Configuration - Software Trigger
using namespace Cvb;
auto devices = DeviceFactory::Discover(DiscoverFlags::IgnoreVins);
auto device = DeviceFactory::Open<GenICamDevice>(devices[0].AccessToken(),
AcquisitionStack::GenTL);
auto nodeMap = device->NodeMap(NodeMapID::Device);
auto triggerModeNode = nodeMap->Node<EnumerationNode>("TriggerMode"); // (1)
triggerModeNode->SetValue("On");
auto triggerSourceNode = nodeMap->Node<EnumerationNode>("TriggerSource"); // (2)
triggerSourceNode->SetValue("Software");
auto triggerSoftwareNode = nodeMap->Node<CommandNode>("TriggerSoftware"); // (3)
auto stream = device->Stream<ImageStream>();
stream->Start();
while(true)
triggerSoftwareNode->Execute(); // (4)
auto [image, status, nodeMaps] = stream->Wait();
//Process image
stream->Abort();
void SetValue(const String &value)
using (var device = (GenICamDevice)DeviceFactory.Open(devices[0], AcquisitionStack.GenTL))
var triggerModeNode = nodes["TriggerMode"] as EnumerationNode; // (1)
triggerModeNode.Value = "On";
var triggerModeNode = nodes["TriggerSource"] as EnumerationNode; // (2)
triggerModeNode.Value = "Software";
var triggerSoftwareNode = nodes["TriggerSoftware"] as CommandNode; // (3)
var stream = device.GetStream<ImageStream>(0);
stream.Start();
triggerSoftwareNode.Execute() // (4)
while(true) {
WaitStatus status;
//Process image
stream.Abort();
trigger_mode_node = node_map["TriggerMode"] # (1)
trigger_mode_node.value = "On"
trigger_mode_node = node_map["TriggerSource"] # (2)
trigger_mode_node.value = "Software"
trigger_software = node_map["TriggerSoftware"] # (3)
while True:
trigger_software.execute() # (4)
image, status, _ = stream.wait()
# Process image
stream.abort()
  1. Activate trigger mode in the device.
  2. Let software control the trigger.
  3. Get the actual trigger node for later use.
  4. Trigger each exposure explicitly from your software.
