GEVServer/CVBpy/QmlGevServer
This example program is located in your CVB installation under %CVB%Tutorial/GEVServer/CVBpy/QmlGevServer.
QmlGevServer.py:
# @brief The QmlGevServer example starts a QML GevServer which can load a device
# and stream the device image.
import os, sys
import cvb.gevserver as gs
import cvb.ui
from PySide6.QtWidgets import QApplication
from PySide6.QtQuick import QQuickView
from PySide6.QtCore import QObject, Signal, Slot, Property, QUrl
else:
from PySide2.QtWidgets import QApplication
from PySide2.QtQuick import QQuickView
from PySide2.QtCore import QObject, Signal, Slot, Property, QUrl
class StreamProcessingHandler(cvb.SingleStreamHandler):
def __init__(self, stream):
super().__init__(stream)
def handle_async_wait_result(self, image, status):
if status is cvb.WaitStatus.Ok:
print("New image arrived")
# display image or
if BackEnd.grab_image or BackEnd.single_shot:
BackEnd.single_shot = False
BackEnd.image_controller.refresh(image)
if BackEnd.has_ring_buffer:
image.unlock()
# send image
elif BackEnd.server_started and (not BackEnd.server_single_shot_send_enabled or BackEnd.server_single_shot_send) and BackEnd.server.stream.is_running:
try:
print('Sending image')
BackEnd.server_single_shot_send = False
BackEnd.buffer_index = image.buffer_index
BackEnd.img_list[image.buffer_index] = image
def image_release(img):
img.unlock()
BackEnd.img_list[BackEnd.buffer_index].unlock()
print('Unlocked buffer at index ' + str(img.buffer_index))
BackEnd.server.stream.send(image, image_release)
BackEnd.image_controller.refresh(BackEnd.img_list[BackEnd.buffer_index])
else:
BackEnd.server.stream.send(image)
except:
print('Failed to send image')
elif BackEnd.has_ring_buffer:
print("Unlock unused image")
image.unlock()
class BackEnd(QObject):
connection_list_changed = Signal()
server_started = False
server_single_shot_send_enabled = False
single_shot = False
server = None
grab_image = False
has_ring_buffer = False
img_list = list()
buffer_index = 0
# create an image controller to interact with the UI
def __init__(self):
QObject.__init__(self)
self.start_in_progress = False
self.window_state_reg_node = None
self.event_cookie = None
# load the device
self.device = cvb.DeviceFactory.open(
os.path.join(cvb.install_path(), 'drivers', 'CVMock.vin'),
cvb.AcquisitionStack.Vin)
self.stream = self.device.stream()
BackEnd.has_ring_buffer = bool(self.stream.ring_buffer)
self.stream.ring_buffer.lock_mode = cvb.RingBufferLockMode.On
BackEnd.img_list = [None] * self.stream.ring_buffer.count
# use a single stream handler to setup an acquisition thread and acquire images
self.handler = StreamProcessingHandler(self.stream)
self.view = view
self.view.rootContext().setContextProperty('mainImage', BackEnd.image_controller)
# register the device image with UI controller to trigger automatic refreshes
self.stream.get_snapshot()
BackEnd.image_controller.refresh(self.device.device_image)
self.handler.run()
# fill combo box with all available connections
self.connections = gs.LogicalNetworkInterface.get_all_available()
self.m_connection_list = list()
for connection in self.connections:
self.m_connection_list.append(connection.ip_address() + ' (' + connection.ipv4_mask() + ')')
self.connection_list_changed.emit()
def __enter__(self):
return self
def __exit__(self, exc_type, exc_val, exc_tb):
if self.handler.is_active:
self.handler.finish()
if BackEnd.server:
BackEnd.server = None
@Property('QVariantList', notify=connection_list_changed)
def connection_list(self):
return self.m_connection_list
@Property('QUrl')
def driver_path(self):
return QUrl.fromLocalFile(cvb.expand_path('%CVB%drivers'))
@Property('QUrl')
def desktop_path(self):
return QUrl.fromLocalFile(os.path.expanduser("~/Desktop"))
@Slot(bool)
def switch_grab(self, switched):
if switched and not self.handler.is_active:
self.handler.run()
BackEnd.grab_image = switched
def reset_ui(self):
print("Resetting ui")
if BackEnd.grab_image:
print('Resetting grab switch')
BackEnd.grab_image = False
switch = self.view.findChild(QObject, 'switchGrab')
switch.setProperty('checked', False)
def stop_grab(self):
print('Stopping grab')
self.reset_ui()
if self.stream.is_running:
self.handler.try_finish()
print('Grab stopped')
@Slot(str)
def load_device(self, path):
print('Loading device from ' + path)
self.stop_grab()
try:
tmp_device = cvb.DeviceFactory.open(path, cvb.AcquisitionStack.Vin)
