Image Manager/Cvb++/CppPointCloudAcquisition
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/Cvb++/CppPointCloudAcquisition.
// Acquire point cloud data and write it to a file. This tutorial assumes that the device is sending
// mulit part data containing a point cloud, a confidence plane and an RGB8 image containing the color
// of each pixel.
#include <fstream>
#include <string>
#include <vector>
#include <cvb/composite.hpp>
#include <cvb/driver/multi_part_image.hpp>
#include <cvb/plane_enumerator.hpp>
#include <cvb/utilities/utilities.hpp>
const constexpr auto numElemsToAcquire = 10;
auto infoList =
if (infoList.empty()) {
std::cout << "Discovered" << std::endl;
throw std::runtime_error(
// Attention: even if you have connected such a device it is not necessarily
// found first. You may want to filter here.
// Maybe adjust some values
// auto nodeMap = device->NodeMap(CVB_LIT("Device"));
// auto settingNodes = nodeMap->Node<Cvb::FloatNode>(CVB_LIT("Aperture"));
// settingNodes->SetValue(5.66f);
// auto exposureTime =
// nodeMap->Node<Cvb::IntegerNode>(CVB_LIT("Cust::ExposureTime"));
// exposureTime->SetValue(40000);
const auto numStreams = device->StreamCount();
// We know the device is streaming point clouds including neighborhood
// information. So we can directly acquire dense point clouds.
auto stream = device->Stream<Cvb::PointCloudStream>(0);
stream->Start();
for (auto i = 0; i < numElemsToAcquire; i++) {
auto [pointCloud, waitStatus, enumerator] =
stream->Wait<Cvb::DensePointCloud>();
if (waitStatus != Cvb::WaitStatus::Ok) {
std::cout << "wait status not ok: " << static_cast<int>(waitStatus)
<< std::endl;
// Here we've got the point cloud (xyz), but there is more in the buffer
// as a multi part buffer is a composition of different parts. You can
// access these parts through a composite, which is basically just another
// view on the point cloud.
auto composite = Cvb::Composite::FromObject(pointCloud);
if (composite->Purpose() == Cvb::CompositePurpose::PointCloud) {
const auto numberOfElements = composite->ItemCount();
std::cout << "Found " << numberOfElements << " point cloud parts"
<< std::endl;
// check if the format is as expected.
auto xyz = Cvb::get<Cvb::PlaneEnumeratorPtr>(composite->ItemAt(0));
if (!xyz) {
std::cout << "Composite xyz is not a plane enumerator" << std::endl;
if (!Cvb::holds_alternative<Cvb::PlanePtr>(composite->ItemAt(1))) {
std::cout << "Composite confidence is not a plane" << std::endl;
if (!Cvb::holds_alternative<Cvb::ImagePtr>(composite->ItemAt(2))) {
std::cout << "Composite image is not an image" << std::endl;
// Note: that items in composite are not automatically associated with
// each other. E.g. the image inside a composite could refer to a
// totally different sensor. As there is no standard way to communicate
// the relation between individual parts, you have to create this
// association with your a priori knowledge. This can be done by adding
// planes with specific roles to the composite/point cloud. Be aware
// that no data is copied.
// Get the RGB planes from the image.
// This is necessary because an image plane supports more memory layouts
// than a plane. For modern acquisition devices they are usually
// compatible.
auto rgbImage = Cvb::get<Cvb::ImagePtr>(composite->ItemAt(2));
auto rPlane = Cvb::Plane::FromImagePlane(rgbImage->Plane(0),
Cvb::PlaneRole::PixRGB_R);
auto gPlane = Cvb::Plane::FromImagePlane(rgbImage->Plane(1),
Cvb::PlaneRole::PixRGB_G);
auto bPlane = Cvb::Plane::FromImagePlane(rgbImage->Plane(2),
Cvb::PlaneRole::PixRGB_B);
// Add them at the end
composite->InsertItemAt(composite->ItemCount(), rPlane);
composite->InsertItemAt(composite->ItemCount(), gPlane);
composite->InsertItemAt(composite->ItemCount(), bPlane);
// remember the point cloud and the composite are the same thing
pointCloud->Save("xyzrgb.pcd");
// Note: when you load it again the image is gone, but XYZ and RGB
// planes can be restored!
} else {
std::cout << "The composite contains something unexpected" << std::endl;
stream->Stop();
static CompositePtr FromObject(std::shared_ptr< T > object)
void Start() override
static PlanePtr FromImagePlane(const ImagePlane &imagePlane, PlaneRole role=PlaneRole::Undefined)
