Device Discovery - Gig-E Vision
Discovering Gig-E Vision (GEV) devices can be done using the Cvb::DeviceFactory::Discover.
In the case that multiple devices using different Transport Layers are connected (e.g. USBTL and GEVTL), no filtering flags can be applied during the discovery process to select a specific transport layer. Instead, after discovery, the Cvb::DiscoveryProperties in the Cvb::DiscoveryInformation should be accessed to determine the transport layer used and filter appropriately.
auto discoveredDevices = Cvb::DeviceFactory::Discover(Cvb::DiscoverFlags::IgnoreVins); // (1)
auto chosenDiscoveryInformation = std::find_if(discoveredDevices.begin(), discoveredDevices.end(),
[](auto discoveryInformation) {
return discoveryInformation[Cvb::DiscoveryProperties::DeviceTransportLayerType] == "GEV"; // (2)
auto device = Cvb::DeviceFactory::Open<Cvb::GenICamDevice>(chosenDiscoveryInformation->AccessToken(), Cvb::AcquisitionStack::PreferGenTL); // (3)
// Configure device
// Start acquisition and streaming
using (var discoveredDevices = DeviceFactory.Discover(DiscoverFlags.IgnoreVins)) // (1)
var chosenDiscoveryInformation = discoveredDevices.First(discoveryInformation => {
return discoveryInformation[DiscoveryProperties.DeviceTransportLayerType] == "GEV"; // (2)
using (var device = (GenICamDevice)DeviceFactory.Open(chosenDiscoveryInformation, AcquisitionStack.PreferGenTL)) // (3)
// Configure device
discoveredDevices = cvb.DeviceFactory.discover_from_root(cvb.DiscoverFlags.IgnoreVins) # (1)
chosenDiscoveryInformation = next(filter(lambda discoveryInformation: discoveryInformation.read_property(cvb.DiscoveryProperties.DeviceTransportLayerType) == "GEV", discoveredDevices)) # (2)
with cvb.DeviceFactory.open(chosenDiscoveryInformation.access_token, cvb.AcquisitionStack.PreferGenTL) as device: # (3)
# Configure device
# Start acquisition and streaming
  1. Discover all GenTL devices. By default all devices are discovered so by using the Cvb::DiscoverFlags::IgnoreVins flag, the legacy VIN drivers are excluded.
  2. Filter the found discovery information to use the first that uses the GEVTL driver.
    Common options are:
    • Mixed - Several supported technologies
    • Custom - Custom technologies
    • GEV - GigE Vision technology
    • CL - Camera Link technology
    • IIDC - IIDC 1394 technology
    • UVC - USB video class devices
    • CXP - CoaXPress
    • CLHS - Camera Link HS
    • USB3 - USB3 Vision Standard
    • Ethernet - Ethernet devices
    • PCI - PCI/PCIe devices
  3. Open the device as a Cvb::GenICamDevice using Cvb::AcquisitionStack::PreferGenTL. When using GEVTL, these flags are mandatory to ensure that all GenICam features are enabled.
