ImageManager/Cvb.Net/DeviceConfiguration
This example program is located in your CVB installation under %CVB%Tutorial/ImageManager/Cvb.Net/DeviceConfiguration.
Program.cs:
// Example that demonstrates buffer updates when modifying a parameter that affects the buffer size.
namespace DeviceConfiguration
class DeviceConfiguration
using var devices = DeviceFactory.Discover(DiscoverFlags.IgnoreVins);
using var device = DeviceFactory.Open(devices[0], AcquisitionStack.GenTL);
// do some acquisition
var pixelFormat = nodes["PixelFormat"] as EnumerationNode;
try
// this is an example for changing buffer size with a
// nodemap entry (assume that Mono10 is supported)
pixelFormat.Value = "Mono10";
catch
// handle the error if setting the value failed
// update the flow_set_pool (buffers)
stream.DeregisterFlowSetPool();
Console.WriteLine($"Pixel format set to: {pixelFormat.Value}");
stream.Start();
for (int i = 0; i < 10; i++)
using var composite = stream.Wait(out WaitStatus status);
using var nodeMaps = NodeMapDictionary.FromImage(composite);
Console.WriteLine($"Acquired image: {i}");
stream.Abort();
DeviceNodeMapDictionary NodeMaps
