Interfacing CVB to 3rd Party Imaging Libraries
Although Common Vision Blox comes with a variety of algorithms tailored to many different imaging and machine vision applications, there are sometimes good reasons to combine Common Vision Blox with other libraries in one application. Luckily, Common Vision Blox provides the necessary utilities to do so sometimes even at minimal or almost no CPU cost. This guide shows how to use Common Vision Blox together with libraries like OpenCV, IPP, Halcon or others.
1. About this guide
To avoid lengthy wordings we will use the following abbreviations throughout this text:
Acronym Meaning
CVB as always, CVB is short for Common Vision Blox
IPP Short for "Intel Performance Primitives", a highly optimized and renowned imaging algorithm library
VPAT Virtual Pixel Access Table – an image data access scheme available in CVB
Although we have chosen OpenCV, IPP and Halcon as examples, it is evident that the methods and approaches outlined in this document are applicable to any library that provides access to the necessary data structures and information.
All products and libraries are property of their respective trademark holders and mention of these libraries/products does not imply an endorsement of Common Vision Blox by these companies or vice versa.
Please note that it is assumed that the reader has a firm grasp of C/C++, especially the use of pointers and pointer arithmetic – both are going to be used extensively throughout this document but will not be explained in detail. It is also assumed, that the reader is sufficiently familiar with Common Vision Blox, OpenCV, IPP or Halcon as none of those libraries will be explained beyond the extent immediately necessary for this guide.
With the exception of chapter 2, the chapters of this guide may be read independently or in sequence. Their summarized contents are:
  • Chapter 2 Explains some basic concepts that will be the foundation of the methods explained in chapter 3 and 4. It is recommended to read this chapter first, especially if you are not yet very familiar with the image model of CVB.
  • Chapter 3 Explains how images from a 3rd party library may be used inside CVB.
  • Chapter 4 Explains how images from CVB may be used inside a 3rd party library.
  • Chapter 5 Gives hints about transferring the recipes outlined in chapter 3 and 4 from C/C++ (which is the main focus of this guide) to other programming languages.  
2. Basic Concepts
Image Models
The fundamental reason why it is not possible to simply pass images/image data between any pair of two machine vision libraries (or sometimes even between the Windows SDK or the Common Language Runtime and a machine vision library) is that there is no universally agreed format for the description of images that is understood and accepted by more than one library (or at best: by more than just a few libraries).
The main reasons for this are:
  • the fact that different libraries emphasize different aspects of image processing; for example, OpenCV and IPP don’t need to concern themselves too much with image acquisition and therefore do not need something like the ring buffer handling that is found e.g. in CVB or Sapera.
  • different capabilities of different libraries; floating point valued images are for example of no practical use to the Windows SDK, whereas in CVB and in IPP they play an important role for a variety of operations like FFT or Wavelet Transforms.
  • different approaches to the representation of image data in a particular library. CVB for example is working with VPATs, offset tables that allow for e.g. RGB<-->BGR transformation, simple deinterlacing or resizing of image data without actually transforming the image’s pixel data in memory but through manipulating the VPATs that define the software’s perception of the image data. The VPAT access interface in CVB allows for variable views to the same image data and used to be a particularly valuable asset at a time when almost no frame grabber had the necessary hardware on board to sort image data from e. g. multi tap cameras into a proper memory layout.
Not surprisingly the key to bridging the gap between any two libraries is to translate and/or transform the image model of library A to fit that of library B. Often (but not always) this can even be achieved without copying the image data. Of course, doing so requires knowledge of the data structures involved as well as the capabilities of the libraries involved.
The Image Model of CVB
Data Types
Data type in this context refers to the data type of an individual pixel inside an image (i.e. if the memory address of a pixel is known, what data type will the pointer need to be cast to for dereferencing it properly).
CVB stores all the information it provides about the data type of an image’s pixel in a 32 bit value that is composed as follows:
31-12 11 10 9 8 7-0
reserved complex number? overlay? floating point number? signed number? bits per pixel
  • Bit 0 to 7 specify the number of bits per pixel that are being used. Note that this number gives the number of bits per pixel that have actually been used. The number of padding bits that might have been added is not reflected in the data type descriptor. For example, the "bits per pixel" value may be 10, but the number of bits consumed in memory by each pixel is in this case at least 16 (pixels and components in CVB images are always aligned at byte boundaries).
  • Bit 8 indicates whether or not the pixel data type is signed. In case of floating-point-valued pixels this bit will be meaningless.
  • Bit 9 indicates whether or not the pixel data type is float. If this bit is not set, it is safe to assume that the pixel data type is an integer type.
  • Bit 10 indicates whether or not bit 0 is to be interpreted as an overlay mask. This overlay-mask concept is specific to some CVB tools, but otherwise meaningless.
The 32-bit value built after this recipe specifies the data type of an image plane's pixels. CVB in theory offers the possibility of constructing an image where the planes have different data types, but this not commonly used and one would in fact need to go to great lengths to construct such an image using CVB functions. In short: Such a case will not be considered in this document.
It is obvious that in situations where the data type can be specified freely (for example when calling CreateGenericImageDT or CreateImageFromPointer), it is easily possible to build nonsensical combinations like 7-bit floating point – the functions will not return an error but do as they’re told. Therefore, common sense should be applied when constructing a CVB data type descriptor.
Beyond the usual 8 bit unsigned pixels (0x00000008) two additional data type descriptors that are being used frequently are 0x0000000A and 0x0000000C which correspond to 10- and 12-bit unsigned integer data. As there are no built-in types with that size in any commonly used programming language it is up to the user to make sure that during operations on images of this type the range of valid values is not exceeded. Internally these formats are always stored in 16 bits per pixel and can be accessed like 16-bit integer data (i.e. through an unsigned short *). Note that the widespread notion of considering RGB a 24 bit per pixel format does not apply to CVB (instead, this would be considered an image with 3 planes at 8 bits per pixel).
