using System.IO;
namespace PixelFormatConversion
class PixelFormatConversion
private static ValueTuple<Image, PfncFormat> GetImage(string fileName)
var imageFormatPair = new ValueTuple<Image, PfncFormat>(
imageSource.CopyTo(imageFormatPair.Item1);
return imageFormatPair;
converter.
Execute(srcImage, dstImage);
return dstImage;
private static string ToString(PfncFormat pixelFormat)
return PfncFormatValue.ToString(pixelFormat);
private static void Save(Image image, string path)
Console.WriteLine($" Saved as: {path}");
Console.WriteLine("As a source, a Bayer pattern image is given.");
const string baseName = "FruitBowl";
const string extension = ".bmp";
var srcImageFormatPair =
GetImage(Path.Combine(new string[] { SystemInfo.InstallPath, "Tutorial", baseName + "Bayer" + extension }));
Save(srcImageFormatPair.Item1, baseName + ToString(srcImageFormatPair.Item2) + extension);
Console.WriteLine("As the destination, an RGB format is given.");
Console.WriteLine("Create a pixel format converter.");
var converter = PixelFormatConverter.
Create(srcImageFormatPair.Item2, dstFormat);
Console.WriteLine("Convert the source to another.");
var dstImage = GetAnotherRepresentation(srcImageFormatPair.Item1, converter);
Console.WriteLine("Saving the converted image as a file.");
Save(dstImage, baseName + ToString(dstFormat) + extension);
static Image FromPixelFormat(Size2D size, PfncFormat pixelFormat)
