Image Manager/Cvb++/CppStreamConsoleWithMock
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/Cvb++/CppStreamConsoleWithMock.
// Demonstrates how image acquisition can be accomplished by using a mock GenTL Producer, so called
// CVMockTL.
#include <string>
#include <cvb/driver/image_stream.hpp>
#include <cvb/global.hpp>
static const constexpr int DELIVERABLE_COUNT =
10; // Number of deliverables to be acquired
// Retrieve CVMockTL in the given system.
Cvb::DiscoverFlags::IgnoreVins | // Ignores all of the CVB VINs.
Cvb::DiscoverFlags::IncludeMockTL // Include CVMockTL.
// Make sure if CVMockTL is on the candidate list.
Cvb::String accessToken;
for (auto n = 0; (n < infoList.size()) && accessToken.empty(); ++n)
if (infoList.at(n).AccessToken().find("MockTL") != std::string::npos)
accessToken = infoList.at(n).AccessToken();
if (accessToken.empty())
throw std::runtime_error("Could not find CVMockTL.");
// Instantiate a GenICam device from the CVMockTL.
accessToken, Cvb::AcquisitionStack::GenTL);
// Get the first stream of the device and start data streaming.
auto stream = device->Stream<Cvb::ImageStream>();
stream->Start();
for (auto m = 0; m < DELIVERABLE_COUNT; ++m) {
std::cout << "Acquisition #" << m << "\t";
// Wait for a single deliverable with a 10-second timeout value.
auto waitResult = stream->WaitFor(std::chrono::seconds(10));
if (std::get<Cvb::WaitStatus>(waitResult) == Cvb::WaitStatus::Timeout)
throw std::runtime_error("Acquisition timeout.");
// Verify the acquired deliverable contents.
auto deliverable = std::get<Cvb::MultiPartImagePtr>(waitResult);
// Retrieve the images in the deliverable.
for (auto n = 0; n < deliverable->NumParts(); ++n) {
auto item = deliverable->GetPartAt(n);
if (Cvb::holds_alternative<Cvb::ImagePtr>(item)) {
auto &image = Cvb::get<Cvb::ImagePtr>(item);
std::cout << "Image property: Part index: " << n
<< ", Width : " << image->Width()
<< ", Height : " << image->Height() << ", ";
// Retrieve VinBuffer node map
auto &enumerator = std::get<Cvb::NodeMapEnumerator>(waitResult);
const auto names = enumerator.Names();
if (std::all_of(names.begin(), names.end(), [](const Cvb::String &name) {
return name != "VinBuffer";
throw std::runtime_error("The nodemap enumerator of this container "
"does not contain a VinBuffer node map.");
auto nodeMap = enumerator.NodeMap(CVB_LIT("VinBuffer"));
// Incompleteness indicates a corrupt buffer
auto isIncompleteNode =
nodeMap->TryGetNode<Cvb::BooleanNode>(CVB_LIT("IsIncomplete"));
std::cout << "IsIncomplete: " << isIncompleteNode->Value() << ", ";
// The ID of the frame that is transported in the corresponding buffer
auto frameIDNode =
nodeMap->TryGetNode<Cvb::IntegerNode>(CVB_LIT("FrameID"));
std::cout << "FrameID: " << frameIDNode->Value() << ", ";
// The total number of bytes written into the buffer
auto sizeFilledNode =
nodeMap->TryGetNode<Cvb::IntegerNode>(CVB_LIT("SizeFilled"));
std::cout << "SizeFilled: " << sizeFilledNode->Value() << ", ";
// The width of the frame transported in the corresponding buffer
auto widthNode = nodeMap->TryGetNode<Cvb::IntegerNode>(CVB_LIT("Width"));
std::cout << "Width: " << widthNode->Value() << ", ";
// The height of the frame transported in the corresponding buffer
auto heightNode =
nodeMap->TryGetNode<Cvb::IntegerNode>(CVB_LIT("Height"));
std::cout << "Height: " << heightNode->Value() << ", ";
// Padding in x-direction
auto xPaddingNode =
nodeMap->TryGetNode<Cvb::IntegerNode>(CVB_LIT("XPadding"));
std::cout << "XPadding: " << xPaddingNode->Value() << ", ";
// Padding in y-direction
auto yPaddingNode =
nodeMap->TryGetNode<Cvb::IntegerNode>(CVB_LIT("YPadding"));
std::cout << "YPadding: " << yPaddingNode->Value() << ", ";
// Timestamp (UINT64) the buffer was acquired
auto timestampNode =
nodeMap->TryGetNode<Cvb::IntegerNode>(CVB_LIT("Timestamp"));
std::cout << "Timestamp: " << timestampNode->Value() << std::endl;
// Try aborting data streaming.
stream->TryAbort();
bool Value() const
void Start() override
std::int64_t Value() const
