Foundation/Cvb.Net/Metric3DCalibration
This example program is located in your CVB installation under %CVB%Tutorial/Foundation/Cvb.Net/Metric3DCalibration.
Program.cs:
// Example for **intrinsic and extrinsic calibration** of a laser triangulation system using the AQS12
// target.
namespace Metric3DCalibration
using ExtensionMethods;
class Program
Console.Write("Estimation of homography and affine transformation (correcting an inclined laser plane)\n\n");
var piece = GetAQS12Piece();
var segmentor = new AQS12RangeMapSegmentor(SegmentationMethod.KmeansClustering);
var rangeMap = Image.FromFile(@"%CVB%\Tutorial\Metric\Images\RangeMapCalibrationPattern.tif");
Console.Write("Rangemap loaded with size of " + rangeMap.Width.ToString() + " x " + rangeMap.Height.ToString() + " from ");
Console.Write(@"%CVB%\Tutorial\Metric\Images\RangeMapCalibrationPattern.tif" + "\n");
Point3Dd[] residuals;
var calibrator = Metric.CalibratorFromAqs12Piece(rangeMap.Planes[0], segmentor, config, out residuals);
calibrator.CorrectionOfLaserPlaneInclination.Item1.Value.ShowTransformation();
if (calibrator.CorrectionOfLaserPlaneInclination.Item2 != null)
calibrator.CorrectionOfLaserPlaneInclination.Item2.Value.ShowTransformation();
Console.Write("Residuals:\n");
residuals.ShowXYZArray();
double desiredAccuracy = 0.05;
if (!residuals.CheckAccuracy(desiredAccuracy))
Console.Write("Results do not have desired accuracy. Check face segmentation and extracted AQS12 points...\n");
var facesAqs12 = segmentor.FaceSegmentationFromPiece(rangeMap.Planes[0]);
var pointsAqs12 = segmentor.ExtractProjectedPointsFromPiece(rangeMap.Planes[0]);
Console.Write("Extracted points from range map:\n");
pointsAqs12.ShowXYZArray();
var calibratedCloud = calibrator.CreatePointCloud(rangeMap, PointCloudFlags.Float);
Console.Write("The calibration was sucessful and accuracy is < " + desiredAccuracy.ToString() + " mm. :)\n");
public static AQS12Piece GetAQS12Piece()
var points = new Point3Dd[]
new Point3Dd(20.0018, 44.9941, 15.0000),
new Point3Dd(24.0018, 39.9942, 14.9994),
new Point3Dd(23.9994, 24.9972, 15.0001),
new Point3Dd(20.0021, 20.0035, 15.0011),
new Point3Dd(15.9994, 25.0079, 15.0016),
new Point3Dd(16.0000, 39.9919, 15.0010),
new Point3Dd(20.0095, 59.9985, 4.9902),
new Point3Dd(32.0093, 44.9958, 4.9909),
new Point3Dd(32.0052, 19.9925, 4.9920),
new Point3Dd(20.0021, 4.9961, 4.9939),
new Point3Dd( 8.0024, 19.9980, 5.0009),
new Point3Dd( 8.0065, 45.0009, 4.9984)
return new AQS12Piece(points, 0);
namespace ExtensionMethods
public static class Extensions
public static void ShowTransformation(this AffineMatrix3D trafo)
System.Text.StringBuilder sMessage = new System.Text.StringBuilder();
sMessage.Append("Translation:\n");
sMessage.Append(trafo.Translation.ToString());
sMessage.Append("\n\nTransformation matrix:\n");
sMessage.Append(trafo.Matrix.ToString());
sMessage.Append("\n\n");
Console.Write(sMessage.ToString());
public static void ShowTransformation(this AffineTransformationParameters trafoPara)
sMessage.Append("Rotation angles in [degree] about\n");
sMessage.Append("X: " + trafoPara.RotationAngles[0].ToString("N4") + "\n");
sMessage.Append("Y: " + trafoPara.RotationAngles[1].ToString("N4") + "\n");
sMessage.Append("Z: " + trafoPara.RotationAngles[2].ToString("N4") + "\n\n");
sMessage.Append("Inclination of laser plane in [degree] about\n");
sMessage.Append("X: " + trafoPara.InclinationX.ToString("N4") + "\n");
sMessage.Append("Z: " + trafoPara.InclinationZ.ToString("N4") + "\n\n");
sMessage.Append("Shear\n");
sMessage.Append("Syz: " + trafoPara.Syz.ToString("N5") + "\n");
sMessage.Append("Syx: " + trafoPara.Syx.ToString("N5") + "\n\n");
sMessage.Append("Scale\n");
sMessage.Append("X: " + trafoPara.Scale.X.ToString("N3") + "\n");
sMessage.Append("Y: " + trafoPara.Scale.Y.ToString("N3") + "\n");
sMessage.Append("Z: " + trafoPara.Scale.Z.ToString("N3") + "\n\n");
public static void ShowXYZArray(this Point3Dd[] xyz)
sMessage.Append("Point \t X \t Y \t Z \n");
for (int i = 0; i < 12; i++)
sMessage.Append(i + 1 + "\t" + xyz[i].X.ToString("N4") + " " + xyz[i].Y.ToString("N4") + " " + xyz[i].Z.ToString("N4") + "\n");
sMessage.Append("\n");
public static bool CheckAccuracy(this Point3Dd[] residuals, double desiredAccuracy)
foreach (Point3Dd residual in residuals)
if (residual.X > desiredAccuracy || residual.Y > desiredAccuracy || residual.Z > desiredAccuracy)
return false;
return true;
} // namespace ExtensionMethods
static CalibrationConfiguration FromAQS12Piece(AQS12Piece piece)
static LaserPlaneHomographyCalibrator3D CalibratorFromAqs12Piece(ImagePlane rangeMapPlane, AQS12RangeMapSegmentor segmentor, CalibrationConfiguration config, out Point3Dd[] residuals)
Tuple< AffineMatrix3D?, AffineTransformationParameters?> CorrectionOfLaserPlaneInclination
override string ToString()
