Foundation/Cvb++/CppMetricCalibrationRigidBodyTrafo
This example program is located in your CVB installation under %CVB%Tutorial/Foundation/Cvb++/CppMetricCalibrationRigidBodyTrafo.
// Example for a **rigid-body transformation** (extrinsic calibration) using the AQS12 target.
#include "cvb/foundation/metric_aqs12.hpp"
void PrintTrafo(const Cvb::AffineMatrix3D &transformation);
void PrintTrafo(
const Cvb::AffineTransformationParameters &transformationParameters);
void PrintResiduals(const std::vector<Cvb::Point3D<double>> &residuals);
std::cout << "Estimation of a rigid body transformation (rotation and "
"translation)\n\n";
// load range map of AQS12
const auto rangemapFile =
CVB_LIT("tutorial/Metric/Images/RangeMapCalibrationPattern.tif");
Cvb::ImagePtr rangemap = Cvb::Image::Load(rangemapFile);
std::cout << "Rangemap loaded with size of " << rangemap->Width() << " x "
<< rangemap->Height() << " from " << rangemapFile << ".\n";
// create calibration configuration object
auto aqs12 = GetAqs12();
// create intrinsically calibrated dense point cloud
const auto calibrationFile =
CVB_LIT(
"tutorial/Metric/Images/SICalibration.json"); // calibration file
// with homography and
// scaling
auto calibrator =
calibrator->SetRangeMapIgnoreValue(0.0);
rangemap->Plane(0), *calibrator,
Cvb::PointCloudFlags::Float | Cvb::PointCloudFlags::XYZConfidence);
std::cout
<< "Dense point cloud created from rangemap and calibration file with "
<< cloud->NumPoints() << " points.\n\n";
// create AQS12 segmentor for dense point clouds
auto segmentor =
Cvb::Foundation::Metric::SegmentationMethod::KmeansClustering);
// estimate calibration parameters
auto [transformation, residuals, transformationParameters] =
*cloud, *segmentor, aqs12);
calibrator->SetExtrinsicMatrix(transformation);
// show results
PrintTrafo(transformation);
PrintTrafo(transformationParameters);
if (residuals)
PrintResiduals(*residuals);
// create calibrated cloud
auto calibratedCloud = Cvb::PointCloudFactory::Create(
// reference points in mm in a right-handed coordinate system
std::array<Cvb::Point3D<double>, 12> points = {{
{20.0018, 44.9941, 15.0000},
{24.0018, 39.9942, 14.9994},
{23.9994, 24.9972, 15.0001},
{20.0021, 20.0035, 15.0011},
{15.9994, 25.0079, 15.0016},
{16.0000, 39.9919, 15.0010},
{20.0095, 59.9985, 4.9902},
{32.0093, 44.9958, 4.9909},
{32.0052, 19.9925, 4.9920},
{20.0021, 4.9961, 4.9939},
{8.0024, 19.9980, 5.0009},
{8.0065, 45.0009, 4.9984},
void PrintTrafo(const Cvb::AffineMatrix3D &transformation) {
std::cout << "Estimated transformation:\n";
std::cout << "translation: [";
std::cout << transformation.Translation().X() << ", "
<< transformation.Translation().Y() << ", "
<< transformation.Translation().Z() << "]\n";
std::cout << "transformation matrix: [\n";
std::cout << transformation.Matrix()[0][0] << ", "
<< transformation.Matrix()[0][1] << ", "
<< transformation.Matrix()[0][2] << ",\n";
std::cout << transformation.Matrix()[1][0] << ", "
<< transformation.Matrix()[1][1] << ", "
<< transformation.Matrix()[1][2] << ",\n";
std::cout << transformation.Matrix()[2][0] << ", "
<< transformation.Matrix()[2][1] << ", "
<< transformation.Matrix()[2][2] << "]\n\n";
void PrintTrafo(
const Cvb::AffineTransformationParameters &transformationParameters) {
std::cout << "Rotation angles about X,Y,Z axis in [degree]: "
<< transformationParameters.RotationAngles[0] << ", "
<< transformationParameters.RotationAngles[1] << ", "
<< transformationParameters.RotationAngles[2] << "\n\n";
void PrintResiduals(const std::vector<Cvb::Point3D<double>> &residuals) {
std::cout << "Residuals:\n";
for (auto residual : residuals) {
std::cout << residual.X() << " " << residual.Y() << " " << residual.Z()
<< "\n";
std::cout << "\n";
Vector3D< double > Translation() const noexcept
Matrix3D Matrix() const noexcept
static std::shared_ptr< T > Load(const String &fileName)
static std::shared_ptr< AQS12DensePointCloudSegmentor > Create(const SegmentationMethod method)
RigidBodyTransformationResult CalculateRigidBodyTransformationFromAqs12Piece(const DensePointCloud &cloud, const AQS12DensePointCloudSegmentor &segmentor, const AQS12Piece &aqs12)