self.device = tmp_device
self.handler.run()
except:
print('Failed to load new device')
@Slot(str)
def save_image(self, path):
print('Saving image to ' + path)
self.device.device_image.save(path)
@Slot()
def btn_single_shot(self):
print('Single Shot')
self.reset_ui()
if not self.handler.is_active:
self.handler.run()
BackEnd.single_shot = True
@Slot(bool)
def switch_enable_single_shot_send(self, enabled):
BackEnd.server_single_shot_send_enabled = enabled
@Slot()
def btn_single_shot_send(self):
if BackEnd.server.stream.is_running:
print('Send single shot')
BackEnd.server_single_shot_send = True
else:
print('Acquisition not enabled on server')
@Slot(int, int)
def start_server(self, connection_index, driver_type_index):
print('connection_index', connection_index, 'driver_type_index', driver_type_index)
# check for recursions
if self.start_in_progress:
return
self.start_in_progress = True
try:
if BackEnd.server_started is False:
self.reset_ui()
# create server
BackEnd.server = gs.Server.create_with_const_size(self.device.device_image.size,
self.device.device_image.color_model,
self.device.device_image.planes[0].data_type,
driver_type_index)
self.add_genicam_features()
BackEnd.server.user_version = 'Python GevServer'
BackEnd.server.node_map.xml_file_version = cvb.GenApiVersion(1, 0, 0)
if(BackEnd.has_ring_buffer):
BackEnd.server.stream.resend_buffers_count = 2
else:
BackEnd.server.stream.resend_buffers_count = 0
# start server
BackEnd.server.start(self.connections[connection_index].ip_address())
# start acquisition
BackEnd.server_started = True
print('Started server')
else:
BackEnd.server.stop()
BackEnd.server_started = False
print('Server stopped')
except:
print('Failed to start/stop the server')
def on_window_size_changed(self, valueNode):
print('Window size change callback called')
val = self.window_state_reg_node.value
if val == 0:
self.view.showMinimized()
elif val == 1:
self.view.showNormal()
elif val == 2:
view.showMaximized()
def add_genicam_features(self):
cat_node = gs.CategoryNode.create('Cust::CustomFeatures')
BackEnd.server.node_map.add_node(cat_node)
cat_node.display_name = 'Custom Features'
cat_node.tool_tip = 'Contains all application defined features'
root_node = BackEnd.server.node_map['Root']
root_node.add(cat_node, gs.NodeList.Child)
self.window_state_reg_node = gs.Int32RegNode.create('Cust::WindowStateReg')
BackEnd.server.node_map.add_node(self.window_state_reg_node)
self.window_state_reg_node.visibility = cvb.Visibility.Invisible
# no cache because of polling
self.window_state_reg_node.cache_mode = cvb.CacheMode.NoCache
# polling time in ms
self.window_state_reg_node.polling_time = 333
self.window_state_reg_node.value = 1 # view in normal mode
self.event_cookie = self.window_state_reg_node.register_event_written_updated(self.on_window_size_changed)
enumeration_node = gs.EnumerationNode.create('Cust::WindowState')
BackEnd.server.node_map.add_node(enumeration_node)
enumeration_node.display_name = 'Window State'
enumeration_node.tool_tip = 'Current window state of server application'
enumeration_node.value_config_as_node = self.window_state_reg_node
minimized_node = gs.EnumEntryNode.create('Cust::Minimized')
minimized_node.numeric_value = 0
enumeration_node.add(minimized_node, gs.NodeList.Child)
normal_node = gs.EnumEntryNode.create('Cust::Normal')
normal_node.numeric_value = 1 # must be ascending entry
enumeration_node.add(normal_node, gs.NodeList.Child)
max_node = gs.EnumEntryNode.create('Cust::Maximized')
max_node.numeric_value = 2
enumeration_node.add(max_node, gs.NodeList.Child)
cat_node.add(enumeration_node, gs.NodeList.Child)
if __name__ == '__main__':
sys.argv += ['--style', 'Windows']
app = QApplication(sys.argv)
app.setApplicationName('GevServer Python tutorial')
if sys.platform == 'win32':
import ctypes
myappid = u'stemmerimaging.commonvisionblox.pygevserver.0'
# register the display component with QML
# setup the QML UI
view = QQuickView()
view.setResizeMode(QQuickView.SizeRootObjectToView)
# create backend object
with BackEnd() as backEnd:
# register it to the context of QML
view.rootContext().setContextProperty('backEnd', backEnd)
# load the qml file into the engine
view.setSource(QUrl('main.qml'))
# call single shot to update the UI
backEnd.btn_single_shot()
view.resize(640, 390)
view.show()
# start the UI event handler
app.exec_()
str expand_path(str path)
