Image Manager/Cvb++/CppStreamConsole
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/Cvb++/CppStreamConsole.
// The CppStreamConsole example shows how to stream from a GenICam device.
#include <cvb/utilities/system_info.hpp>
path += CVB_LIT("drivers/GenICam.vin");
// use command line argument if provided.
if (argc > 1) {
std::string inputPath(argv[1]);
path = Cvb::String(inputPath.begin(), inputPath.end());
// expand environment variables in path
path = Cvb::ExpandPath(path);
// open a device
auto device = Cvb::DeviceFactory::Open(path, Cvb::AcquisitionStack::Vin);
// get the first stream of the device
// to get another stream call Stream(index)
// start the stream - start the acquisition
stream->Start();
for (int i = 0; i < 10; ++i) {
// wait for an image with a timeout of 10 seconds
auto waitResult = stream->WaitFor(std::chrono::seconds(10));
if (waitResult.Status == Cvb::WaitStatus::Timeout)
throw std::runtime_error("acquisition timeout");
// get the timestamp of the image (usually a large integer number mapped
// to double - so better use fixed formatting)
std::cout << "Acquired image... " << std::fixed
<< waitResult.Image->RawTimestamp() << std::endl;
// synchronously stop the stream
stream->Stop();
