Image Manager/Cvb++/QtStreamDisplayPair
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/Cvb++/QtStreamDisplayPair.
// The QtStreamDisplayPair example shows two displays from a GenICam device with Qt. One display shows
// the device's output, the other display one of the planes.
#include <QApplication>
#include <QDebug>
#include <QHBoxLayout>
#include <QIcon>
#include <QWidget>
#include <cvb/device.hpp>
// MainWidget with two displays (original and plane 0)
class MainWidget : public QWidget {
MainWidget() : QWidget() {
masterView_ = new Cvb::UI::ImageView(this);
slaveView_ = new Cvb::UI::ImageView(this);
masterView_->SetUploadMode(Cvb::UI::UploadMode::Viewport);
masterView_->CustomWaitForRepaint([&]() {
masterView_->viewport()->repaint();
slaveView_->viewport()->repaint();
slaveView_->SetRefreshMode(Cvb::UI::RefreshMode::UploadOnly);
auto mainLayout = new QHBoxLayout(this);
setLayout(mainLayout);
mainLayout->addWidget(masterView_);
mainLayout->addWidget(slaveView_);
void Run(const Cvb::Device &device) {
// the display of the image
slaveView_->Refresh(device.DeviceImage(), Cvb::UI::AutoRefresh::On);
// the display of the image with plane 0
masterView_->Refresh(device.DeviceImage()->Plane(0).Map());
customAcquisitonHandler_ =
CustomStreamHandler::Create(device.Stream(), *this);
customAcquisitonHandler_->Run();
protected:
void closeEvent(QCloseEvent *event) override {
masterView_->SetWaitForRepaintEnabled(false);
QWidget::closeEvent(event);
private:
class CustomStreamHandler : public Cvb::SingleStreamHandler {
Create(const Cvb::StreamPtr &stream, MainWidget &mainWidget) {
return std::unique_ptr<CustomStreamHandler>(
new CustomStreamHandler(stream, mainWidget));
~CustomStreamHandler() { TryFinish(); }
private:
CustomStreamHandler(const Cvb::StreamPtr &stream, MainWidget &mainWidget)
: Cvb::SingleStreamHandler(stream), mainWidget_(mainWidget) {}
void HandleAsyncStream(const Cvb::StreamPtr &stream) override {
auto waitResult = stream->WaitFor(std::chrono::milliseconds(10000));
if (!waitResult.Image)
mainWidget_.masterView_->Refresh(waitResult.Image->Plane(0).Map());
MainWidget &mainWidget_;
Cvb::UI::ImageView *masterView_ = nullptr;
Cvb::UI::ImageView *slaveView_ = nullptr;
std::unique_ptr<CustomStreamHandler> customAcquisitonHandler_;
QApplication app(argc, argv);
path += CVB_LIT("drivers/GenICam.vin");
// use command line argument if provided
if (argc > 1) {
std::string inputPath(argv[1]);
path = Cvb::String(inputPath.begin(), inputPath.end());
// expand environment variables in path
path = Cvb::ExpandPath(path);
// open a device
auto device = Cvb::DeviceFactory::Open(path, Cvb::AcquisitionStack::Vin);
// connect the device image to the UI
MainWidget mainWidget;
mainWidget.setWindowIcon(QIcon(":/qttutorial.png"));
mainWidget.Run(*device);
mainWidget.resize(880, 600);
mainWidget.show();
return app.exec();
virtual StreamPtr Stream() const
std::shared_ptr< T > DeviceImage() const