If we ignore the reserved bits and the overlay mask bit (which has no correspondence in the OpenCV, IPP or Halcon pixel data types), then we end up using the following data type descriptors for the most commonly used pixel data types:
Descriptor & 0x3FF C/C++ data type
0x00000008 unsigned char
0x00000108 (signed) char
0x00000010 unsigned short
0x00000110 (signed) short
0x00000020 unsigned int
0x00000120 (signed) int
0x00000220,
0x00000320
float
0x00000240,
0x00000340
double
CVB treats the pixel data type, the memory layout, and the color/channel interpretation of an image completely separate. Of course, monochrome images are just images with one channel (usually called "plane" in the CVB documentation). RGB images are simply images with three such channels, but so would be images in the HSI or Lab color space. That means that the user is responsible for keeping track of the color format he is currently working on. The Common Vision Blox Display, when confronted with an image with 3 or more planes, will simply assume that plane 0 contains the red pixels, 1 one contains the green pixels and plane 2 contains the blue pixels.
Memory Layout
As already mentioned, CVB implements access to the image data through the so-called VPATs, two tables with offsets in x and y direction that can be combined with a base pointer to calculate the address of a pixel in memory. The base pointer and VPAT for an image plane can be queried using the function GetImageVPA:
// get base pointer and VPAT address
intptr_t pBase = 0;
PVPAT pVpat = nullptr;
GetImageVPA(cvbImg, 0, reinterpret_cast<void**>(&pBase), &pVpat);
// calculate address of pixel x = 19, y = 21:
intptr_t pPixel = pBase + pVpat[19].XEntry + pVpat[21].YEntry;
cvbbool_t GetImageVPA(IMG Image, cvbval_t PlaneIndex, void **ppBase, PVPAT *ppVPAT)
VPAEntry * PVPAT
intptr_t YEntry
intptr_t XEntry
This might look like an unnecessary overhead when compared to other libraries that often simply work on a base pointer and an increment in y direction to calculate a pixel’s address. But the VPATs not only allow CVB to easily cover practically all memory layouts that a 3rd party library may use – they also allow for neat tricks like merging two separate images into one (see function CreatePanoramicImageMap), rotating an image (see function CreateRotatedImageMap) or extracting a scaled portion of an image (see function CreateImageMap) – all without copying a single pixel.
Lifetime Management
Defining the lifetime of a large data object (like an image acquired from a camera that may easily contain several megabytes of pixel data) is not as trivial as it may sound, and there is more than just one approach available for this issue. Probably the two most commonly encountered patterns here are alloc/free (i.e., there’s a malloc-like allocation function and free-like cleanup function) and reference counting.
In CVB's C-API we have opted for the implementation of a reference counting model:
  • Every image object (i.e., every object access through a handle of type IMG) carries its own reference counter. In fact, the reference counting model in CVB is not limited to image objects – it also applies to several other stateful objects in CVB.
  • Every time the handle is passed to a consumer (a new function, a different thread or just a new copy of the handle) the reference count is/should be increased by calling ShareObject once.
  • Every time a consumer stops using a handle, its reference count is/should be decreased by calling ReleaseObject once.
  • If the reference count reaches 0, the image memory is freed.
(Luckily, when working with CVB.Net, CVBpy or CVB++ these error-prone and daunting tasks are hidden from users by smart pointers.)
This is important to be aware of, because other libraries typically follow different approaches. IPP for example simply provides functions to allocate and free image memory (and it is the caller’s responsibility to make sure both are being called, and at the right times), while e.g., Sapera uses C++ objects and the image memory’s lifetime is tied to the lifetime of the containing Sapera object instance.
The Image Model of OpenCV
Data Types
OpenCV typically describes the images it is working on using a structure called IplImage which was actually borrowed from the Intel Image Processing Library. The supported pixel data types for the OpenCV library are listed in the description of the depth member of the IplImage structure. The supported pixel data types are:
  • 8 bit signed and unsigned integer
  • 16 bit signed and unsigned integer
  • 32 bit signed integer
  • 32 bit float
  • 64 bit float
OpenCV supports images with 1 to 4 channels (nChannels member of IplImage). All channels share the same data type, and the memory layout may in theory be interleaved or planar, with interleaved being the predominant alternative (see description of the dataOrder member of IplImage).
Memory Layout
The memory of an OpenCV image is accessible through the imageData pointer in the IplImage. This refers to the C interface of OpenCV. If you are using the C++ interface of OpenCV please to the documentation to map the description to the C++ interface. The data pointer together with the widthStep member (y increment) allow for the calculation of the address of each pixel in the image.
Lifetime Management
An OpenCV image comes into existence when it is created using one of the creation functions (like e.g., cvCreateImage) and can be destroyed using e.g. cvReleaseImage.
The Image Model of IPP
The image processing functions in the IPP (Intel® Integrated Performance Primitives for Intel® Architecture) are a little more basic than those of the OpenCV library. Unlike OpenCV, IPP does not use a structure to collect the information necessary to process image data – memorizing and organizing that data is solely the programmer’s responsibility.
Data Types
On functions that process image data, IPP supports the following data types:
  • 32 bit signed integer and 32 bit float
  • 32 bit signed integer and 32 bit float complex
The complex data type is only used by a very limited set of functions. Like OpenCV, IPP supports images with 1 to 4 channels. In case of 4 channels, one channel may be used for transparency information (alpha channel).
Memory Layout
Like OpenCV, IPP supports interleaved and planar data arrangement, with interleaved arrangement again being the predominant memory layout. The image data is being accessed through the base pointer and the vertical increment. Note that due to the fact that IPP contains many functions that have been optimized for Intel’s SSE units, it is necessary that a memory block for IPP to work on is aligned on a 32 byte boundary and that the start of each line of an image lies on a 4 byte boundary.
Lifetime Management
As IPP offers no structure to contain the image data, there is only a function available to allocate memory blocks that fit the requirements of IPP (ippiMalloc), and a function to free these memory blocks (ippiFree).
