ShapeFinder/Cvb++/QtShapeFinder2
This example program is located in your CVB installation under %CVB%Tutorial/ShapeFinder/Cvb++/QtShapeFinder2.
// Example for **pattern recognition** in 2D images using ShapeFinder.
#ifdef _MSC_VER
#pragma warning(push, 1)
#pragma warning(disable : 4702)
#endif
#include <QApplication>
#include <QIcon>
#include "main_widget.hpp"
#ifdef _MSC_VER
#pragma warning(pop)
#endif
QApplication application(argc, argv);
MainWidget mainWidget;
mainWidget.setWindowIcon(QIcon(":/qttutorial.png"));
mainWidget.show();
application.exec();
main_widget.cpp:
#include <QElapsedTimer>
#include <QFileDialog>
#include <QGraphicsRectItem>
#include <QGraphicsSceneMouseEvent>
#include <QGroupBox>
#include <QMessageBox>
#include <QPushButton>
#include <QRubberBand>
#include <QVBoxLayout>
#include <cvb/device.hpp>
#include <cvb/shapefinder2/classifier_factory.hpp>
MainWidget::MainWidget() : QSplitter() {
imageScene_ = new CustomImageScene(this);
imageView_ = new Cvb::UI::ImageView(imageScene_, this);
imageView_->SetUploadMode(Cvb::UI::UploadMode::Viewport);
imageView_->SetRenderEngine(Cvb::UI::RenderEngine::Raster);
imageView_->resize(800, 600);
imageView_->setDragMode(QGraphicsView::RubberBandDrag);
QObject::connect(imageScene_, SIGNAL(SelectionDone(QRectF)), this,
SLOT(HandleSelection(QRectF)));
ctrlWidget_ = new ControlWidget(this);
addWidget(imageView_);
addWidget(ctrlWidget_);
Cvb::AcquisitionStack::Vin);
// Connect the device with the ImageView
imageView_->Refresh(device_->DeviceImage(), Cvb::UI::AutoRefresh::On);
// Create a stream handler
streamHandler_ = CustomStreamHandler::Create(device_->Stream(), *this);
// Enable the grab check box for devices
ctrlWidget_->EnableGrabCheckBox(true);
QObject::connect(this, SIGNAL(SearchDone()), this, SLOT(ShowSearchResult()));
resize(1000, 800);
// first snapshot
device_->Stream()->GetSnapshot();
// Load an image or driver
void MainWidget::HandleLoad() {
imageScene_->ClearScene();
auto fileName = QFileDialog::getOpenFileName(
this, "Load Image",
CVB_LIT("tutorial/ShapeFinder/Images/SF2/Lusterterminal"))),
"CVB Emulator Image Lists (*.emu);;CVB Drivers (*.vin);;Images (*.bmp "
"*.png *.tif *.tiff *.jpg)");
if (fileName.isEmpty())
if (fileName.contains(".emu", Qt::CaseInsensitive))
fileName = fileName.replace("/", "\\"); // necessary for emu files
// Either load an image or device (vin or emu)
if (fileName.contains(".bmp", Qt::CaseInsensitive) ||
fileName.contains(".png", Qt::CaseInsensitive) ||
fileName.contains(".tif", Qt::CaseInsensitive) ||
fileName.contains(".jpg", Qt::CaseInsensitive)) {
imageView_->Refresh(image);
// Disable the grab check box for images
ctrlWidget_->EnableGrabCheckBox(false);
} else {
QMessageBox::critical(this, "Error", QString(error.what()));
// Handle start / stop grab
void MainWidget::HandleGrab(int state) {
if (state == Qt::CheckState::Checked) {
// Start streaming
streamHandler_->Run();
} else {
// Disable possible blocking of the UI if necessary
bool wait = imageView_->IsWaitForRepaintEnabled();
if (wait)
imageView_->SetWaitForRepaintEnabled(!wait);
// Stop streaming
streamHandler_->Finish();
// Reset the previous state
imageView_->SetWaitForRepaintEnabled(wait);
// Handle a snap
void MainWidget::HandleSnap() {
if (continuedSearch_)
