ShapeFinder/CVBpy/ShapeFinder
This example program is located in your CVB installation under %CVB%Tutorial/ShapeFinder/CVBpy/ShapeFinder.
shapefinder.py:
# @brief Example for pattern recognition in 2D images using ShapeFinder.
def print_search_result(search_result):
i = 0
for result in search_result:
i += 1
x = result.x
y = result.y
quality = result.quality
rot = result.rotation
angle = result.rotation.deg
print(' {0:2d} Position=[{1:.2f},{2:.2f}], Quality={3:.2f}, Angle={4:.2f}'.format(i, x, y, quality, angle))
sf_example_path = "tutorial/ShapeFinder/Images/SF2/Lusterterminal"
# open device
stream = device.stream()
classifier = cvb.shapefinder2.Classifier(os.path.join(cvb.install_path(), sf_example_path, "Screw.sf2"))
for i in range(2):
image, status = stream.wait()
res = classifier.search_all(device.device_image.planes[0], device.device_image.bounds, cvb.shapefinder2.PrecisionMode.CorrelationFine, 0.55, 20, 10)
print('Result for image {0:2d}:'.format(i+1))
print(' Number of search results: {0:2d}'.format(len(res)))
print_search_result(res)
stream.abort()
