Image Manager/Cvb++/CppCompositeStreamHandler
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/Cvb++/CppCompositeStreamHandler.
// Example for streaming composites.
#include <condition_variable>
#include <string>
#include <vector>
#include <cvb/async/async.hpp>
#include <cvb/async/stream_handler_base.hpp>
#include <cvb/global.hpp>
static const constexpr int NUM_ELEMENTS_TO_ACQUIRE =
10; // number of elements to be acquired
{Cvb::WaitStatus::Timeout, "timeout"}, {Cvb::WaitStatus::Abort, "abort"}};
// derives the CompositeStreamHandler class so that we can implement our own
// customized tasks for the demonstration.
class CustomStreamHandler final : public Cvb::Async::CompositeStreamHandler {
struct PrivateTag {};
return std::make_unique<CustomStreamHandler>(streams, PrivateTag{});
explicit CustomStreamHandler(
PrivateTag)
: Cvb::Async::CompositeStreamHandler(streams), numDeliverables_(0) {}
std::cv_status
WaitUntil(std::unique_lock<std::mutex> &lock,
const std::chrono::system_clock::time_point &absTime) {
return observer_.wait_until(lock, absTime);
private:
// asynchronously called for all registered streams.
&streams) override {
// the following code is the same as the default implementation;
// this is just to demonstrate that you can freely override depending on
// your demand.
std::vector<Cvb::WaitResultTuple<Cvb::Composite>> waitResultList;
waitResultList.reserve(streams.size());
for (auto n = 0; n < streams.size(); ++n)
waitResultList.emplace_back(streams[n]->WaitFor(TIMEOUT));
// let it take care of the acquired deliverables.
HandleAsyncWaitResult(waitResultList);
// asynchronously called for all acquired deliverables.
const std::vector<Cvb::WaitResultTuple<Cvb::Composite>> &waitResultList)
override {
// the default implementation does nothing; you may add tasks by yourself.
std::cout << "round: #" << numDeliverables_ << "\n";
// iterate over the streams.
for (auto m = 0; m < waitResultList.size(); ++m) {
// check the wait status.
auto waitStatus = std::get<Cvb::WaitStatus>(waitResultList[m]);
std::cout << "stream #" << m << "\n";
std::cout << "wait status: ";
if (waitStatus != Cvb::WaitStatus::Ok) {
switch (waitStatus) {
case Cvb::WaitStatus::Abort:
case Cvb::WaitStatus::Timeout:
std::cout << WAIT_ERROR_STATES[waitStatus];
std::cout << "unknown";
std::cout << "; no deliverable is available.\n";
continue; // work on the next stream.
} else
std::cout << "ok\n";
// pick up the delivered composite.
auto composite = std::get<Cvb::CompositePtr>(waitResultList[m]);
// identify the deliverable type of each item.
const auto numItems = composite->ItemCount();
std::cout << "number of items: " << numItems << "\n";
for (auto n = 0; n < numItems; ++n) {
auto item = composite->ItemAt(n);
auto item_type = std::string("unknown");
if (Cvb::holds_alternative<Cvb::ImagePtr>(item))
item_type = "image";
else if (Cvb::holds_alternative<Cvb::PlanePtr>(item))
item_type = "plane";
else if (Cvb::holds_alternative<Cvb::PlaneEnumeratorPtr>(item))
item_type = "plane enumerator";
else if (Cvb::holds_alternative<Cvb::BufferPtr>(item))
item_type = "buffer";
else if (Cvb::holds_alternative<Cvb::PFNCBufferPtr>(item))
item_type = "pfnc buffer";
std::cout << "composite item #" << n << ": " << item_type << "\n";
std::cout << "\n";
++numDeliverables_;
if (numDeliverables_ == NUM_ELEMENTS_TO_ACQUIRE)
observer_.notify_all();
private:
std::condition_variable observer_;
int numDeliverables_;
// enumerate devices.
auto infoList =
// cannot continue the demonstration if CVMockTL is not present
Cvb::String accessToken;
for (const auto &info : infoList)
if (info.AccessToken().find("MockTL") != Cvb::String::npos)
accessToken = info.AccessToken();
if (accessToken.empty())
throw std::runtime_error(
"there is no available device for this demonstration.");
// instantiate the first device on the list; however, it is worth knowing
// that you can bind streams of other devices to a stream handle if needed.
infoList.front().AccessToken(), Cvb::AcquisitionStack::GenTL);
// create a stream handler.
// IMPORTANT: this tutorial assumes that each stream is synchronized, i.e.,
// it is running at the same acquisition frame rate; if any of them is out
// of sync the application will lose images. if any of the streams are not
// synchronized, please consider preparing a dedicated stream handler object
// for every single stream.
std::vector<Cvb::CompositeStreamPtr> streams;
streams.reserve(device->StreamCount());
for (auto n = 0; n < device->StreamCount(); ++n)
streams.emplace_back(device->Stream<Cvb::CompositeStream>(n));
auto handler = CustomStreamHandler::Create(streams);
// start the data acquisition.
handler->Run();
// wait for the job is done.
std::mutex mutex;
std::unique_lock<std::mutex> lock(mutex);
if (std::cv_status::no_timeout !=
handler->WaitUntil(lock, std::chrono::system_clock::now() + TIMEOUT))
throw std::runtime_error("could not complete the job");
// stop the data acquisition, ignore errors.
handler->TryFinish();
virtual void HandleAsyncWaitResult(const std::vector< WaitResult< typename Internal::DeliverableTraits< STREAMTYPE >::type > > &waitResultVector)
std::vector< StreamPtrType > StreamVectorType
static std::unique_ptr< StreamHandlerBase > Create(const StreamVectorType &streamVector)
virtual void HandleAsyncStream(const StreamVectorType &streamVector)
StreamHandlerBase< CompositeStream > CompositeStreamHandler
std::tuple< std::shared_ptr< T >, WaitStatus, NodeMapEnumerator > WaitResultTuple
