ImageManager/Cvb.Net/Multipart
This example program is located in your CVB installation under %CVB%Tutorial/ImageManager/Cvb.Net/Multipart.
Program.cs:
// Example for acquiring multi part images.
namespace Multipart
class Multipart
using var devices = DeviceFactory.Discover(DiscoverFlags.IgnoreVins);
using var device = DeviceFactory.Open(devices[0], AcquisitionStack.GenTL);
var stream = ((GenICamDevice)device).GetStream<CompositeStream>(0);
stream.Start();
for (int i = 0; i < 10; i++)
using (Composite composite = stream.Wait(out WaitStatus status))
using var nodeMaps = NodeMapDictionary.FromComposite(composite);
Console.WriteLine($"Acquired composite: {i} with purpose: {composite.Purpose}");
foreach (var part in composite)
Console.WriteLine($"Part of composite is of type {part.GetType()}");
// using the type you can check which specific object is in the part
// at this point you can cast the part to a specific object e.g.:
// if (part.GetType() == typeof(Image))
// var img = (Image)part;
Console.WriteLine();
stream.Abort();
static NodeMapDictionary FromComposite(Composite composite)
