This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/CVBpy/DeviceConfiguration.
device_configuration.py:
cvb.AcquisitionStack.Vin)
dev_node_map = device.node_maps["Device"]
exposure_node = dev_node_map["ExposureTime"]
exposure_node.value = exposure_node.max / 2
print("Exposure time set to: " + str(exposure_node.value) + " " + exposure_node.unit)
with_bufferchange.py:
stream = device.stream()
stream.abort()
nodes = device.node_maps["Device"]
pixel_format = nodes["Std::PixelFormat"]
pixel_format.value = "Mono10"
stream.image_rect.update(cvb.DeviceUpdateMode.UpdateDeviceImage)
print("Pixel format set to: {}".format(pixel_format.value))
with_flowsetpool.py:
stream.abort()
stream.deregister_flow_set_pool()
for i in range(10):
print("Acquired image: {0} | Timestamp: {1}".format(i, image.raw_timestamp))
stream.abort()