HandleSearch();
// Save the image
void MainWidget::HandleSave() {
auto fileName = QFileDialog::getSaveFileName(
this, "Save Image", Cvb::UI::CvbToQt(Cvb::InstallPath()),
"Bitmap File (*.bmp);;CVB Emulator Image Lists (*.emu);;JPEG (*.jpg, "
"*.jpeg);;Portable Network Graphic (*.png);;Tagged Image File Format "
"(*.tif, *.tiff);;All Files (*.*)");
imageView_->Image()->Save(Cvb::UI::QtToCvb(fileName));
// Load an SF2 model (classifier)
void MainWidget::HandleLoadModel() {
this, "Load SF2 Model",
"ShapeFinder2 models (*.sf2)");
classifier_ = Cvb::Classifier::Create(Cvb::UI::QtToCvb(fileName));
// Save the SF2 model
void MainWidget::HandleSaveModel() {
this, "Save SF2 Model",
classifier_->Save(Cvb::UI::QtToCvb(fileName));
// Train / learn the selection and create classifier
void MainWidget::HandleTrain() {
if (isSelected_) {
ctrlWidget_->SetTrainView(*selection_);
isSelected_ = false;
} else {
ctrlWidget_->SetTrainView(*imageView_->Image());
auto aoi = imageView_->Image()->Bounds();
selectionRect_ =
Cvb::Rect<double>(aoi.Left(), aoi.Top(), aoi.Right(), aoi.Bottom());
auto centerX = static_cast<int>(
std::round(selectionRect_.Left() +
((selectionRect_.Right() - selectionRect_.Left()) / 2)));
auto centerY = static_cast<int>(
std::round(selectionRect_.Top() +
((selectionRect_.Bottom() - selectionRect_.Top()) / 2)));
Cvb::Rect<int> teachWindow(
selectionRect_.Left() - centerX, selectionRect_.Top() - centerY,
selectionRect_.Right() - centerX, selectionRect_.Bottom() - centerY);
classifier_ =
factory.Learn(imageView_->Image()->Plane(0),
Cvb::Point2D<int>(centerX, centerY), teachWindow);
QMessageBox::critical(this, "Error", e.what());
// Run a search (search button clicked)
void MainWidget::HandleSearch() {
if (!classifier_) {
QMessageBox::warning(
this, "SF2 Search",
"Please create (train) or load a model/classifier first.");
Search();
// Activate the continuous search
void MainWidget::HandleContSearch(int state) {
if (state == Qt::Checked)
continuedSearch_ = true;
continuedSearch_ = false;
template <typename T> Cvb::Rect<T> AsRect(const Cvb::RectLT<T> &rectLT) {
Cvb::Size2D<T>(rectLT.Size()));
// Area has been selected
void MainWidget::HandleSelection(QRectF selection) {
Cvb::Area2D area(AsRect(Cvb::UI::QtToCvb(selection)));
// Convert the rectangle to pixel coordinates
auto convertedArea = imageView_->Image()->ImageToPixelCoordinates(area);
// Get the bounds
Cvb::Rect<double> boundingRect = convertedArea.BoundingRectangle();
// Get the selected part of the image
selection_ = imageView_->Image()->Map(
Cvb::Rect<int>(boundingRect.Left(), boundingRect.Top(),
boundingRect.Right(), boundingRect.Bottom()));
isSelected_ = true;
selectionRect_ = boundingRect;
// Run the search on the classifier loaded
void MainWidget::Search() {
if (!classifier_)
Cvb::ShapeFinder2::PrecisionMode::CorrelationFine; // Defines how many and
// which search phases
// will be carried out.
double relativeThreshold = 0.55; // Defines the quality span between the best
// and the worst result candidate.
int minimumThreshold = 20; // Absolute quality threshold a result must exceed
// to make it into the result list.
int coarseLocality = 10; // Minimum distance for solutions in the coarse layer
// before correlation hill climbing happens.
