Image Manager/Cvb++/CppSingleStreamComposite
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/Cvb++/CppSingleStreamComposite.
// Example for streaming a single composite.
#include <string>
#include <vector>
#include <cvb/global.hpp>
static const constexpr int NUM_ELEMENTS_TO_ACQUIRE =
10; // number of elements to be acquired
{Cvb::WaitStatus::Timeout, "timeout"}, {Cvb::WaitStatus::Abort, "abort"}};
// discover transport layers
auto infoList =
// can't continue the demo if there's no available device
if (infoList.empty())
throw std::runtime_error(
// instantiate the first device in the discovered list
// access the first data stream that belongs to the device:
auto dataStream = device->Stream<Cvb::CompositeStream>();
// start the data acquisition
dataStream->Start();
// acquire data
auto [composite, waitStatus, enumerator] = dataStream->WaitFor(TIMEOUT);
switch (waitStatus) {
case Cvb::WaitStatus::Abort:
std::cout << "wait status not ok: " << WAIT_ERROR_STATES[waitStatus]
<< "\n";
continue;
case Cvb::WaitStatus::Ok: {
// assume the composites first element is an image
auto firstElement = composite->ItemAt(0);
if (!Cvb::holds_alternative<Cvb::ImagePtr>(firstElement)) {
std::cout
<< "composite does not contain an image at the first element\n";
continue;
auto image = Cvb::get<Cvb::ImagePtr>(firstElement);
auto linearAccess = image->Plane(0).LinearAccess();
std::cout << "acquired image: " << i << " at memory location: "
<< reinterpret_cast<intptr_t>(linearAccess.BasePtr()) << "\n";
// stop the data acquisition, ignore errors
dataStream->Stop();
void Start() override