The Image Model of Halcon
Data Types
Halcon uses pixel types that are somewhat similar to CVB's data type descriptors mentioned earlier. These pixel types map to the C types uint8_t, int8_t, int32_t, and float as well as composed types
Preprocessor define Type ID Meaning
BYTE_IMAGE (int)1 1 byte per pixel (0..255)
INT4_IMAGE (int)2 Type: 4 bytes per pixel (int32_t)
LONG_IMAGE (int)2 4 byte per pixel (int32_t)
FLOAT_IMAGE (int)4 4 byte per pixel (float)
DIR_IMAGE (int)8 edge orientation 0..180
CYCLIC_IMAGE (int)16 0..255 cyclic
INT1_IMAGE (int)32 -128..127
COMPLEX_IMAGE (int)128 2 float images
INT2_IMAGE (int)512 2 bytes with sign
UINT2_IMAGE (int)1024 Type: 2 bytes (unsigned short)
VF_IMAGE (int)2048 Two float images
INT8_IMAGE (int)4096 8 byte per pixel (int64_t)
Memory Layout
Gray value images are represented by a rectangular image matrix. Several matrices (called channels) can be combined to a multi-channel image. Each channel is stored separately, i. e. in Halcon the channels are never interleaved in memory. The pixel data is stored as a one-dimensional array (image vector) of one of the pixel types. The indices of the array range from 0 to width*height-1
Lifetime Management
All of HALCON’s classes, i. e. not only HImage, HRegion, HTuple, HFramegrabber etc., but also the class HObject used when calling operators in the procedural approach, release their allocated resources automatically in their destructor. There is no need to call the operator ClearObj in HALCON/C++. Actually, if you do call it HALCON will at some point complain about already released memory. To explicitly release the resources before the instance gets out of scope, you can call the method .Clear() of the instance.
3. Data Transfer from 3rd Party Libraries to CVB
The data/image transfer from 3rd party libraries to CVB is probably the easier direction – simply because thanks to the VPAT image model and the fairly versatile data type descriptor CVB covers many memory layouts and data types encountered in libraries like OpenCV or IPP. It is also noteworthy that in practically all relevant cases the import can happen without copying the image data – all that is needed is a very thin VPAT wrapper (that can be built by the function CreateImageFromPointer) which takes only a fraction of a millisecond to construct. Probably the only potential obstacle is lifetime management.
As the function CreateImageFromPointer is pivotal for importing 3rd party images into CVB, let’s have a detailed look at it:
IMPORT(cvbres_t) CreateImageFromPointer (
void *pImageMem, size_t MemSize,
cvbdim_t Width, cvbdim_t Height, cvbdim_t NumPlanes, cvbdatatype_t DataType,
intptr_t PitchX, intptr_t PitchY, intptr_t PitchPlane, cvbval_t PlaneOrder[],
PFFINALRELEASE ReleaseCallback, void *pUserData,
IMG &ImgOut);
void(* PFFINALRELEASE)(void *pBufferBase, void *pPrivate)
long cvbdatatype_t
void * IMG
cvbres_t CreateImageFromPointer(void *pImageMemory, size_t MemorySize, cvbdim_t Width, cvbdim_t Height, cvbdim_t NumPlanes, cvbdatatype_t DataType, intptr_t PitchX, intptr_t PitchY, intptr_t PitchPlane, const cvbval_t PlaneOrder[], PFFINALRELEASE ReleaseCallback, void *pPrivate, IMG &ImageOut)
Its parameters are:
  • pImageMem Pointer to the pixel data. When importing from OpenCV the pointer can be directly copied from IplImage::imageData.
  • MemSize
    Gives the size of the memory block pointed to by pImageMem. This value will only be used for consistency checks and should be at least Width * Height * NumPlanes * sizeof(pixeldatatype). When importing from OpenCV, the value IplImage::imageSize may be used here.
  • Width, Height
    Specify the width and height of the image to be imported. When importing from OpenCV these can be copied from IplImage::width and IplImage::height.
  • NumPlanes
    Specify the number of planes the CVB image should have. When importing from OpenCV, the value IplImage::nChannels may be used directly as it corresponds to the CVB plane count interpretation. Likewise with Halcon's number of channels indicator. With IPP, it is necessary to interpret the image type as one of the following: 8u, 8s, 16u, 16s, 32s, 32f, 32sc, 32fc. Note that in the unlikely case of dealing with 32sc or 32fc it might be a good idea to double the number of planes and treat e.g., a one-channel complex image as a 2-plane image with plane 0 being real and plane 1 being imaginary part.
IPP Image Type Number of Planes
ipp<data_type>C1 1
ipp<data_type>C2 2
ipp<data_type>C3 3
ipp<data_type>C4 4
ipp<data_type>AC4 3
ipp<data_type>P3 3
ipp<data_type>P4 4
  • DataType
    Pass a CVB data type descriptor that best fits the pixel format of each channel. The available OpenCV, IPP and Halcon data type descriptions map to CVB descriptors as follows:
OpenCV IPP Halcon CVB
IPL_DEPTH_8U ipp8u BYTE_IMAGE 0x00000008
IPL_DEPTH_8S ipp8s INT1_IMAGE 0x00000108
IPL_DEPTH_16U ipp16u UINT2_IMAGE 0x00000010
IPL_DEPTH_16S ipp16s INT2_IMAGE 0x00000110
IPL_DEPTH_32S ipp32s not available 0x00000120
IPL_DEPTH_32F ipp32f FLOAT_IMAGE 0x00000320
IPL_DEPTH_64F not available not available 0x00000340
  • PitchX, PitchY, PitchPlane
    These three pitch values will be needed by CreateImageFromPointer to build the VPAT wrapper around a 3rd party image. Although many users seem to struggle with these, their interpretation is fairly straightforward: If we know that p is the address of a pixel at the location (x, y, i) (with i being the plane index), then
    • p + PitchX gives the address of the pixel at the location (x+1, y, i)
    • p + PitchY gives the address of the pixel at the location (x, y+1, i)
    • p + PitchPlane gives the address of the pixel at the location (x, y, i+1)
      To determine the correct values for these pitches, it is necessary to look at the source image’s pixel data type as well as the source image’s memory layout! Luckily with OpenCV and IPP the number of possible permutations here is fairly limited.
