Spectral/Cvb++/CubeAcquisition
This example program is located in your CVB installation under %CVB%Tutorial/Spectral/Cvb++/CubeAcquisition.
// Example for acquistion of **hyperspectral cubes**.
#include <cvb/spectral/cube.hpp>
#include <cvb/spectral/spectral.hpp>
#include <cvb/spectral/wrapped_cube.hpp>
// Get Images
std::vector<Cvb::ImagePtr> GrabImageVec(Cvb::String driverPath, int numImg) {
std::vector<Cvb::ImagePtr> imgVec;
imgVec.reserve(numImg);
// open a device
driverPath = Cvb::ExpandPath(driverPath);
auto device =
Cvb::DeviceFactory::Open(driverPath, Cvb::AcquisitionStack::Vin);
stream->RingBuffer()->ChangeCount(numImg,
Cvb::DeviceUpdateMode::NewDeviceImage);
// start the stream - start the acquisition
stream->Start();
for (int i = 0; i < numImg; ++i) {
Cvb::ImagePtr img = stream->WaitFor(std::chrono::seconds(10), res);
if (res == Cvb::WaitStatus::Timeout)
throw std::runtime_error("acquisition timeout");
if (i % 10 == 0)
std::cout << ".";
imgVec.push_back(img);
// synchronously stop the stream
stream->Stop();
return imgVec;
// Create cube from stack of images
int numberOfImages = 100;
Cvb::String vinDriverPath(
Cvb::ExpandPath(Cvb::InstallPath() + CVB_LIT("drivers/GenICam.vin")));
std::cout << "Start acquiring " << numberOfImages << " images from:\n\t"
<< vinDriverPath << std::endl;
std::vector<Cvb::ImagePtr> imgVec =
GrabImageVec(vinDriverPath, numberOfImages);
auto stackedCube = Cvb::Cube::FromImages(
imgVec, Cvb::Spectral::CubeEncoding::BandInterleavedByLine);
// .. MetaData
auto metaData = stackedCube->MetaData();
int bandsOut = metaData->ReadField<int>(Cvb::Spectral::FieldID::Bands);
// Some imaginary wavelengths
std::vector<double> wavelengths(bandsOut);
for (int i = 0; i < bandsOut; ++i)
wavelengths.at(i) = 400 + i;
metaData->WriteField<std::vector<double>>(
Cvb::Spectral::FieldID::Wavelength, wavelengths);
Cvb::String enviHeaderFile(Cvb::ExpandPath(CVB_LIT("StackedCube.hdr")));
Cvb::String enviBinaryFile(Cvb::ExpandPath(CVB_LIT("StackedCube.bin")));
stackedCube->Save(enviHeaderFile, enviBinaryFile);
std::cout << "\nSaved Cube to file:\n\t" << enviHeaderFile << "\n\t"
<< enviBinaryFile << std::endl;
static std::unique_ptr< Cube > FromImages(const std::vector< ImagePtr > &images, CubeEncoding bufferLayout)
WaitStatus
