Documentation