OpenCV
Although OpenCV does in principle inherit the possibility to describe planar memory layouts from the IPL, it usually uses interleaved memory layouts only. With interleaved layout the pitch values need to be constructed as follows:
PitchX = IplImage::nChannels * sizeof(pixel_type)
PitchY = IplImage::widthStep
PitchPlane = sizeof(pixel_type)
Code Example
As the OpenCV library provides a lot of convenience functionality that IPP does not offer, we’ll only show a code sample for OpenCV here, but of course the principles apply to other 3rd party libraries as well. For the sake of brevity, error checking as well as using-, include- and linker statements have been omitted. Simply painting the image over the desktop is of course just a quick and dirty approach to displaying the image, but it reduces the amount of code necessary for displaying it to just one line.:
void __stdcall final_release(void* pBufferBase, void* pUserData)
IplImage* ocvImg = reinterpret_cast<IplImage*>(pUserData);
cvReleaseImage(&ocvImg);
int _tmain(int argc, _TCHAR* argv[])
// load a sample image string path = getenv("CVB");
path.append("\\Tutorial\\FruitBowl.jpg");
IplImage* ocvImg = cvLoadImage(
path.c_str(), CV_LOAD_IMAGE_UNCHANGED);
// build CVB image from OpenCV image
IMG cvbFromOcv = nullptr;
cvbval_t planeOrder[] = { 2, 1, 0 };
ocvImg->imageData,
ocvImg->imageSize,
ocvImg->width,
ocvImg->height,
ocvImg->nChannels,
8,
ocvImg->nChannels * 1,
ocvImg->widthStep,
1,
planeOrder,
final_release,
ocvImg,
cvbFromOcv);
// display it (simply painting over the desktop)
cvbFromOcv,
GetDC(NULL),
0,
0,
0,
0,
ImageWidth(cvbFromOcv)-1,
ImageHeight(cvbFromOcv)-1,
0,
1,
2,
1.0,
0);
ReleaseObject(cvbFromOcv);
cvbdim_t ImageWidth(IMG Image)
cvbdim_t ImageHeight(IMG Image)
void ImageToDC(IMG ImageIn, HDC hDC, cvbval_t hDCLeft, cvbval_t hDCTop, cvbval_t InLeft, cvbval_t InTop, cvbval_t InRight, cvbval_t InBottom, cvbval_t hDCWidth, cvbval_t hDCHeight, cvbval_t RedPlaneIndex, cvbval_t GreenPlaneIndex, cvbval_t BluePlaneIndex, double Gain, cvbval_t Offset)
cvbbool_t ReleaseObject(OBJ &Object)
IPP
With IPP we need to take into account the possibility of planar memory layout (P3 and P4 variants of the image data types), as well as the special cases of the alpha channel (AC4) and the complex data types (32sc and 32fc):
  • Interleaved Formats (C1, C2, C3, C4):
    NumPlanes refers to the value given to CreateImageFromPointer in the NumPlanes function parameter. stepBytes is the value returned by the ippMalloc function in the pStepBytes parameter (needs to memorized for later use) or generally speaking the y increment that is being used in IPP function calls.
    PitchX = NumPlanes * sizeof(pixel_type)
    PitchY = stepBytes
  • Alpha channel formats (AC4)
    PitchX = 4 * sizeof(pixel_type)
    PitchY = stepBytes
  • Planar formats (P3, P4)
    Planar formats are only supported by CreateImageFromPointer if the distance in memory between the different planes is fixed. As there is currently no ippMalloc version for planar images it is the caller’s responsibility to make sure that this condition is met and that the y increments and the plane increments are calculated correctly and take into account the necessary padding bytes.
    PitchX = sizeof(pixel_type)
    PitchY = stepBytes
    PitchPlane = planeDistance
  • Complex formats (32sc, 32fc)
    To handle IPP’s complex data formats properly, there are two valid approaches: either double the width and then access the image as if it were a regular image (keeping in mind that the even columns hold the real part and the odd columns hold the imaginary part of the pixel values), or create an image with two planes (plane 0 for the real part and plane 1 for the imaginary part). The latter approach is only possible for complex formats with just one channel, at least without building multiple images with CreateImageFromPointer and then concatenating them with CreateConcatenatedImage.
    The approach of doubling the width is fairly straightforward and the rules mentioned above the IPP apply (with sizeof(pixel_type) being 4 of course). Just remember to multiply the Width parameter with 2 in that case. Building an image where the real part and the imaginary part are located in different planes requires – besides multiplying the NumPlanes parameter with 2 – a slight modification of the calculation of the increments:
    PitchX = 8
    PitchY = stepBytes
    PitchPlane = 4
  •  PlaneOrder
    This parameter gives the caller the opportunity to easily reorder the numbering of the image planes. As mentioned before, CVB usually interprets plane 0 as the red channel, plane 1 as the green channel and plane 2 as the blue channel where color processing or display is involved. If that fits the data provided by the 3rd party library (typically the case with the IPP for example), then PlaneOrder can simply be set to NULL. But OpenCV by default loads color images in BGR format – in this case the PlaneOrder parameter should be set up like this to create a proper CVB image:
  • ReleaseCallback, pUserData
    The callback and user data pointer provided here can help make sure that the 3rd party image’s lifetime and the CVB image’s lifetime are properly managed. As the CVB image constructed by CreateImageFromPointer shares the source image’s memory, it is absolutely necessary that the source image exists at least as long as the CVB image constructed by CreateImageFromPointer. To make this easier, a callback pointer can be given in the ReleaseCallback parameter, and this callback will be invoked by CVB as soon as the reference counter of the image constructed by CreateImageFromPointer reaches zero. With this callback and the user data pointer it is even possible to transfer ownership (and thereby lifetime management) of the 3rd party image to CVB. For example it is possible to simply pass the IplImage* returned by e.g. cvLoadImage to the pUserData parameter and call cvReleaseImage on it in the release callback (see code example below). ReleaseCallback and/or pUserData may be set to NULL if the caller is not interested in knowing when the CVB image has been destroyed.