if (isSelected_) {
Cvb::Rect<int> aoi(selectionRect_.Left(), selectionRect_.Top(),
selectionRect_.Right(), selectionRect_.Bottom());
searchResult_ = classifier_->SearchAll(imageView_->Image()->Plane(0), aoi,
mode, relativeThreshold,
minimumThreshold, coarseLocality);
} else {
imageView_->Image()->Plane(0), imageView_->Image()->Bounds(), mode,
relativeThreshold, minimumThreshold, coarseLocality);
emit SearchDone();
// Display the search result (result info and overlay)
void MainWidget::ShowSearchResult() {
ctrlWidget_->SetResultInfo(searchResult_.size());
imageScene_->SetSearchResult(*imageView_->Image(), searchResult_);
ControlWidget::ControlWidget(QWidget *parent) : QWidget(parent) {
auto mainLayout = new QGridLayout;
trainImageView_ = new Cvb::UI::ImageView(this);
trainImageView_->SetUploadMode(Cvb::UI::UploadMode::Image);
trainImageView_->SetRenderEngine(Cvb::UI::RenderEngine::Raster);
QPushButton *openImgBtn = new QPushButton(tr("Open Image"));
QObject::connect(openImgBtn, SIGNAL(clicked()), parent, SLOT(HandleLoad()));
grabCheckBox_ = new QCheckBox(tr("Grab"));
QObject::connect(grabCheckBox_, SIGNAL(stateChanged(int)), parent,
SLOT(HandleGrab(int)));
QPushButton *snapBtn = new QPushButton(tr("Snap"));
QObject::connect(snapBtn, SIGNAL(clicked()), parent, SLOT(HandleSnap()));
QPushButton *saveBtn = new QPushButton(tr("Save"));
QObject::connect(saveBtn, SIGNAL(clicked()), parent, SLOT(HandleSave()));
contSearchCheckBox_ = new QCheckBox(tr("Continued Search"));
QObject::connect(contSearchCheckBox_, SIGNAL(stateChanged(int)), parent,
SLOT(HandleContSearch(int)));
QGroupBox *groupBox = new QGroupBox(tr(""));
QPushButton *loadModelBtn = new QPushButton(tr("Load Model"));
QObject::connect(loadModelBtn, SIGNAL(clicked()), parent,
SLOT(HandleLoadModel()));
QPushButton *saveModelBtn = new QPushButton(tr("Save Model"));
QObject::connect(saveModelBtn, SIGNAL(clicked()), parent,
SLOT(HandleSaveModel()));
QPushButton *trainBtn = new QPushButton(tr("Train"));
QObject::connect(trainBtn, SIGNAL(clicked()), parent, SLOT(HandleTrain()));
QPushButton *searchBtn = new QPushButton(tr("Search"));
QObject::connect(searchBtn, SIGNAL(clicked()), parent, SLOT(HandleSearch()));
resultLabel_ = new QLabel(tr("Number of search results: 0"));
QGridLayout *gbLayout = new QGridLayout;
gbLayout->addWidget(trainBtn, 0, 0);
gbLayout->addWidget(loadModelBtn, 0, 1);
gbLayout->addWidget(searchBtn, 1, 0);
gbLayout->addWidget(saveModelBtn, 1, 1);
gbLayout->addWidget(resultLabel_, 2, 0, 1, -1);
groupBox->setLayout(gbLayout);
mainLayout->addWidget(trainImageView_, 0, 0, 1, -1);
mainLayout->addWidget(openImgBtn, 1, 0, 1, 1);
mainLayout->addWidget(grabCheckBox_, 1, 1, 1, 1);
mainLayout->addWidget(snapBtn, 1, 2, 1, 1);
mainLayout->addWidget(saveBtn, 2, 0, 1, 1);
mainLayout->addWidget(contSearchCheckBox_, 2, 1, 1, -1);
mainLayout->addWidget(groupBox, 3, 0, 1, -1);
setLayout(mainLayout);
void ControlWidget::EnableGrabCheckBox(bool value) {
grabCheckBox_->setEnabled(value);
void ControlWidget::SetResultInfo(size_t numResults) {
QString count = "Number of search results: " + QString::number(numResults);
resultLabel_->setText(count);
void ControlWidget::SetTrainView(const Cvb::Image &image) {
if (trainImageView_)
trainImageView_->Refresh(image);
CustomImageScene::CustomImageScene(QWidget *parent)
: Cvb::UI::ImageScene(parent) {}
void CustomImageScene::SetSearchResult(
const Cvb::Image &image,
std::vector<Cvb::ShapeFinder2::SearchResult> result) {
// Clear the scene
ClearScene();
searchResult_ = result;
// Draw overlays for search results
for (int i = 0; i < searchResult_.size(); i++) {
Cvb::ShapeFinder2::SearchResult res = result.at(i);
double x = res.X();
double y = res.Y();
// Draw a small rectangle at the result pixel location
auto point = image.PixelToImageCoordinates(Cvb::Point2D<double>(x, y));
QGraphicsRectItem *item =
new QGraphicsRectItem(QRectF(point.X(), point.Y(), 5, 5));
item->setBrush(QBrush(Qt::red));
this->addItem(item);
// Draw a label right beside the pixel
QString label = "Q: " + QString::number(res.Quality(), 'f', 2) +
", A: " + QString::number(res.Rotation().Deg(), 'f', 2);
