Image Manager/Cvb++/QmlStreamDisplay
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/Cvb++/QmlStreamDisplay.
// The QmlStreamDisplay example shows an image in a Qt display. With mouse over the pixel data are
// shown.
#include <QApplication>
#include <QIcon>
#include <QQmlContext>
#include <QQuickView>
QApplication app(argc, argv);
QQuickView view;
view.setResizeMode(QQuickView::SizeRootObjectToView);
view.setIcon(QIcon(":/qttutorial.png"));
auto context = view.rootContext();
// load main QML file
view.setSource(QUrl::fromLocalFile("../main.qml"));
// open a device
CVB_LIT("drivers/CVMock.vin"),
Cvb::AcquisitionStack::Vin);
// refresh the image display through the controller object
imageController.Refresh(device->DeviceImage(), Cvb::UI::AutoRefresh::On);
// get the first stream of the device
// or use device->Stream(index) to get another stream
// create an acquisition handler for that stream and run it.
// Actually the guard starts it, and will finish it when destructed.
// There are two ways to run the acquisition:
// - Either via stream->Start() and stream->Wait() in a separate thread
// - or via SingleStreamHandler (Run() / Finish())
Cvb::SingleStreamHandler::Create(stream), Cvb::AutoRun::Yes);
view.resize(640, 480);
view.show();
return app.exec();
static std::unique_ptr< SingleStreamHandler > Create(const Driver::StreamPtr &stream)