    Of course it is also possible to decouple the CVB image completely from the source image it has been created from, but this requires copying the image data and is therefore a bit more time consuming. Probably the most convenient way to do it is to call CreateImageFromPointer first (as described above) and then using CreateDuplicateImageEx to create a decoupled copy of the source image.
Halcon
In Halcon the operator get_image_pointer1 returns a pointer to the first channel of the image. Additionally, the image type (Type = byte, int2, uint2, etc.) and the image size (width and height) are returned. Consequently, a direct access to the image data via the pointer is possible. An image is stored by Halcon linearized in row major order, i.e., line by line. Note that the image types complex and vector_type are handled differently: complex images are interleaved, i.e., the real and the imaginary parts are alternating. In contrast, vector_field images consist of two matrices, one for the rows and one for the columns, which are stored one after the other. The number of image planes can be retrieved in Halcon using the function HImage::CountChannels(). Using both get_image_pointer1 and HImage::CountChannels(), all the required arguments for the CVB function CreateImageFromPointer can be calculated.
4. Data Transfer from CVB to 3rd Party Libraries
Transferring data from CVB images to 3rd party libraries is a lot more difficult than vice versa – especially if the transfer is supposed to be done without copying image data. Ironically it is the VPAT image model that made transferring 3rd party images into CVB so easy in the previous chapter. This makes the other direction potentially more complicated because a certain amount of work needs to be invested to make sure that the memory layout of the CVB image matches the requirements of the destination library.
Transfer Without Copy
For performance reasons, it is usually more desirable to interface CVB to another library without copying the image data. However, this is not always possible.
First of all the 3rd party library that is the target for the image data needs to support this approach, i.e., there needs to be some means of creating an image for that library around an already existing memory block (much like the CreateImageFromPointer function in CVB or the combination of cvCreateImageHeader and cvSetData in OpenCV). This is not always a given – a library that concerns itself exclusively or mostly with the acquisition of images is likely to require the buffers it works on to have been allocated by its own memory management. In short: If you want to transfer image data without copying them, the first step should be to make sure that the destination library actually supports this.
Then there is the matter of the CVB image model. Because the VPAT interface of CVB images supports far more memory layouts than a library relying on e.g., a base pointer and a fixed y increment, it is necessary to analyze the memory layout of a CVB image to find out if a data transfer without copying the image data is possible. The function for this is GetLinearAccess (exported by the CVCUtilities.dll). It analyses the VPAT on a given image’s plane and returns the x and y increments as well as the base pointer if the VPAT is organized linearly (i.e. if it uses fixed increments in x and y direction), otherwise the returned increments will be 0. The subsequent checks on the increments and the base pointer that are necessary of course depend on the 3rd party library’s requirements, so it is not possible to give a complete and generally applicable account here but for our sample cases (OpenCV and IPP) it is possible to give a recipe.
OpenCV
First of all, it is recommendable to determine whether or not the image format is in principle compatible with OpenCV. For this to be the case:
  • all image planes will need to be of the same data type (usually the case)
  • the data type must be one of those supported by OpenCV (see chapter 2)
  • the number of planes must not exceed 4.
If these conditions are met, GetLinearAccess will need to be called on each plane of the image. In principle these conditions apply the logic behind the calculation of the increments for CreateImageFromPointer shown in chapter 3 to the CVB image. The results (base pointers and increments) will need to be harvested for the following comparisons:
  • The x and y increments for all planes need to be identical
  • The x increment must be equal to the number of bytes per pixel times the number of planes
  • The y increment must be greater or equal to the x increment times the image width. If the y increment is bigger than x increment times image width there simply is a number of padding bytes added in memory to each line which can be safely ignored.
  • For images with more than one plane the absolute difference between two consecutive base pointers must be equal to the number of bytes per pixel
  • For images with three planes to be properly interpreted as BGR by OpenCV it is necessary that the three base pointers are in descending order (i.e. base pointer for plane 0 points to a higher address than base pointer for plane 1 and base pointer for plane 1 points to a higher address than base pointer for plane 2). This is an implication of the BGR ordering of the color planes that OpenCV expects. Note that the IplImage structure does in fact have a channelSeq member, but according to the documentation this member is ignored by OpenCV. Of course, application of this criterion is optional: For those OpenCV functions that do not process color information the channel order is largely irrelevant.
If all the required conditions are met, attaching an OpenCV image to the CVB image data is fairly straightforward: First an empty IplImage structure needs to be created as the recipient by calling cvCreateImageHeader, then the data members need to be set using cvSetData (the input for cvSetData can be taken directly from GetLinearAccess.
The only remaining issue to be sorted out now is the object lifetime. The situation is a bit dangerous in that both, the source CVB image and the wrapping OpenCV image rely on the same image data to be available. CVB has no means of yielding ownership of its image memory to another entity, so calling e.g., cvReleaseImage or cvReleaseData will result in an access violation as soon as the CVB image is being accessed after that (even if it is just through ReleaseObject). Vice versa, calling ReleaseObject on the CVB image and accessing the OpenCV image afterward will also result in an access violation. The only safe way to get rid of both, the CVB image and the OpenCV image (without producing a memory leak) is to only call cvReleaseImageHeader on the OpenCV side and (as usual) ReleaseObject on the CVB side. Of course the ReleaseObject call can happen a lot later than cvReleaseImageHeader – the latter will in fact destroy the the IplImage structure so that accidental continued use of the image is no longer possible.
