#include "main_widget.hpp"
#include <QComboBox>
#include <QDir>
#include <QFileDialog>
#include <QGridLayout>
#include <QLabel>
#include <QLineEdit>
#include <QMessageBox>
#include <QPushButton>
#include <cvb/device.hpp>
#include <cvb/size_2d.hpp>
#include <cvb/movie2/recorder.hpp>
#include <cvb/movie2/recording_settings.hpp>
MainWidget::MainWidget() : QWidget() {
auto layout = new QGridLayout;
auto fileName = QDir::homePath() + QDir::separator() + "Documents" +
QDir::separator() + "Movie2ExampleVideo.avi";
movieFile_ = new QLineEdit(fileName);
auto btnFileSelect = new QPushButton("Record to...");
QObject::connect(btnFileSelect, &QPushButton::clicked, [=]() {
auto file = QFileDialog::getSaveFileName(this, "Record Video", fileName,
"Video Files (*.avi)");
if (file.isEmpty())
file = fileName;
movieFile_->setText(file);
imageView_->SetRenderEngine(Cvb::UI::RenderEngine::Raster);
imageView_->resize(800, 600);
QPushButton *openImgBtn = new QPushButton("Open Image");
QObject::connect(openImgBtn, &QPushButton::clicked, [=]() {
auto driver = QFileDialog::getOpenFileName(
this, "Load Image",
"CVB Emulator Image Lists (*.emu);;CVB Drivers (*.vin);;Images (*.bmp "
"*.png *.tif *.tiff *.jpg)");
Load(driver);
grabCheckBox_ = new QCheckBox("Grab");
QObject::connect(grabCheckBox_, &QCheckBox::stateChanged, [=](int state) {
if (state == Qt::CheckState::Checked) {
streamHandler_->Run();
assert(streamHandler_->IsActive());
} else {
bool wait = imageView_->IsWaitForRepaintEnabled();
if (wait)
imageView_->SetWaitForRepaintEnabled(!wait);
streamHandler_->Finish();
imageView_->SetWaitForRepaintEnabled(wait);
assert(!streamHandler_->IsActive());
auto recordCheckBox = new QCheckBox("Record");
QObject::connect(recordCheckBox, &QPushButton::clicked, [=]() {
if (!recorder_) {
Cvb::Movie2::RecorderPixelFormat::Mono, settings_);
} else {
recorder_.reset();
auto codecComboBox = new QComboBox();
auto codecs = settings_.AvailableCodecs();
for (const auto &codec : codecs)
layout->addWidget(btnFileSelect, 0, 0);
layout->addWidget(movieFile_, 0, 1);
layout->addWidget(openImgBtn, 0, 2);
layout->addWidget(grabCheckBox_, 0, 3);
layout->addWidget(recordCheckBox, 1, 2, 1, 2);
layout->addWidget(codecComboBox, 2, 2, 1, -1);
layout->addWidget(imageView_, 1, 0, 3, 2);
CVB_LIT("tutorial/ClassicSwitch.emu")));
setLayout(layout);
void MainWidget::Load(const QString &driver) {
QString fileName = driver;
if (fileName.isEmpty())
if (fileName.contains(".emu", Qt::CaseInsensitive))
fileName = fileName.replace("/", "\\");
if (fileName.contains(".bmp", Qt::CaseInsensitive) ||
fileName.contains(".png", Qt::CaseInsensitive) ||
fileName.contains(".tif", Qt::CaseInsensitive) ||
fileName.contains(".jpg", Qt::CaseInsensitive)) {
imageView_->Refresh(image);
grabCheckBox_->setEnabled(false);
} else {
Cvb::AcquisitionStack::Vin);
imageView_->Refresh(device->DeviceImage(), Cvb::UI::AutoRefresh::On);
streamHandler_ = CustomStreamHandler::Create(device->Stream(), *this);
grabCheckBox_->setEnabled(true);
QMessageBox::critical(this, "Error", QString(error.what()));
static std::unique_ptr< Recorder > Create(const String &path, Size2D< int > size, RecorderPixelFormat pixelFormat, const RecordingSettings &settings)
void SetUploadMode(Cvb::UI::UploadMode uploadMode)
