Image Manager/Cvb++/QmlFirmwareUpdater
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/Cvb++/QmlFirmwareUpdater.
backend.cpp:
#include "backend.hpp"
#include "QDebug"
#include "QQuickView"
#include <cvb/data_type.hpp>
#include <cvb/device.hpp>
#include <cvb/ui/ui.hpp>
#include <sstream>
BackEnd::BackEnd(QQuickView *view, QObject *parent)
: QObject(parent), view_{view} {
// Register view to queue commands over threads
qRegisterMetaType<QWindow::Visibility>();
BackEnd::~BackEnd() {}
void BackEnd::ShowStatus(const std::string &statusMessage) {
auto statusText = view_->findChild<QObject *>("status");
if (statusText)
statusText->setProperty("text", statusMessage.c_str());
void BackEnd::ShowGufContent(const std::string &statusMessage) {
auto statusText = view_->findChild<QObject *>("gufContent");
if (statusText)
const QVariantList BackEnd::CameraCombo() { return cameraCombo_; }
const QVariantList BackEnd::GufEntriesCombo() { return gufEntriesCombo_; }
void BackEnd::SetCameraCombo(const QVariantList &cameraCombo) {
if (cameraCombo_ != cameraCombo) {
cameraCombo_ = cameraCombo;
emit CameraComboChanged();
void BackEnd::SetGufEntriesCombo(const QVariantList &gufEntriesCombo) {
if (gufEntriesCombo_ != gufEntriesCombo) {
gufEntriesCombo_ = gufEntriesCombo;
emit GufEntriesComboChanged();
void BackEnd::UpdateGufEntryInfo(const int &gufEntryIdx) {
if (fwupdater_) {
ShowStatus("Loading guf file.");
auto entries = fwupdater_->UpdateFileInfos(gufEntryIdx);
QString text;
for (const auto &entry : entries) {
text += Cvb::UI::CvbToQt(entry);
text += "\n";
ShowGufContent(text.toStdString());
ShowStatus("Done.");
} catch (...) {
ShowStatus("Failed to retrieve available update file infos from guf.");
void BackEnd::BtnOpenGuf(const QString &path) {
qDebug() << "Using guf file " << path;
gufFilePath_ = Cvb::UI::QtToCvb(path);
ShowStatus("Reading guf content.");
fwupdater_ = Cvb::GenApi::FWUpdater::Create(gufFilePath_);
ShowStatus("Done");
std::stringstream error;
error << "Error creating firmware updater using guf file.\n"
<< path.toUtf8().constData() << "\n"
<< e.what() << "\nMaybe check the Control.xml in the guf file.";
ShowStatus(error.str());
} catch (...) {
ShowStatus("Failed to create firmware updater.");
QVariantList list;
list.clear();
if (fwupdater_) {
gufFileEntries_ = fwupdater_->AvailableUpdateFiles();
for (const auto &entry : gufFileEntries_) {
list.append(Cvb::UI::CvbToQt(entry));
SetGufEntriesCombo(list);
} catch (...) {
ShowStatus("Failed to retrieve available update files from guf.");
void BackEnd::ListAvailableDevices() {
deviceMap_.clear();
discover_ =
Cvb::DeviceFactory::Discover(Cvb::Driver::DiscoverFlags::IgnoreGevSD);
for (const auto &device : discover_) {
Cvb::String devModel{CVB_LIT("Unset")};
if (device.TryGetProperty(Cvb::Driver::DiscoveryProperties::DeviceModel,
devModel))
deviceMap_[devModel] = static_cast<int32_t>(device.Index());
// Scan for available devices and update list of possible updates, call update
// list to update dropdown
void BackEnd::BtnScan() {
qDebug() << "Starting scan of available devices for guf file.";
QVariantList list;
list.clear();
ListAvailableDevices();
for (const auto &device : deviceMap_) {
list.append(Cvb::UI::CvbToQt(device.first));
SetCameraCombo(list);
void BackEnd::BtnStartUpdate(const int gufEntryIdx, const QString &selCamera) {
if (gufEntryIdx < 0) {
ShowStatus("No guf entry set.");
