Image Manager/Cvb++/CppCameraIPConfig
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/Cvb++/CppCameraIPConfig.
// Example for discovering all your interfaces (NICS & USB HCs).
// currently there is no way to filter out USB HCs
#include <cvb/composite.hpp>
#include <cvb/driver/multi_part_image.hpp>
#include <cvb/plane_enumerator.hpp>
#include <cvb/utilities/utilities.hpp>
auto interfaceInfoList = Cvb::DeviceFactory::Discover(
Cvb::DiscoverFlags::IgnoreGevFD | Cvb::DiscoverFlags::IgnoreVins |
Cvb::DiscoverFlags::UpToLevelInterface,
std::chrono::milliseconds(2000));
for (int i = 0; i < interfaceInfoList.size(); i++) {
std::string mac = "No MAC available";
interfaceInfoList[i].TryGetProperty(Cvb::DiscoveryProperties::InterfaceMac,
mac);
std::cout << mac << " | Index: " << i << std::endl;
std::cout
<< "Please enter the index of the interface your device is connected to:"
<< std::endl;
std::cout << "(You can check the mac addresses in the GenICamBrowser)"
<< std::endl;
int index = -1;
std::cin >> index;
while (index < 0 || index > interfaceInfoList.size() || std::cin.fail()) {
std::cin.clear();
std::cin.ignore(std::numeric_limits<std::streamsize>::max(), '\n');
std::cout << "Invalid index, please enter a valid number:" << std::endl;
std::cin >> index;
auto &interfaceInfo = interfaceInfoList[index];
// Do a broadcast discovery and allow devices from another subnet to answer.
interfaceInfo.SetGenApiFeature(CVB_LIT("TLInterface"),
CVB_LIT("Cust::DisableSubnetMatch"),
CVB_LIT("1"));
CVB_LIT("TLInterface"), CVB_LIT("Cust::AllowBroadcastDiscoveryResponse"),
CVB_LIT("1"));
// Discover again only devices connected to your interface!
// Include also devices that are inaccessible (might be because they are in
// use or in a different subnet)
Cvb::DiscoverFlags::UpToLevelDevice |
Cvb::DiscoverFlags::IncludeInaccessible,
auto interfaceDevice =
Cvb::DeviceFactory::Open(interfaceInfo.AccessToken());
auto interfaceNM = interfaceDevice->NodeMap(CVB_LIT("TLInterface"));
// get all required nodes
auto deviceUpdateListNode =
interfaceNM->Node<Cvb::CommandNode>(CVB_LIT("DeviceUpdateList"));
auto ipNode =
interfaceNM->Node<Cvb::IntegerNode>(CVB_LIT("GevDeviceForceIPAddress"));
auto subnetNode = interfaceNM->Node<Cvb::IntegerNode>(
CVB_LIT("GevDeviceForceIPSubnetMask"));
auto forceIPNode =
interfaceNM->Node<Cvb::CommandNode>(CVB_LIT("GevDeviceForceIP"));
auto configurationStatusNode = interfaceNM->Node<Cvb::EnumerationNode>(
CVB_LIT("GevDeviceIPConfigurationStatus"));
// make node map aware of the device
deviceUpdateListNode->Execute();
// we want to set the ip static, but before, it has to be set temporarily
// needs to be set before ip so ip node is writeable
configurationStatusNode->SetValue("TemporaryIP");
// IP can be 10.0.0.2.
ipNode->SetValue(0x0A000002);
// Subnet 255.255.255.0
subnetNode->SetValue(0xFFFFFF00);
// Force the new IP
forceIPNode->Execute();
// make node map aware of new IP
// now we can set it persistently
configurationStatusNode->SetValue("PersistentIP");
// same address
// Force the new IP
// Done, now you can see in the GC Browser, that the camera is in the same
// subnet as the NIC
void SetValue(std::int64_t value)