Expressing all this in C/C++ could look e.g., like this:
int ocv_depth(cvbdatatype_t cvbDt)
// map compatible cvb data type descriptors to
// OpenCV data types switch (cvbDt & 0xFF)
case 8:
return IsSignedDatatype(cvbDt) ? IPL_DEPTH_8S : IPL_DEPTH_8U;
case 16:
return IsSignedDatatype(cvbDt) ? IPL_DEPTH_16S : IPL_DEPTH_16U;
case 32:
return IsFloatDatatype(cvbDt) ? IPL_DEPTH_32F : IPL_DEPTH_32S;
case 64:
return IsFloatDatatype(cvbDt) ? IPL_DEPTH_64F : 0;
bool is_opencv_compatible(IMG cvbImg)
using namespace std;
if (cvbImg == nullptr)
return false;
vector<cvbdatatype_t> dataTypes(ImageDimension(cvbImg));
for (cvbdim_t i = 0; i < ImageDimension(cvbImg); ++i)
dataTypes[i] = ImageDatatype(cvbImg, i);
// all planes have identical data type?
for (size_t i = 1; i < dataTypes.size(); ++i)
if (dataTypes[i] != dataTypes[0])
return false;
// data type compatible with OpenCV?
if (ocv_depth(dataTypes[0]) == 0)
return false;
// no more than 4 channels?
if ((ImageDimension(cvbImg) < 1) || (ImageDimension(cvbImg) > 4))
return false;
// all checks passed
return true;
bool is_opencv_shareable(IMG cvbImg, bool bgrStrict)
if(!is_opencv_compatible(cvbImg))
return false;
vector<intptr_t> basePtr(ImageDimension(cvbImg));
vector<intptr_t> xInc(ImageDimension(cvbImg));
vector<intptr_t> yInc(ImageDimension(cvbImg));
GetLinearAccess(cvbImg,
i,
reinterpret_cast<void**>(&basePtr[i]),
&xInc[i],
&yInc[i]);
// do all planes have same increment in x and y?
for (size_t i = 1; i < xInc.size(); ++i)
if (xInc[i] != xInc[0])
return false;
if (yInc[i] != yInc[0])
return false;
// do the increments hint at an interleaved memory layout?
size_t bytesPp = BytesPerPixel(ImageDatatype(cvbImg, 0));
if (xInc[0] != (bytesPp * ImageDimension(cvbImg)))
return false;
// is the y increment ok?
if (yInc[0] < xInc[0] * ImageWidth(cvbImg))
return false;
// is the plane pitch ok?
if (ImageDimension(cvbImg) > 1)
for (size_t i = 0; i < basePtr.size() - 1; ++i)
ptrdiff_t iInc = abs(basePtr[i+1] - basePtr[i]);
if (iInc != bytesPp)
return false;
// if requested, make sure we have bgr arrangement
if ((bgrStrict) && (ImageDimension(cvbImg) == 3))
if (basePtr[0] <= basePtr[1])
return false;
if (basePtr[1] <= basePtr[2])
return false;
// all test passed successfully
return true;
IplImage* cvb_to_ocv_nocopy(IMG cvbImg, bool bgrStrict)
if (!is_opencv_shareable(cvbImg, bgrStrict))
return nullptr;
// construct an appropriate OpenCV image CvSize size;
size.width = ImageWidth(cvbImg);
size.height = ImageHeight(cvbImg);
IplImage* retval = cvCreateImageHeader(
size,
ocv_depth(ImageDatatype(cvbImg, 0)), ImageDimension(cvbImg));
if (retval == nullptr)
return retval;
// as we have made sure that the memory layout is compatible, it is
// sufficient here to access plane 0 only
void* ppixels = nullptr;
intptr_t xInc = 0;
intptr_t yInc = 0;
GetLinearAccess(cvbImg, 0, &ppixels, &xInc, &yInc);
cvSetData(retval, ppixels, yInc);
return retval;
cvbbool_t GetLinearAccess(IMG Img, cvbdim_t Plane, void **ppBaseAddress, intptr_t *pXInc, intptr_t *pYInc)
cvbdim_t ImageDimension(IMG Image)
cvbdatatype_t ImageDatatype(IMG Image, cvbval_t PlaneIndex)
cvbbool_t IsFloatDatatype(cvbdatatype_t Datatype)
cvbval_t BytesPerPixel(cvbdatatype_t Datatype)
cvbbool_t IsSignedDatatype(cvbdatatype_t Datatype)
cvb.Angle abs(cvb.Angle angle)
Use of these functions is fairly straightforward:
path.append("Tutorial\\FruitBowl.jpg");
IMG cvbImg = nullptr;
LoadImageFile(path.c_str(), cvbImg);
// create an attached OpenCV image
IplImage* ocvImg = cvb_to_ocv_nocopy(cvbImg, false);
// cleanup
cvReleaseImageHeader(&ocvImg);
ReleaseObject(cvbImg);
cvbbool_t LoadImageFile(const char *FileName, IMG &ImageOut)
IPP
In principle the same approach taken for OpenCV can be applied to IPP as well, therefore we will not re-iterate them in source code here again. First verify whether the image is in principle usable with IPP (the analysis is more less the same as for OpenCV, however IPP does not support 64 bit floating point images), analyze the memory layout (keeping in mind that some functions of IPP actually also support a planar layout) and use the information provided by GetLinearAccess to let IPP work on the image.
BGR arrangement is not an issue here, as most functions in IPP actually expect RGB layout, and lifetime management also is a non-issue as IPP uses no image structure of its own.
There is, however, one additional pitfall that did not apply to OpenCV: The IPP tries to use SSE optimized algorithms wherever possible. These do not only require that each line starts on a 4 byte boundary, they also require that the image starts on a 32 bit boundary. Both need to be verified using the data returned by GetLinearAccess, when calling an IPP function. If these conditions are not met, those IPP functions that expected them will return an error code. Two situations where this image data layout is usually given are CVB VIN drivers (as long as RotateImage has not been set) and BMP files.
