Foundation/Cvb++/QmlBlobSearch
This example program is located in your CVB installation under %CVB%Tutorial/Foundation/Cvb++/QmlBlobSearch.
blob_result_model.cpp:
#include "blob_result_model.hpp"
#include <QRect>
BlobResultModel::BlobResultModel(
const std::vector<Cvb::Foundation::BlobResult> &blobResults)
: QAbstractListModel(), blobResults_(blobResults) {}
QHash<int, QByteArray> BlobResultModel::roleNames() const {
QHash<int, QByteArray> names;
names[Center] = "blobCenter";
names[BoundingBox] = "boundingBox";
names[Size] = "blobSize";
return names;
int BlobResultModel::rowCount(const QModelIndex &) const {
return static_cast<int>(blobResults_.size());
QVariant BlobResultModel::data(const QModelIndex &index, int role) const {
if (!index.isValid())
return QVariant();
const auto &result = blobResults_[index.row()];
switch (role) {
return QVariant();
case Center:
return QVariant(QPointF(result.X(), result.Y()));
case BoundingBox:
return QVariant(
QRect(result.BoundingBox().Left(), result.BoundingBox().Top(),
result.BoundingBox().Width(), result.BoundingBox().Height()));
case Size:
return QVariant(result.Size());
blob_result_model.hpp:
#pragma once
#include <QAbstractListModel>
#include <cvb/foundation/blob.hpp>
class BlobResultModel : public QAbstractListModel {
explicit BlobResultModel(
const std::vector<Cvb::Foundation::BlobResult> &blobResults);
private:
enum BlobResultRoles {
Center = Qt::UserRole,
BoundingBox = Qt::UserRole + 1,
Size = Qt::UserRole + 2
QHash<int, QByteArray> roleNames() const override;
int rowCount(const QModelIndex &) const override;
QVariant data(const QModelIndex &index,
int role = Qt::DisplayRole) const override;
std::vector<Cvb::Foundation::BlobResult> blobResults_;
// The QmlBlobSearch example shows the **blob search** of CVB Foundation package.
#include <QApplication>
#include <QIcon>
#include <QQmlContext>
#include <QQuickView>
QApplication app(argc, argv);
CVB_LIT("tutorial/Foundation/Images/Blob/Microswitch.bmp"));
// expand environment variables in path
path = Cvb::ExpandPath(path);
auto image = Cvb::Image::Load(path);
filter[Cvb::Foundation::BlobRangeFilter::Size] =
Cvb::ValueRange<int>(100, 100000);
image->Plane(0), Cvb::ValueRange<int>(0, 62), filter);
BlobResultModel blobResultModel(blobResults);
Cvb::UI::ImageLabelItem::Register();
QQuickView view;
view.setResizeMode(QQuickView::SizeRootObjectToView);
view.setIcon(QIcon(":/qttutorial.png"));
auto context = view.rootContext();
context->setContextProperty("blobResultModel", &blobResultModel);
// load main QML file
view.setSource(QUrl::fromLocalFile("../main.qml"));
// refresh the image display through the controller object
imageController.Refresh(std::move(image));
view.resize(640, 480);
view.show();
return app.exec();
std::vector< BlobResult > BinarizeAndSearchBlobs(const ImagePlane &plane, ValueRange< int > binarizationThreshold)
