Image Manager/CVBpy/StreamingParallel
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/CVBpy/StreamingParallel.
streaming_parallel.py:
# @brief Example for parallel streaming.
# CVBpy Example Script
# 1. Open the GenICam.vin driver.
# 2. Acquire images in a dedicated native thread through a stream handler.
# 3. Measure the frame rate and print results.
# Requires: A connected and configured GenICam device
import time
class MyStreamHandler(cvb.SingleStreamHandler):
def __init__(self, stream):
super().__init__(stream)
self.rate_counter = cvb.RateCounter()
# called in the interpreter thread to setup additionla stuff.
def setup(self, stream):
super().setup(stream)
print("setup")
# called in the interpreter thread to tear down stuff from setup.
def tear_down(self, stream):
super().tear_down(stream)
print("tear_down")
# called from the aqusition thread
def handle_async_stream(self, stream):
super().handle_async_stream(stream)
print("handle_async_stream")
def handle_async_wait_result(self, image, status):
super().handle_async_wait_result(image, status)
self.rate_counter.step()
print("New image: " + image.__class__.__name__ + " " + str(image) + " | Status: " + str(status) + " | Buffer Index: " + str(image.buffer_index))
# print messurement results
def eval(self):
print("Acquired with: " + str(self.rate_counter.rate) + " fps")
with MyStreamHandler(device.stream()) as handler:
handler.run()
time.sleep(10)
handler.finish()