Lifetime is also a non-issue with IPP. As there is – at least in the C API – no data structure for images (IPP usually works only on pointers and increments that the caller needs to keep inside his own data structures) there is nothing to keep in mind other than that the pointers and increments returned by GetLinearAccess should not be used any more once the image has been released with ReleaseObject.
Halcon
Unlike in CVB, the Halcon image model is always planar in RGB cases. Therefore, it is only possible to convert monochrome CVB images to Halcon images without copying - for converting color CVB images to Halcon, copying is inevitable. The Halcon operator GenImage1Extern creates an image from a pointer to the pixels with storage management. As it has been explained already the pointer to the pixels can be queried with GetLinearAccess to let Halcon work on the image. The memory for the new image is not newly allocated by HALCON, and thus is not copied either. This means that the memory space that PixelPointer points to must be released by calling ReleaseObject on the CVB image object. This is done by the callback ClearProc provided by the caller. This procedure must have the following signature.
void __cdecl ClearProc(void* ptr);
and will be called using __cdecl calling convention when deleting Image. If the memory shall not be released (in the case of frame grabbers or static memory) a procedure “without trunk” or the NULL-Pointer can be passed. Please remember that x and y increment of a CVB image should fulfill the same condition mentioned in OpenCV .
int main()
// using CVB, load a Mono8 image
// make sure cvbImg refers to a monochrome image with 8 bits per pixel
// get linear access to the CVB image
cvbuint8_t* pBase = nullptr;
intptr_t xInc = 0;
intptr_t yInc = 0;
cvbdim_t width = ImageWidth(cvbImg);
cvbdim_t height = ImageHeight(cvbImg);
cvbdim_t imageDimension = ImageDimension(cvbImg);
cvbImg,
imageDimension - 1,
&xInc,
&yInc);
// convert monochrome 8bit CVB image to Halcon image
HImage halconImg;
Hlong originalWidth = int(width);
Hlong originalHeight = int(height);
const char Type[] = "byte";
Hlong fillColor = 255;
halconImg.GenImage1Extern(
Type,
originalWidth,
originalHeight,
pBase,
ClearProc);
// continue to work with both images;
// make sure halconImg doesn't go out of scope before
// ReleaseObject(cvbImg); is called!
Transfer With Copy
Although copying the image data from a CVB image to any 3rd party data structure will take significantly longer than the approach explained in the previous chapter (even on small images), there are typically two scenarios where that amount of time needs to be invested:
  1. If the 3rd party library does not accept memory buffers that weren’t allocated by it.
  2. If the memory layout of the CVB image does not meet the requirements of the 3rd party library. Keep in mind that this can often be prevented by fairly simple measures. For example make sure that the RotateImage parameter in the driver configuration file is (if available) set to 0 and avoid functions like GetLinearAccess, CreatePanoramicImageMap and CreateRotatedImageMap, as these functions will (most likely) generate VPATs that are not linearly accessible. Doing memcpy line by line as opposed to doing the whole image in one block is not much slower but saves a great deal of checks that would be necessary to properly treat padding bytes and, at the same time, automatically takes care of potential discrepancies between top-down or bottom-up arrangement.
These two cases can differ significantly in terms of implementation and time required for copying the data. If the data in the CVB image is already arranged in a format that is usable by the target library, copying the data line by line will be very efficient. Otherwise, it may be necessary to copy each pixel individually through VPAT access, which obviously is more time-consuming.
OpenCV
To determine whether or not it becomes necessary to copy the image data through the VPAT, we can revert to the work that has been done in the previous chapter: If it would in principle be possible to transfer the data without copying, then the layout obviously is already ok and VPAT copy will not be necessary. Copying in this case is reduced to a loop over the image’s lines. For VPAT copy, there obviously needs to be two loops (one in vertical and one in horizontal direction). A bit of complexity is added by the fact that the amount of data to be copied for each pixel depends on the image’s data type, but templates go a long way to implementing copy loops that automatically apply to all supported data types. They can also greatly help reduce overhead from looping through the image planes. Note, however, that this benefit can only be reaped in the release build. In practice the code will look something like this:
IplImage* cvb_to_ocv_copy_lines(IMG cvbImg)
// consistency checks on input
if (!is_opencv_compatible(cvbImg))
return nullptr;
if (!(is_opencv_shareable(cvbImg, true)
|| (is_opencv_shareable(cvbImg, false))))
return nullptr;
// get data access pointers
intptr_t pSrc, xInc, yInc;
pSrc = xInc = yInc = 0;
0,
reinterpret_cast<void**>(&pSrc),
&xInc,
&yInc);
if ((xInc == 0) || (yInc == 0))
return nullptr;
// create destination image
IplImage* retval = cvCreateImage(
cvSize(ImageWidth(cvbImg), ImageHeight(cvbImg)),
return nullptr;
// copy loop
intptr_t pDst = reinterpret_cast<intptr_t>(retval->imageData);
for (int y = 0; y < retval->height; ++y)
memcpy(
reinterpret_cast<void*>(pDst),
reinterpret_cast<void*>(pSrc),
xInc * retval->width);
pSrc += yInc;
pDst += retval->widthStep;
return retval;
template<typename t_pixel, int numPlanes>
IplImage* cvb_to_ocv_copy_vpat(IMG cvbImg)
return nullptr;
if (ImageDimension(cvbImg) < numPlanes)
return nullptr;
