Foundation/Cvb.Net/Metric3DCalibrationRigidBodyTransform
This example program is located in your CVB installation under %CVB%Tutorial/Foundation/Cvb.Net/Metric3DCalibrationRigidBodyTransform.
Program.cs:
// Example for a **rigid-body transformation** (extrinsic calibration) using the AQS12 target.
namespace Metric3DCalibration
using ExtensionMethods;
class Program
Console.Write("Estimation of a rigid body transformation (rotation and translation)\n\n");
var piece = GetAQS12Piece();
var rangeMap = Image.FromFile(@"%CVB%\Tutorial\Metric\Images\RangeMapCalibrationPattern.tif");
Console.Write("Rangemap loaded with size of " + rangeMap.Width.ToString() + " x " + rangeMap.Height.ToString() + " from ");
Console.Write(@"%CVB%\Tutorial\Metric\Images\RangeMapCalibrationPattern.tif" + "\n");
var calibrator = Calibrator3D.FromFile(@"%CVB%\Tutorial\Metric\Images\SICalibration.json");
var cloud = calibrator.CreatePointCloud(rangeMap, PointCloudFlags.Float);
Console.Write("Dense point cloud created from rangemap and calibration file with " + cloud.NumPoints + " points.\n\n");
var segmentor = new AQS12DensePointCloudSegmentor(SegmentationMethod.KmeansClustering)
// set a valid window size
WindowSize = 5
var trafo = Metric.CalculateRigidBodyTransformationFromAqs12Piece(cloud as DensePointCloud, segmentor, piece, out Point3Dd[] residuals);
calibrator.ExtrinsicMatrix = trafo.Item1;
trafo.Item1.ShowTransformation();
trafo.Item2.ShowTransformation();
Console.Write("Residuals:\n");
residuals.ShowXYZArray();
var calibratedCloud = calibrator.CreatePointCloud(rangeMap, PointCloudFlags.Float);
Console.Write("Number of points: " + calibratedCloud.NumPoints + "\n");
public static AQS12Piece GetAQS12Piece()
var points = new Point3Dd[]
new(20.0018, 44.9941, 15.0000),
new(24.0018, 39.9942, 14.9994),
new(23.9994, 24.9972, 15.0001),
new(20.0021, 20.0035, 15.0011),
new(15.9994, 25.0079, 15.0016),
new(16.0000, 39.9919, 15.0010),
new(20.0095, 59.9985, 4.9902),
new(32.0093, 44.9958, 4.9909),
new(32.0052, 19.9925, 4.9920),
new(20.0021, 4.9961, 4.9939),
new( 8.0024, 19.9980, 5.0009),
new( 8.0065, 45.0009, 4.9984)
return new AQS12Piece(points, 0);
namespace ExtensionMethods
public static class Extensions
public static void ShowTransformation(this AffineMatrix3D trafo)
System.Text.StringBuilder sMessage = new System.Text.StringBuilder();
sMessage.Append("Translation:\n");
sMessage.Append(trafo.Translation.ToString());
sMessage.Append("\n\nTransformation matrix:\n");
sMessage.Append(trafo.Matrix.ToString());
sMessage.Append("\n\n");
Console.Write(sMessage.ToString());
public static void ShowTransformation(this AffineTransformationParameters trafoPara)
sMessage.Append("Rotation angles in [degree] about\n");
sMessage.Append("X: " + trafoPara.RotationAngles[0].ToString("N4") + "\n");
sMessage.Append("Y: " + trafoPara.RotationAngles[1].ToString("N4") + "\n");
sMessage.Append("Z: " + trafoPara.RotationAngles[2].ToString("N4") + "\n\n");
public static void ShowXYZArray(this Point3Dd[] xyz)
sMessage.Append("Point \t X \t Y \t Z \n");
for (int i = 0; i < 12; i++)
sMessage.Append(i + 1 + "\t" + xyz[i].X.ToString("N4") + " " + xyz[i].Y.ToString("N4") + " " + xyz[i].Z.ToString("N4") + "\n");
sMessage.Append("\n");
} // namespace ExtensionMethods
PointCloud CreatePointCloud(Image rangeMap)
static Calibrator3D FromFile(string fileName)
static Tuple< AffineMatrix3D, AffineTransformationParameters > CalculateRigidBodyTransformationFromAqs12Piece(DensePointCloud cloud, AQS12DensePointCloudSegmentor segmentor, AQS12Piece piece, out Point3Dd[] residuals)
__int3264 Image
readonly override string ToString()