QGraphicsRectItem *textLabel =
new QGraphicsRectItem(QRectF(point.X() + 5, point.Y() + 5, 100, 15));
textLabel->setBrush(QBrush(Qt::red));
this->addItem(textLabel);
QGraphicsTextItem *text = this->addText(label);
text->setPos(point.X() + 5, point.Y() + 2.5);
text->setDefaultTextColor(Qt::black);
void CustomImageScene::ClearScene() {
this->clear();
this->update();
void CustomImageScene::mousePressEvent(QGraphicsSceneMouseEvent *event) {
ClearScene();
this->ImageView()->setDragMode(QGraphicsView::RubberBandDrag);
// remember the start point
pointStart_ = event->scenePos();
void CustomImageScene::mouseReleaseEvent(QGraphicsSceneMouseEvent *event) {
// remember the end point
pointEnd_ = event->scenePos();
// draw a rectangle to mark the selection
this->addRect(QRectF(pointStart_, pointEnd_), QPen(Qt::blue, 0));
// signal to react to the selection
emit SelectionDone(QRectF(pointStart_, pointEnd_));
double Deg() const noexcept
static std::unique_ptr< Classifier > Create(const String &fileName)
T Bottom() const noexcept
T Top() const noexcept
T Right() const noexcept
T Left() const noexcept
Size2D< T > Size() const noexcept
Point2D< T > Location() const noexcept
std::unique_ptr< Classifier > Learn(const ImagePlane &plane, Point2D< int > position, Rect< int > teachWindow, const std::vector< Point2D< int > > &dontCarePoints) const
double Quality() const noexcept
Angle Rotation() const noexcept
double Y() const noexcept
double X() const noexcept
y
x
main_widget.hpp:
#pragma once
#include <QCheckBox>
#include <QLabel>
#include <QSplitter>
#include <cvb/shapefinder2/classifier.hpp>
// The custom image scene to draw overlays
class CustomImageScene : public Cvb::UI::ImageScene {
Q_OBJECT
explicit CustomImageScene(QWidget *parent = 0);
void SetSearchResult(const Cvb::Image &image,
std::vector<Cvb::ShapeFinder2::SearchResult> result);
void ClearScene();
void mousePressEvent(QGraphicsSceneMouseEvent *event);
void mouseReleaseEvent(QGraphicsSceneMouseEvent *event);
signals:
void SelectionDone(QRectF selectedArea);
private:
std::vector<Cvb::ShapeFinder2::SearchResult> searchResult_;
QPointF pointStart_;
QPointF pointEnd_;
// The control widget
class ControlWidget : public QWidget {
Q_OBJECT
explicit ControlWidget(QWidget *parent);
~ControlWidget() = default;
void EnableGrabCheckBox(bool value);
void SetResultInfo(size_t numResults);
void SetTrainView(const Cvb::Image &image);
private:
Cvb::UI::ImageView *trainImageView_ = nullptr;
QCheckBox *grabCheckBox_ = nullptr;
QCheckBox *contSearchCheckBox_ = nullptr;
QLabel *resultLabel_ = nullptr;
// The main widget
class MainWidget : public QSplitter {
Q_OBJECT
explicit MainWidget();
virtual ~MainWidget() {}
void Search();
public Q_SLOTS:
void HandleLoad();
void HandleGrab(int);
void HandleSnap();
void HandleSave();
void HandleLoadModel();
void HandleSaveModel();
void HandleSearch();
void HandleTrain();
void HandleContSearch(int);
void HandleSelection(QRectF);
protected Q_SLOTS:
void ShowSearchResult();
signals:
void SearchDone();
private:
CustomImageScene *imageScene_ = nullptr;
Cvb::UI::ImageView *imageView_ = nullptr;
ControlWidget *ctrlWidget_ = nullptr;
Cvb::DevicePtr device_ = nullptr;
bool continuedSearch_ = false;
bool isSelected_ = false;
Cvb::ImagePtr selection_ = nullptr;
Cvb::Rect<double> selectionRect_;
// The custom stream handler to handle image processing while grabbing
class CustomStreamHandler : public Cvb::SingleStreamHandler {
Create(const Cvb::StreamPtr &stream, MainWidget &mainWidget) {
return std::unique_ptr<CustomStreamHandler>(
new CustomStreamHandler(stream, mainWidget));
~CustomStreamHandler() { TryFinish(); }
private:
CustomStreamHandler(const Cvb::StreamPtr &stream, MainWidget &mainWidget)
: Cvb::SingleStreamHandler(stream), mainWidget_(mainWidget) {}
void HandleAsyncStream(const Cvb::StreamPtr &stream) override {
auto waitResult = stream->WaitFor(std::chrono::milliseconds(10000));
if (!waitResult.Image)
if (mainWidget_.continuedSearch_)
mainWidget_.Search();
MainWidget &mainWidget_;
std::shared_ptr<CustomStreamHandler> streamHandler_ = nullptr;
std::shared_ptr< Classifier > ClassifierPtr