// get the VPAT pointers
vector<intptr_t> pBase(numPlanes);
vector<PVPAT> pVpat(numPlanes);
vector<intptr_t> pLine(numPlanes);
for (int i = 0; i < numPlanes; ++i)
cvbImg,
i,
reinterpret_cast<void**>(&pBase[i]),
&pVpat[i]))
return nullptr;
// create the destination image
return nullptr;
// copy loops
intptr_t pDstLine = reinterpret_cast<intptr_t>(retval->imageData);
t_pixel* pDst = reinterpret_cast<t_pixel*>(pDstLine);
pLine[i] = pBase[i] + pVpat[i][y].YEntry;
for (int x = 0; x < retval->width; ++x)
if (numPlanes == 3)
// in case we have 4 planes, we switch R and B
*pDst++ = *reinterpret_cast<t_pixel*>(pLine[2] + pVpat[2][x].XEntry);
*pDst++ = *reinterpret_cast<t_pixel*>(pLine[1] + pVpat[1][x].XEntry);
*pDst++ = *reinterpret_cast<t_pixel*>(pLine[0] + pVpat[0][x].XEntry);
if (numPlanes > 1)
if (numPlanes > 2)
if (numPlanes > 3)
*pDst++ = *reinterpret_cast<t_pixel*>(pLine[3] + pVpat[3][x].XEntry);
pDstLine += retval->widthStep;
return retval;
template<typename t_pixel>
IplImage* cvb_to_ocv_copy_vpat_dispatcher(IMG cvbImg)
int dim = ImageDimension(cvbImg);
switch(dim)
case 1:
return cvb_to_ocv_copy_vpat<t_pixel, 1>(cvbImg);
case 2:
return cvb_to_ocv_copy_vpat<t_pixel, 2>(cvbImg);
case 3:
return cvb_to_ocv_copy_vpat<t_pixel, 3>(cvbImg);
case 4:
return cvb_to_ocv_copy_vpat<t_pixel, 4>(cvbImg);
return nullptr;
IplImage* cvb_to_ocv_copy(IMG cvbImg, bool bgrStrict)
// make sure the image is not fundamentally incompatible
return nullptr;
// find out if a line-by-line copy is possible
if (is_opencv_shareable(cvbImg, bgrStrict))
return cvb_to_ocv_copy_lines(cvbImg);
// VPAT copy is necessary to port the image to OpenCV
switch(ocv_depth(ImageDatatype(cvbImg, 0)))
case IPL_DEPTH_8U:
case IPL_DEPTH_8S:
return cvb_to_ocv_copy_vpat_dispatcher<unsigned char>(cvbImg);
case IPL_DEPTH_16U:
case IPL_DEPTH_16S:
return cvb_to_ocv_copy_vpat_dispatcher<unsigned short>(cvbImg);
case IPL_DEPTH_32S:
return cvb_to_ocv_copy_vpat_dispatcher<int>(cvbImg);
case IPL_DEPTH_32F:
return cvb_to_ocv_copy_vpat_dispatcher<float>(cvbImg);
case IPL_DEPTH_64F:
return cvb_to_ocv_copy_vpat_dispatcher<double>(cvbImg);
return nullptr;
y
x
With the OpenCV image created through cvCreateImage independent of the CVB image, it does not matter in what order they are destroyed. And unlike in the previous chapter, destruction of the OpenCV image must now happen through cvReleaseImage, otherwise a memory leak will occur.
IPP
Like in the previous chapter, the copy of CVB image data to IPP buffers is again pretty much covered by what has been said and coded for OpenCV. Again, the major differences are that the IPP does not support double-valued images and is working well with RGB arrangement of color images (therefore the special treatment in the template cvb_to_ocv_copy_vpat for 3-plane images can just be omitted). Due to the special requirements (image start on a 32 byte boundary, line start on a 4 byte boundary), import of CVB images into IPP is probably a little more likely to require copying image data.
Halcon
As explained earlier, Halcon will always represent RGB images with planar memory layout. In CVB, RGB images usually have interleaved memory layout (as delivered by the hardware), so in most cases it will be necessary to copy the pixel data of RGB images from CVB to Halcon. The Halcon operator GenImageInterleaved does just that: It allocates memory for a three-channel planar image and copies the pixel data from an interleaved source. The following simple example shows how to convert a CVB RGB8 image into a Halcon image:
... // do what is necessary to have cvbImg refer to an RGB image
// get linear access to the RGB8 CVB image
intptr_t xInc = 0;
intptr_t yInc = 0;
cvbImg,
imageDimension - 1,
&xInc, &
yInc);
// convert RGB8 CVB image to Halcon image
HImage halconImg;
Hlong alignment = 1;
const char type[] = "byte";
Hlong startRow = 0;
Hlong startColumn = 0;
const char colorFormat[] = "rgb";
Hlong imageWidth = 0;
Hlong imageHeight = 0;
Hlong bitsPerChannel = -1;
Hlong bitShift = 0;
halconImg.GenImageInterleaved(
pBase,
colorFormat,
originalWidth,
originalHeight,
alignment,
type,
imageWidth,
imageHeight,
startRow,
startColumn,
bitsPerChannel,
bitShift);
// cleanup
// (Halcon has copied the image data, so the life time of cvbImg can
// be treated as independent from that of halconImg)
5. Other Programming Languages
C/C++ has been used as the programming language for this description – mostly because when looking at any 3rd party imaging library, C++ is the most likely language to be supported. It is also because the pointer support in C/C++ is very straightforward and versatile. Of course, this does not mean that interoperation with 3rd party libraries is limited to C/C++.
The methods explained in this application note should be easily transferable to any language that supports the notion of pointers such as C#. With C# of course there’s the added complexity of managed versus unmanaged domain, but even that is not really a problem – it just requires proper use of the fixed and the unsafe keyword. Keep in mind however, that it is beneficial to keep the managed-unmanaged transitions to the necessary minimum as these transitions tend to consume a fair amount of CPU time.
Visual Basic.Net programmers can in theory also implement anything that has been shown in this application note. However, because the language does not support pointers directly, doing so requires heavy use of the System.Runtime.InteropServices.Marshal class’s methods and is certain to result in code that is much harder to implement and read, and runs a fair bit slower than the corresponding C# implementation. Therefore, our recommendation to VB.Net programmers is to implement their interoperation with 3rd party libraries in C# into a DLL that can then be used from within a VB.Net application.
