Discovering devices using VIN drivers can be done using the Cvb::DeviceFactory::Discover.
The exact details of what each device reports depends on the exact implementation of the VIN driver in question. For more details, refer to the driver documentation.
auto chosenDiscoveryInformation = discoveredDevices[0];
var chosenDiscoveryInformation = discoveredDevices[0];
with cvb.DeviceFactory.open(chosenDiscoveryInformation.access_token, cvb.AcquisitionStack.PreferVin)
as device:
- Discover all VIN devices. By default all devices are discovered so by using the
Cvb::DiscoverFlags::IgnoreTLs flag, the GenTL devices are excluded.
- Filter the found discovery information to select the correct one. As the reported data depends on the VIN driver in question, the first is selected for simplicity.
- Open the device as a
Cvb::VinDevice using Cvb::AcquisitionStack::PreferVin.
