namespace Metric3DCalibration
using ExtensionMethods;
class Program
Console.Write("Estimation of a rigid body transformation (rotation and translation)\n\n");
var piece = GetAQS12Piece();
var rangeMap =
Image.
FromFile(
@"%CVB%\Tutorial\Metric\Images\RangeMapCalibrationPattern.tif");
Console.Write("Rangemap loaded with size of " + rangeMap.Width.ToString() + " x " + rangeMap.Height.ToString() + " from ");
Console.Write(@"%CVB%\Tutorial\Metric\Images\RangeMapCalibrationPattern.tif" + "\n");
Console.Write("Dense point cloud created from rangemap and calibration file with " + cloud.NumPoints + " points.\n\n");
WindowSize = 5
calibrator.ExtrinsicMatrix = trafo.Item1;
trafo.Item1.ShowTransformation();
trafo.Item2.ShowTransformation();
Console.Write("Residuals:\n");
residuals.ShowXYZArray();
var calibratedCloud = calibrator.CreatePointCloud(rangeMap,
PointCloudFlags.Float);
Console.Write("Number of points: " + calibratedCloud.NumPoints + "\n");
public static AQS12Piece GetAQS12Piece()
var points = new Point3Dd[]
new Point3Dd(20.0018, 44.9941, 15.0000),
new Point3Dd(24.0018, 39.9942, 14.9994),
new Point3Dd(23.9994, 24.9972, 15.0001),
new Point3Dd(20.0021, 20.0035, 15.0011),
new Point3Dd(15.9994, 25.0079, 15.0016),
new Point3Dd(16.0000, 39.9919, 15.0010),
new Point3Dd(20.0095, 59.9985, 4.9902),
new Point3Dd(32.0093, 44.9958, 4.9909),
new Point3Dd(32.0052, 19.9925, 4.9920),
new Point3Dd(20.0021, 4.9961, 4.9939),
new Point3Dd( 8.0024, 19.9980, 5.0009),
new Point3Dd( 8.0065, 45.0009, 4.9984)
return new AQS12Piece(points, 0);
namespace ExtensionMethods
public static class Extensions
public static void ShowTransformation(this AffineMatrix3D trafo)
System.Text.StringBuilder sMessage = new System.Text.StringBuilder();
sMessage.Append("Translation:\n");
sMessage.Append("\n\nTransformation matrix:\n");
sMessage.Append("\n\n");
Console.Write(sMessage.ToString());
public static void ShowTransformation(this AffineTransformationParameters trafoPara)
sMessage.Append("Rotation angles in [degree] about\n");
public static void ShowXYZArray(this Point3Dd[] xyz)
sMessage.Append("Point \t X \t Y \t Z \n");
for (int i = 0; i < 12; i++)
sMessage.Append(i + 1 + "\t" + xyz[i].X.ToString("N4") + " " + xyz[i].Y.ToString("N4") + " " + xyz[i].Z.ToString("N4") + "\n");
sMessage.Append("\n");
PointCloud CreatePointCloud(Image rangeMap)
static Calibrator3D FromFile(string fileName)
static Tuple< AffineMatrix3D, AffineTransformationParameters > CalculateRigidBodyTransformationFromAqs12Piece(DensePointCloud cloud, AQS12DensePointCloudSegmentor segmentor, AQS12Piece piece, out Point3Dd[] residuals)
override string ToString()
