using System.Linq;
namespace Multistream
class Multistream
var executeWithMock = args.Length > 0 && args.First().Equals("--mock");
var flags = DiscoverFlags.IgnoreVins | (executeWithMock ? DiscoverFlags.IncludeMockTL : 0);
if (devices.Count < 1)
Console.WriteLine("No devices found.");
var targetDiscoveryInfo = devices.First();
if (executeWithMock)
var foundMock = false;
foreach (var info in devices)
info.AccessToken.Contains("MockTL");
targetDiscoveryInfo = info;
foundMock = true;
if (!foundMock)
Console.WriteLine("Could not find CVMockTL.");
using var device = DeviceFactory.Open(targetDiscoveryInfo,
AcquisitionStack.GenTL);
var streams = Enumerable.Range(0, device.StreamCount).Select(i => ((GenICamDevice)device).GetStream<ImageStream>(i)).ToArray();
Console.WriteLine($"Stream Count: {streams.Length}");
foreach (var stream in streams)
stream.EngineStart();
stream.DeviceStart();
for (int imageIndex = 0; imageIndex < 10; imageIndex++)
var streamIndex = -1;
++streamIndex;
using var composite = stream.Wait(out WaitStatus status);
using var nodeMaps = NodeMapDictionary.FromImage(composite);
var imagePlane = composite.Planes.ElementAt(0);
Console.WriteLine(
$"Stream #{streamIndex}, " +
$"Image #{imageIndex}, " +
$"Width: {composite.Size.Width}, " +
$"Height: {composite.Size.Height}");
stream.DeviceAbort();
stream.EngineAbort();
