Discovering USB3 Vision (U3V) devices can be done using the Cvb::DeviceFactory::Discover.
In the case that multiple devices using different Transport Layers are connected (e.g. USBTL and GEVTL), no filtering flags can be applied during the discovery process to select a specific transport layer. Instead, after discovery, the Cvb::DiscoveryProperties in the Cvb::DiscoveryInformation should be accessed to determine the transport layer used and filter appropriately.
auto chosenDiscoveryInformation = std::find_if(discoveredDevices.begin(), discoveredDevices.end(),
[](auto discoveryInformation) {
return discoveryInformation[Cvb::DiscoveryProperties::DeviceTransportLayerType] == "USB3";
var chosenDiscoveryInformation = discoveredDevices.First(discoveryInformation => {
chosenDiscoveryInformation = next(filter(lambda discoveryInformation: discoveryInformation.read_property(cvb.DiscoveryProperties.DeviceTransportLayerType) == "USB3", discoveredDevices))
with cvb.DeviceFactory.open(chosenDiscoveryInformation.access_token, cvb.AcquisitionStack.PreferGenTL)
as device:
- Discover all GenTL devices. By default all devices are discovered so by using the
Cvb::DiscoverFlags::IgnoreVins flag, the legacy VIN drivers are excluded.
Filter the found discovery information to use the first that uses the USBTL driver.
Common options are:
Mixed - Several supported technologies
Custom - Custom technologies
GEV - GigE Vision technology
CL - Camera Link technology
IIDC - IIDC 1394 technology
UVC - USB video class devices
CXP - CoaXPress
CLHS - Camera Link HS
USB3 - USB3 Vision Standard
Ethernet - Ethernet devices
PCI - PCI/PCIe devices
- Open the device as a
Cvb::GenICamDevice using Cvb::AcquisitionStack::PreferGenTL. When using USBTL, these flags are mandatory to ensure that all GenICam features are enabled.
