GigEVision (Gigabit Ethernet Vision) is a machine vision technology standard for discovering, controlling and streaming Ethernet vision devices. Hosted by A3, it offers fast, abundant, standardized, scalable and low-cost streaming over Ethernet. The A3 page is the right place to look for all standard related material (documents, applications, legal topics).
CVB implements most of the available aspects of GEV. The standard defines three major regards of Ethernet based vision, which are represented as follows:
The GEV stack - from a technical perspective - comes in three different forms, where each serves a different purpose and use case.
On top of all flavors of GEV streaming in CVB there is a common interface, that fulfills the GenTL (transport layer) and GEV specifications. GevSD in its standard configuration is the most basic implementation that uses the OS networking stack and - compared to the others - offers the least performance. The RDMA configuration in the GevSD uses direct memory access and brings significant improvements in performance by leveraging hardware offloading. For Windows there is a specific kernel driver called GevFD that skips part of the OS networking stack, offering a performance speedup when compared to the standard GevSD.
The following table helps to find the right driver for an application:
| Topic | GevSD (RDMA) | GevSD (GVSP) | GevFD (GVSP) |
| GEV Implementation | Uses direct NIC access | Uses OS for GVSP transfer | Uses packet filtering and bypasses OS kernel stack |
| Data Rate | Highest (bypasses OS networking stack) | Medium (limited by UDP stack and OS overhead) | Higher (through kernel driver) |
| Latency | Lowest (direct memory access to NIC) | Moderate (UDP introduces some jitter) | Moderate (depends on filtering efficiency) |
| CPU Load | Very Low (offloaded to NIC hardware) | High (software-based packet processing) | Medium (kernel driver offloads some processing) |
| Firewall Interaction | Not affected (direct NIC access) | Needs open UDP ports | Bypasses firewall via kernel driver |
| Reliability | Highest (guaranteed memory transfers) | Moderate (UDP may drop packets, resends take resources) | High (for higher data rates controlled packet filtering, fast resends) |
| Use Case | High-speed, low-latency applications | Vision systems using standard GVSP, no dedicated hardware | Systems needing controlled firewall bypassing on Windows |
| OS Compatibility | Any | Any | Windows only |
| Hardware Requirement | RDMA capable NIC and Camera | Any | Any |
One of the major benefits of GEV is its capability regarding setting up different network topologies. They are - as usual in IP networks - configured by subnet masks and IP addresses of the different participants:
This is the most straight forward case, where no other components are involved and the camera is setup as a simple point to point connection. IP addresses are either assigned by DHCP or manually. This results in the most performant setup, as there is the full bandwidth available for GVSP.
In order to build up more complex setups, switches can help stacking networks and enable one-to-N or N-to-M (participants) connections, for cameras and hosts. This requires compatibility and configuration in the switch.
As soon as there are multiple network interfaces involved, the traffic needs to be distributed by subnets. A careful configuration of subnets per NIC ensures the correct behavior. Compared to the multiple camera setup on one NIC, this enhances performance as the load is balanced.
The overall performance of a GEV system setup depends on the network hardware components (network interface card, switch, camera, cable) as well as their appropriate configuration. Additionally, there are some camera dependent GigE network features.
To establish a connection to any GEV device, both the NIC and the GEV device must have a valid IP in the same subnet range. Addresses can be assigned both dynamically and statically.
Static addresses guarantee the expected IP assignment for all network participants. This is available in two different forms:
The devices within the network with DHCP enabled get their addresses from the server. GEV devices try to inquire an address over DHCP by default. Dynamically assigned addresses are random and can vary over connections.
If there is no DHCP server present, the LLA (link local address) method is used. The NIC automatically assigns an IP address in the 169.254.X.Y subnet range.
There are configuration properties which influence the performance of the system and the stability of the data transfer over the network card. The settings depend on the used operating system, the NIC should be optimized with respect to the corresponding vendors best practice. Refer to the manufacturers manual for specifics.
Sets the number of buffers used by the driver when copying data to the protocol memory. Increasing this value can enhance the receive performance, but also consumes system memory.
Sets the Interrupt Throttle Rate (ITR), the rate at which the controller moderates interrupts. The default setting is optimized for common configurations. Changing this setting can improve network performance on certain network and system configurations. When you use a higher ITR setting, the result is better system performance.
Sets the capability. If large packets make up the majority of traffic and more latency can be tolerated, Jumbo Frames can reduce CPU utilization and improve transmission efficiency. Jumbo frames have a strong impact on the performance of the GEV system. Jumbo frames are packages with more than the Ethernet MTU (Maximum Transmission Unit) of 1500 bytes.
When activated in the network card this does not mean that Jumbo Frames are used. The changes take effect when also adjusting the packet size within the device. 9174 Bytes is recommended if supported by camera and network card.
Firewalls can block GEV packets and slow down the system performance. Therefore it is important to disable all firewalls within the camera connection setup if there are connection problems. This can also be handled via Firewall incoming/outgoing rules.
Inter Packet Delay is a parameter to control the data rate from cameras in multi-device setups. With IPD, cameras can be slowed down by adding delays between the sent packets. This can help balancing network traffic between multiple devices. The specific delay values have to be tuned depending on the network capacity, the devices configuration and the data rates.
Packet resend can be used (when supported) to request the retransmission of packets that have been lost. In high data rate scenarios and due to the use of UDP this can cause corrupted frames. In order to get those lost frames, GEV implements an asynchronous resend mechanism.
To enable RDMA on supported devices, the driver needs to be advised to do so. For further information on RDMA, see this page
The GEV standard offers a dedicated way to handle special devices. In the context of CVB they are hidden to the user, but for completeness their support may be mentioned here:
The GEV specific container format offers a way to pack various payload types into one container. In CVB, those Multipart payloads are represented in Cvb::Composites parts.
In certain scenarios camera vendors offer devices with not only one but multiple image streams in parallel. This is often the case if there are two independent signals acquired, simultaneously. In CVB the streams can be selected as follows:
Discovering a GEV Device
Setting device IPs
Getting started with RDMA
