This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/CVBpy/DiscoverDevices.
discover_devices.py:
mock_info = next((info for info in discover if "CVMock.vin" in info.access_token), None)
if mock_info is None:
raise RuntimeError("unable to find CVMock.vin")
mock_info.access_token, cvb.AcquisitionStack.Vin) as device:
stream = device.stream()
for i in range(10):
image, status = stream.wait()
print("Acquired image: " + str(i))
stream.abort()
discover_devices_3gen.py:
for i in range(10):
with composite:
print("Acquired image: {}".format(i))
stream.abort()
