Common Vision Blox supports a variety of different image and video formats.
This is an overview for the supported file formats in CVB. For more detailed information about specific formats see the sections about individual formats further down below.
| Extension(s) | Description |
.jpg, .jpeg, .jpe, .jif, .jfif | Standard JPEG image formats |
.png | Portable Network Graphics |
.bmp | Bitmap image |
.tif, .tiff | Tagged Image File Format |
.psd | Adobe Photoshop Document |
.clp | Windows Clipboard Image (legacy) |
.xif | Xerox Image Format (scanner image) |
.thm | Thumbnail image file (from cameras) |
.j2k, .jp2, .jp2k, .j2c, .jpc, .jpx | JPEG 2000 formats |
.iff | Interchange File Format (Amiga) |
.pct | Macintosh Picture file |
.dcx | Multipage PCX |
.pcx | Paintbrush Bitmap Image |
.tga | Targa Graphic |
.ras | Sun Rasterfile |
.wmf | Windows Metafile |
The Windows Bitmap format (*.bmp) is perhaps the most important format on the PC platform. CVB supports BMP files with either 8 bits/Pixel (monochrome) or 24 bits/Pixel (colour). RLE-compressed BMP can neither be loaded nor saved with CVB.
The TIFF-format (*.tif, *.tiff, *.xif) is a very widespread format on several computer platforms. However, the TIFF standard itself is quite complex and offers a huge variety of pixel formats, additional tags, planes etc. Therefore almost all software packages support only a certain subset of the official TIFF standard - and CVB is no exception to this. TIFF formats supported by CVB are from 8 to 16 bits/pixel (bpp) for one (monochrome) or 3 channels (colour). Reading is supported for uncompressed images, LZW77 compressed images and Packbits compressed images. Huffman-coding and Fax-coding are not supported as they would result in images with less than 8 bpp. TIFF support in CVB is achieved through the libtiff library, version 3.5.7, Copyright (c) 1988-1997 Sam Leffler, Copyright (c) 1991-1997 Silicon Graphics, Inc. The source of libtiff is available from https://gitlab.com/libtiff/libtiff.
The JPEG format (*.jpg, *.jpeg, *.jpe, *.jif, *.jfif) is the perhaps most popular and most widespread image format with lossy compression. JPEG support in CVB comprises 8 bpp images (monochrome) and 24 bpp images (colour) with jpeg compression. There is an inherent limitation to images of 65536 pixels width and height in jpeg formats.
The comparatively young JPEG2000 format (*.j2k, *.jp2, *.jp2k, *.jpc, *.jpx) is - much like its ancestor JPEG - a lossy image compression format based on wavelet compression technology. It is recommended to use this image format only on fairly up-to-date computers, because JPEG2000 compression and decompression are extremely time consuming. The boon of using JPEG2000 is a comparatively good image quality even at higher compression ratios. Under CVB, JPEG2000 supports image formats with 8, 10, 12 or 16 bpp (monochrome) as well as 3x8, 3x10, 3x12, 3x16 bpp (colour). JPEG2000 support in CVB is based on the free j2000 codec available from https://jpeg.org/jpeg2000/.
The Minos Image Object (*.mio) file format is proprietary to CVB. This format saves the image data as well as the coordinate system and origin information. This extended information could be used to store calibrated spatial information, coordinate information used for correlation or simply information about a processed image.
The MIO format allows to store images with more than 8 bit image data called High Dynamic range images (HDR).
