namespace Metric3DCalibration
using ExtensionMethods;
class Program
Console.Write("Estimation of an affine transformation(correcting an inclined laser plane)\n\n");
var piece = GetAQS12Piece();
config.CalculateHomography = false;
var rangeMap =
Image.FromFile(
@"%CVB%\Tutorial\Metric\Images\RangeMapCalibrationPattern.tif");
Console.Write("Rangemap loaded with size of " + rangeMap.Width.ToString() + " x " + rangeMap.Height.ToString() + " from ");
Console.Write(@"%CVB%\Tutorial\Metric\Images\RangeMapCalibrationPattern.tif" + "\n");
Console.Write("Dense point cloud created from rangemap and calibration file with " + cloud.NumPoints + " points.\n\n");
calibrator.CorrectionOfLaserPlaneInclination.Item1.Value.ShowTransformation();
calibrator.CorrectionOfLaserPlaneInclination.Item2?.ShowTransformation();
Console.Write("Residuals:\n");
residuals.ShowXYZArray();
double desiredAccuracy = 0.05;
if (!residuals.CheckAccuracy(desiredAccuracy))
Console.Write("Results do not have desired accuracy. Check face segmentation and extracted AQS12 points...\n");
var pointsAqs12 = segmentor.ExtractProjectedPointsFromPiece(cloud as
DensePointCloud);
Console.Write("Extracted points from point cloud:\n");
pointsAqs12.ShowXYZArray();
var calibratedCloud = calibrator.CreatePointCloud(rangeMap,
PointCloudFlags.Float);
Console.Write("The calibration was sucessful and accuracy is < " + desiredAccuracy.ToString() +
$" mm. :)\nPointCloud has the following DataType: {calibratedCloud.DataType}");
public static AQS12Piece GetAQS12Piece()
var points = new Point3Dd[]
new(20.0018, 44.9941, 15.0000),
new(24.0018, 39.9942, 14.9994),
new(23.9994, 24.9972, 15.0001),
new(20.0021, 20.0035, 15.0011),
new(15.9994, 25.0079, 15.0016),
new(16.0000, 39.9919, 15.0010),
new(20.0095, 59.9985, 4.9902),
new(32.0093, 44.9958, 4.9909),
new(32.0052, 19.9925, 4.9920),
new(20.0021, 4.9961, 4.9939),
new( 8.0024, 19.9980, 5.0009),
new( 8.0065, 45.0009, 4.9984)
return new AQS12Piece(points, 0);
namespace ExtensionMethods
public static class Extensions
public static void ShowTransformation(this AffineMatrix3D trafo)
System.Text.StringBuilder sMessage = new System.Text.StringBuilder();
sMessage.Append("Translation:\n");
sMessage.Append("\n\nTransformation matrix:\n");
sMessage.Append("\n\n");
Console.Write(sMessage.ToString());
public static void ShowTransformation(this AffineTransformationParameters trafoPara)
sMessage.Append("Rotation angles in [degree] about\n");
sMessage.Append("Inclination of laser plane in [degree] about\n");
sMessage.Append(
"X: " + trafoPara.
InclinationX.ToString(
"N4") +
"\n");
sMessage.Append(
"Z: " + trafoPara.
InclinationZ.ToString(
"N4") +
"\n\n");
sMessage.Append("Shear\n");
sMessage.Append(
"Syz: " + trafoPara.
Syz.ToString(
"N5") +
"\n");
sMessage.Append(
"Syx: " + trafoPara.
Syx.ToString(
"N5") +
"\n\n");
sMessage.Append("Scale\n");
sMessage.Append(
"X: " + trafoPara.
Scale.
X.ToString(
"N3") +
"\n");
sMessage.Append(
"Y: " + trafoPara.
Scale.
Y.ToString(
"N3") +
"\n");
sMessage.Append(
"Z: " + trafoPara.
Scale.
Z.ToString(
"N3") +
"\n\n");
public static void ShowXYZArray(this Point3Dd[] xyz)
sMessage.Append("Point \t X \t Y \t Z \n");
for (int i = 0; i < 12; i++)
sMessage.Append(i + 1 + "\t" + xyz[i].X.ToString("N4") + " " + xyz[i].Y.ToString("N4") + " " + xyz[i].Z.ToString("N4") + "\n");
sMessage.Append("\n");
public static bool CheckAccuracy(this Point3Dd[] residuals, double desiredAccuracy)
foreach (Point3Dd residual in residuals)
if (residual.
X > desiredAccuracy || residual.
Y > desiredAccuracy || residual.
Z > desiredAccuracy)
return false;
return true;
PointCloud CreatePointCloud(Image rangeMap)
static Calibrator3D FromFile(string fileName)
static CalibrationConfiguration FromAQS12Piece(AQS12Piece piece)
static Tuple< AffineMatrix3D, AffineTransformationParameters?> CalculateCorrectionOfLaserPlaneInclinationFromAqs12Piece(DensePointCloud cloud, AQS12DensePointCloudSegmentor segmentor, CalibrationConfiguration config, out Point3Dd[] residuals)
readonly override string ToString()