if (selCamera.isEmpty()) {
ShowStatus("No camera selected.");
auto selDeviceIdx = deviceMap_[Cvb::UI::QtToCvb(selCamera)];
qDebug() << "Starting update for device " << selCamera << " with update file "
<< QString::number(gufEntryIdx) << "\""
<< Cvb::UI::CvbToQt(gufFileEntries_[gufEntryIdx]) << "\".";
ShowStatus("Updating camera.");
auto tmpDevPtr{
Cvb::DeviceFactory::Open(discover_[selDeviceIdx].AccessToken(),
Cvb::AcquisitionStack::PreferGenTL)};
fwupdater_->Update(std::move(tmpDevPtr), gufEntryIdx);
ShowStatus("Update successful.");
error << "Update failed: " << e.what();
} catch (...) {
ShowStatus(
"Sorry, something unknown and unexpected has happened. Following the "
"mainstream we could have ignored this leaving you even more puzzled. "
"However we must admit that we have no clue either.");
static std::unique_ptr< FWUpdater > Create(const String &filename, bool verify=true)
backend.hpp:
#pragma once
#include "QVariantList"
#include <QObject>
#include <QQmlContext>
#include <QQuickItem>
#include <QQuickView>
#include <QString>
#include <map>
#include <string>
#include <vector>
#include <cvb/genapi/fw_updater.hpp>
class BackEnd : public QObject {
// This macro is required for QObject support. You should get a compiler
// error if you don't include this.
Q_OBJECT
Q_PROPERTY(QVariantList CameraCombo READ CameraCombo WRITE SetCameraCombo
NOTIFY CameraComboChanged)
Q_PROPERTY(QVariantList GufEntriesCombo READ GufEntriesCombo WRITE
SetGufEntriesCombo NOTIFY GufEntriesComboChanged)
// QObjects are expected to support a parent/child hierarchy
explicit BackEnd(QQuickView *view, QObject *parent = 0);
~BackEnd();
const QVariantList CameraCombo();
void SetCameraCombo(const QVariantList &cameraCombo);
const QVariantList GufEntriesCombo();
void SetGufEntriesCombo(const QVariantList &cameraCombo);
signals:
void CameraComboChanged();
void GufEntriesComboChanged();
public slots:
void BtnScan();
void BtnOpenGuf(const QString &path);
void BtnStartUpdate(const int gufEntryIdx, const QString &selCamera);
void UpdateGufEntryInfo(const int &gufEntryIdx);
private:
void ShowStatus(const std::string &statusMessage);
void ShowGufContent(const std::string &statusMessage);
void ListAvailableDevices();
QQuickView *view_;
QQmlContext *context_;
QVariantList cameraCombo_;
QVariantList gufEntriesCombo_;
Cvb::String gufFilePath_;
std::map<Cvb::String, int32_t> deviceMap_;
std::vector<Cvb::String> gufFileEntries_;
std::unique_ptr<Cvb::GenApi::FWUpdater> fwupdater_;
std::vector<Cvb::DiscoveryInformation> discover_;
// The QmlFirmwareUpdater example starts a QML FirmwareUpdater which can load a device and stream the
// device image.
#include <QApplication>
#include <QIcon>
#include <QMetaType>
#include <QQuickStyle>
QQuickStyle::setStyle("Windows");
QQuickStyle::setFallbackStyle("Universal");
QApplication app(argc, argv);
app.setOrganizationName("STEMMER IMAGING");
app.setOrganizationDomain("https://www.stemmer-imaging.com/");
app.setApplicationName("FirmwareUpdater C++ tutorial");
QQuickView *view = new QQuickView;
view->setResizeMode(QQuickView::SizeRootObjectToView);
view->setIcon(QIcon(":/qttutorial.png"));
view->resize(640, 390);
view->show();
// Set context property before creating QML file
BackEnd be(view);
view->rootContext()->setContextProperty("backEnd", &be);
// Load main QML file
view->setSource(QUrl::fromLocalFile("../main.qml"));
return app.exec();
