Image Manager/CVBpy/QmlStreamDisplay
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/CVBpy/QmlStreamDisplay.
display.py:
# @brief Example for QML based streaming display.
import os, sys
import cvb.ui
from PySide6.QtCore import QObject, QUrl
from PySide6.QtQml import qmlRegisterType
from PySide6.QtWidgets import QApplication, QWidget
from PySide6.QtQuick import QQuickView, QQuickPaintedItem
else:
from PySide2.QtCore import QObject, QUrl
from PySide2.QtQml import qmlRegisterType
from PySide2.QtWidgets import QApplication, QWidget
from PySide2.QtQuick import QQuickView, QQuickPaintedItem
if __name__ == "__main__":
app = QApplication([])
app.setApplicationName('Display Python tutorial')
if sys.platform == 'win32':
import ctypes
myappid = u'stemmerimaging.commonvisionblox.pystreamdisplay.0'
script_dir = os.path.dirname(os.path.realpath(__file__))
icon_path = os.path.join(script_dir, 'Tutorial-Python_32x32.png')
app.setWindowIcon(QIcon(icon_path))
# load the device
cvb.AcquisitionStack.Vin)
# use a single stream handler to setup an acquisition thread and acquire images
handler = cvb.SingleStreamHandler(device.stream())
# create an image controller to interact with the UI
# register the display component with QML
# setup the QML UI
view = QQuickView()
view.setResizeMode(QQuickView.SizeRootObjectToView)
context = view.rootContext()
filepath = os.path.dirname(os.path.realpath(__file__))
view.setSource(QUrl.fromLocalFile(os.path.join(filepath,"main.qml")))
view.resize(640, 480)
view.show()
# register the device image with UI controller to trigger automatic refreshes
image_controller.refresh(device.device_image, cvb.ui.AutoRefresh.On)
# start the acquisition thread
handler.run()
# start the UI event handler
app.exec_()
# stop the acquisition after UI exits
handler.try_finish()
